SAM V71 WM8904 SSC one interrupt per sample, one interrupt per XDMA complete
8 posts / 0 new
I would like to have an interrupt per sample of the SSC. I took the demo code from
https://microchipdeveloper.com/asf:audio-sine-tone-intro#Steps_anchor
and added ISR Handlers for SSC and XDMA to increment counter global variables. In the watch, I see the global counter go up only for the SSC Handler.  How come the codec stops producing a waveform when I this in the code? How do I fix it?
    NVIC_EnableIRQ(SSC_IRQn);
    ssc_enable_interrupt(SSC, 0xFFFFFFFF);
volatile uint32_t xdmacHandlerCount = 0;
volatile uint32_t sscHandlerCount = 0;
void XDMAC_Handler(void){
	xdmacHandlerCount ++;
void SSC_Handler        ( void ){
	sscHandlerCount ++;
Where do I find a quick start guide for SSC? I don't see anything here:
https://asf.microchip.com/docs/latest/get_started.html
The whole code is here:
Frank
#include <asf.h>
/// @cond 0
/**INDENT-OFF**/
#ifdef __cplusplus
extern "C" {
#endif
/**INDENT-ON**/
/// @endcond
#define STRING_EOL    "\r"
#define STRING_HEADER "-- Audio sine tone using SSC on WM8904 --\r\n" \
"-- "BOARD_NAME" --\r\n" \
"-- Compiled: "__DATE__" "__TIME__" --"STRING_EOL
//#define PCK2 PMC_MCKR_CSS_MAIN_CLK
#define PCK2 PMC_MCKR_CSS_SLOW_CLK
/** Features of the stored sine tone */
/** Sampling rate */
#define SAMPLE_RATE             (48000)
/** slot per sample */
#define SLOT_BY_FRAME           (2)
/** Bits per slot */
#define BITS_BY_SLOT            (16)
/* Input Master Clock to SSC peripheral */
#define INPUT_MCK_TO_SSC		120000000
/** XDMA channel used in this example. */
#define XDMA_CH_SSC_TX    0
/** XDMA Descriptor */
#define TOTAL_BUFFERS     2
#define MAX_DMA_SIZE            240
static lld_view1 linklist_write[TOTAL_BUFFERS];
static uint16_t AudioBuffer[MAX_DMA_SIZE*(BITS_BY_SLOT / 8)]=
	0,           0,
	1714, 		 1714,
	3425, 		 3425,
	5125, 		 5125,
	6812, 		 6812,
	8480, 		 8480,
	10125, 		 10125,
	11742, 		 11742,
	13327, 		 13327,
	14876, 		 14876,
	16383, 		 16383,
	17846, 		 17846,
	19260, 		 19260,
	20621, 		 20621,
	21925, 		 21925,
	23170, 		 23170,
	24350, 		 24350,
	25465, 		 25465,
	26509, 		 26509,
	27481, 		 27481,
	28377, 		 28377,
	29196, 		 29196,
	29934, 		 29934,
	30591, 		 30591,
	31163, 		 31163,
	31650, 		 31650,
	32051, 		 32051,
	32364, 		 32364,
	32587, 		 32587,
	32722, 		 32722,
	32767, 		 32767,
	32722, 		 32722,
	32587, 		 32587,
	32364, 		 32364,
	32051, 		 32051,
	31650, 		 31650,
	31163, 		 31163,
	30591, 		 30591,
	29934, 		 29934,
	29196, 		 29196,
	28377, 		 28377,
	27481, 		 27481,
	26509, 		 26509,
	25465, 		 25465,
	24350, 		 24350,
	23170, 		 23170,
	21925, 		 21925,
	20621, 		 20621,
	19260, 		 19260,
	17846, 		 17846,
	16383, 		 16383,
	14876, 		 14876,
	13327, 		 13327,
	11742, 		 11742,
	10125, 		 10125,
	8480, 		 8480,
	6812, 		 6812,
	5125, 		 5125,
	3425, 		 3425,
	1714, 		 1714,
	0, 		 0,
	-1715, 		 -1715,
	-3426, 		 -3426,
	-5126, 		 -5126,
	-6813, 		 -6813,
	-8481, 		 -8481,
	-10126, 	 -10126,
	-11743, 	 -11743,
	-13328, 	 -13328,
	-14877, 	 -14877,
	-16384, 	 -16384,
	-17847, 	 -17847,
	-19261, 	 -19261,
	-20622, 	 -20622,
	-21926, 	 -21926,
	-23171, 	 -23171,
	-24351, 	 -24351,
	-25466, 	 -25466,
	-26510, 	 -26510,
	-27482, 	 -27482,
	-28378, 	 -28378,
	-29197, 	 -29197,
	-29935, 	 -29935,
	-30592, 	 -30592,
	-31164, 	 -31164,
	-31651, 	 -31651,
	-32052, 	 -32052,
	-32365, 	 -32365,
	-32588, 	 -32588,
	-32723, 	 -32723,
	-32768, 	 -32768,
	-32723, 	 -32723,
	-32588, 	 -32588,
	-32365, 	 -32365,
	-32052, 	 -32052,
	-31651, 	 -31651,
	-31164, 	 -31164,
	-30592, 	 -30592,
	-29935, 	 -29935,
	-29197, 	 -29197,
	-28378, 	 -28378,
	-27482, 	 -27482,
	-26510, 	 -26510,
	-25466, 	 -25466,
	-24351, 	 -24351,
	-23171, 	 -23171,
	-21926, 	 -21926,
	-20622, 	 -20622,
	-19261, 	 -19261,
	-17847, 	 -17847,
	-16384, 	 -16384,
	-14877, 	 -14877,
	-13328, 	 -13328,
	-11743, 	 -11743,
	-10126, 	 -10126,
	-8481, 		 -8481,
	-6813, 		 -6813,
	-5126, 		 -5126,
	-3426, 		 -3426,
	-1715, 		 -1715
	sscHandlerCount ++;
 *  \brief Configure UART console.
static void configure_console(void)
	const usart_serial_options_t uart_serial_options =
		.baudrate = CONF_UART_BAUDRATE,
		.charlength = CONF_UART_CHAR_LENGTH,
		.paritytype = CONF_UART_PARITY,
		.stopbits = CONF_UART_STOP_BITS,
	/* Configure console UART. */
	sysclk_enable_peripheral_clock(CONSOLE_UART_ID);
	stdio_serial_init(CONF_UART, &uart_serial_options);
 *  \brief Configure SSC in Master or Slave mode
 *  (based on the value of macro PCK2) for Tx operation only
static void configure_ssc(void)
	clock_opt_t tx_clk_option;
	data_frame_opt_t tx_data_frame_option;
	/* Initialize clock */
	pmc_enable_periph_clk(ID_SSC);
	/* Reset SSC */
	ssc_reset(SSC);
	if(PCK2 == PMC_MCKR_CSS_SLOW_CLK)
		/* Transmitter clock mode configuration. */
		tx_clk_option.ul_cks = SSC_TCMR_CKS_TK;
		tx_clk_option.ul_cko = SSC_TCMR_CKO_NONE;
		tx_clk_option.ul_cki = 0;
		tx_clk_option.ul_ckg = SSC_TCMR_CKG_CONTINUOUS;
		tx_clk_option.ul_start_sel = SSC_TCMR_START_TF_EDGE;
		tx_clk_option.ul_sttdly = 1;
		tx_clk_option.ul_period = BITS_BY_SLOT - 1;
		/* Transmitter frame mode configuration. */
		tx_data_frame_option.ul_datlen = BITS_BY_SLOT - 1;
		tx_data_frame_option.ul_msbf = SSC_TFMR_MSBF;
		tx_data_frame_option.ul_datnb = 0;
		tx_data_frame_option.ul_fslen = BITS_BY_SLOT - 1;
		tx_data_frame_option.ul_fslen_ext = 0;
		tx_data_frame_option.ul_fsos = SSC_TFMR_FSOS_NONE;
		tx_data_frame_option.ul_fsedge = SSC_TFMR_FSEDGE_POSITIVE;
		ssc_set_clock_divider(SSC, ((BITS_BY_SLOT*SLOT_BY_FRAME)*SAMPLE_RATE), INPUT_MCK_TO_SSC);
		tx_clk_option.ul_cks = SSC_TCMR_CKS_MCK;
		tx_clk_option.ul_cko = SSC_TCMR_CKO_CONTINUOUS;
		//tx_data_frame_option.ul_datlen = BITS_BY_SLOT - 1;
		tx_data_frame_option.ul_datnb = SLOT_BY_FRAME - 1;
		tx_data_frame_option.ul_fsos = SSC_TFMR_FSOS_NEGATIVE;
	ssc_set_transmitter(SSC, &tx_clk_option, &tx_data_frame_option);
	/* Disable transmitter first */
	ssc_disable_tx(SSC);
	/* Disable All Interrupt */
	ssc_disable_interrupt(SSC, 0xFFFFFFFF);
 *  \brief Configure DMA
static void configure_xdma(void)
	uint16_t *src;
	uint8_t i;
	xdmac_channel_config_t xdmac_channel_cfg = {0};
	/* Initialize and enable DMA controller */
	pmc_enable_periph_clk(ID_XDMAC);
	xdmac_channel_cfg.mbr_cfg = XDMAC_CC_TYPE_PER_TRAN
								| XDMAC_CC_MBSIZE_SINGLE
								| XDMAC_CC_DSYNC_MEM2PER
								| XDMAC_CC_CSIZE_CHK_1
								| XDMAC_CC_DWIDTH_HALFWORD
								| XDMAC_CC_SIF_AHB_IF0
								| XDMAC_CC_DIF_AHB_IF1
								| XDMAC_CC_SAM_INCREMENTED_AM
								| XDMAC_CC_DAM_FIXED_AM
								| XDMAC_CC_PERID(32);
	xdmac_configure_transfer(XDMAC, XDMA_CH_SSC_TX, &xdmac_channel_cfg);
	src = &AudioBuffer[0];
	for(i = 0; i < TOTAL_BUFFERS; i++)
		linklist_write[i].mbr_ubc = XDMAC_UBC_NVIEW_NDV1
									| XDMAC_UBC_NDE_FETCH_EN
									| XDMAC_UBC_NSEN_UPDATED
									| XDMAC_UBC_NDEN_UNCHANGED
									| XDMAC_CUBC_UBLEN(MAX_DMA_SIZE);
		linklist_write[i].mbr_sa = (uint32_t)(src);
		linklist_write[i].mbr_da = (uint32_t)&(SSC->SSC_THR);
		if ( i == (TOTAL_BUFFERS - 1 ))
			linklist_write[i].mbr_nda = (uint32_t)&linklist_write[0];
			linklist_write[i].mbr_nda = (uint32_t)&linklist_write[i+1];
	xdmac_channel_set_descriptor_control(XDMAC, XDMA_CH_SSC_TX,
										  XDMAC_CNDC_NDVIEW_NDV1
										| XDMAC_CNDC_NDE_DSCR_FETCH_EN
										| XDMAC_CNDC_NDSUP_SRC_PARAMS_UPDATED
										| XDMAC_CNDC_NDDUP_DST_PARAMS_UPDATED);
	xdmac_channel_set_descriptor_addr(XDMAC, XDMA_CH_SSC_TX, (uint32_t)(&linklist_write[0]), 0);
	xdmac_enable_interrupt(XDMAC, XDMA_CH_SSC_TX);
	xdmac_channel_enable_interrupt(XDMAC, XDMA_CH_SSC_TX, XDMAC_CIE_LIE);
	/*Enable XDMA interrupt */
	NVIC_ClearPendingIRQ(XDMAC_IRQn);
	NVIC_SetPriority(XDMAC_IRQn ,1);
	NVIC_EnableIRQ(XDMAC_IRQn);
 *  \brief Configure Codec WM8904 in Master or Slave mode
 *  (based on the value of macro PCK2) for audio playback
static void configure_codec(void)
	uint16_t data = 0;
	/* check that WM8904 is present */
	wm8904_write_register(WM8904_SW_RESET_AND_ID, 0xFFFF);
	data = wm8904_read_register(WM8904_SW_RESET_AND_ID);
	if(data != 0x8904) {
		printf("WM8904 not found!\n\r");
		while(1);
		wm8904_write_register(WM8904_BIAS_CONTROL_0, WM8904_ISEL_HP_BIAS);
		wm8904_write_register(WM8904_VMID_CONTROL_0, WM8904_VMID_BUF_ENA |
								WM8904_VMID_RES_FAST | WM8904_VMID_ENA);
		delay_ms(5);
		wm8904_write_register(WM8904_VMID_CONTROL_0, WM8904_VMID_BUF_ENA | 	WM8904_VMID_RES_NORMAL | WM8904_VMID_ENA);
		wm8904_write_register(WM8904_BIAS_CONTROL_0, WM8904_ISEL_HP_BIAS | WM8904_BIAS_ENA);
		wm8904_write_register(WM8904_POWER_MANAGEMENT_0, WM8904_INL_ENA | WM8904_INR_ENA);
		wm8904_write_register(WM8904_POWER_MANAGEMENT_2, WM8904_HPL_PGA_ENA | WM8904_HPR_PGA_ENA);
		wm8904_write_register(WM8904_DAC_DIGITAL_1, WM8904_DEEMPH(0));
		wm8904_write_register(WM8904_ANALOGUE_OUT12_ZC, 0x0000);
		wm8904_write_register(WM8904_CHARGE_PUMP_0, WM8904_CP_ENA);
		wm8904_write_register(WM8904_CLASS_W_0, WM8904_CP_DYN_PWR);
		wm8904_write_register(WM8904_FLL_CONTROL_1, 0x0000);
		wm8904_write_register(WM8904_FLL_CONTROL_2, WM8904_FLL_OUTDIV(7)|
								WM8904_FLL_FRATIO(4));
		wm8904_write_register(WM8904_FLL_CONTROL_3, WM8904_FLL_K(0x8000));
		wm8904_write_register(WM8904_FLL_CONTROL_4, WM8904_FLL_N(0xBB));
		wm8904_write_register(WM8904_FLL_CONTROL_1, WM8904_FLL_FRACN_ENA |
								WM8904_FLL_ENA);
		delay_ms(5);
		wm8904_write_register(WM8904_CLOCK_RATES_1, WM8904_CLK_SYS_RATE(3) |
								WM8904_SAMPLE_RATE(5));
		wm8904_write_register(WM8904_CLOCK_RATES_0, 0x0000);
		wm8904_write_register(WM8904_CLOCK_RATES_2,	WM8904_SYSCLK_SRC
							| WM8904_CLK_SYS_ENA | WM8904_CLK_DSP_ENA);
		wm8904_write_register(WM8904_AUDIO_INTERFACE_1, WM8904_BCLK_DIR |
								WM8904_AIF_WL_16BIT | WM8904_AIF_FMT_I2S);
		wm8904_write_register(WM8904_AUDIO_INTERFACE_2, WM8904_BCLK_DIV(8));
		wm8904_write_register(WM8904_AUDIO_INTERFACE_3, WM8904_LRCLK_DIR |
								WM8904_LRCLK_RATE(0x20));
		wm8904_write_register(WM8904_POWER_MANAGEMENT_6, WM8904_DACL_ENA |
								WM8904_DACR_ENA | WM8904_ADCL_ENA | WM8904_ADCR_ENA);
		delay_ms(5);
		wm8904_write_register(WM8904_ANALOGUE_LEFT_INPUT_0, WM8904_LIN_VOL(0x10));
		wm8904_write_register(WM8904_ANALOGUE_RIGHT_INPUT_0, WM8904_RIN_VOL(0x10));
		wm8904_write_register(WM8904_ANALOGUE_HP_0,
		WM8904_HPL_ENA | WM8904_HPR_ENA);
		WM8904_HPL_ENA_DLY | WM8904_HPL_ENA |
		WM8904_HPR_ENA_DLY | WM8904_HPR_ENA);
		wm8904_write_register(WM8904_DC_SERVO_0,
		WM8904_DCS_ENA_CHAN_3 | WM8904_DCS_ENA_CHAN_2 |
		WM8904_DCS_ENA_CHAN_1 | WM8904_DCS_ENA_CHAN_0);
		wm8904_write_register(WM8904_DC_SERVO_1,
		WM8904_DCS_TRIG_STARTUP_3 | WM8904_DCS_TRIG_STARTUP_2 |
		WM8904_DCS_TRIG_STARTUP_1 | WM8904_DCS_TRIG_STARTUP_0);
		delay_ms(100);
		WM8904_HPL_ENA_OUTP | WM8904_HPL_ENA_DLY | WM8904_HPL_ENA |
		WM8904_HPR_ENA_OUTP | WM8904_HPR_ENA_DLY | WM8904_HPR_ENA);
		WM8904_HPL_RMV_SHORT | WM8904_HPL_ENA_OUTP | WM8904_HPL_ENA_DLY | WM8904_HPL_ENA |
		WM8904_HPR_RMV_SHORT | WM8904_HPR_ENA_OUTP | WM8904_HPR_ENA_DLY | WM8904_HPR_ENA);
		wm8904_write_register(WM8904_ANALOGUE_OUT1_LEFT, WM8904_HPOUT_VU | WM8904_HPOUTL_VOL(0x39));
		wm8904_write_register(WM8904_ANALOGUE_OUT1_RIGHT, WM8904_HPOUT_VU | WM8904_HPOUTR_VOL(0x39));
		delay_ms(5);
		wm8904_write_register(WM8904_POWER_MANAGEMENT_0, WM8904_HPL_PGA_ENA | WM8904_HPR_PGA_ENA);
		wm8904_write_register(WM8904_POWER_MANAGEMENT_6, WM8904_DACL_ENA | WM8904_DACR_ENA | WM8904_ADCL_ENA | WM8904_ADCR_ENA);
		delay_ms(100);
		wm8904_write_register(WM8904_CLOCK_RATES_0, 0x845E);
		wm8904_write_register(WM8904_CLOCK_RATES_1,  WM8904_CLK_SYS_RATE(3) | WM8904_SAMPLE_RATE(5));
		wm8904_write_register(WM8904_CLOCK_RATES_2, WM8904_CLK_SYS_ENA | WM8904_CLK_DSP_ENA);
		wm8904_write_register(WM8904_AUDIO_INTERFACE_1, 0x0002);
		delay_ms(100);
		wm8904_write_register(WM8904_DAC_DIGITAL_1, 0x0000);
		wm8904_write_register(WM8904_ANALOGUE_LEFT_INPUT_0, WM8904_LIN_VOL(0x5));
		wm8904_write_register(WM8904_ANALOGUE_RIGHT_INPUT_0, WM8904_RIN_VOL(0x5));
		wm8904_write_register(WM8904_ANALOGUE_LEFT_INPUT_1, 0x0000);
		wm8904_write_register(WM8904_ANALOGUE_RIGHT_INPUT_1, 0x0000);
		delay_ms(100);
		wm8904_write_register(WM8904_ANALOGUE_OUT1_RIGHT, 0x00AD);
		wm8904_write_register(WM8904_DC_SERVO_0, WM8904_DCS_ENA_CHAN_1 | WM8904_DCS_ENA_CHAN_0);
		wm8904_write_register(WM8904_ANALOGUE_HP_0, 0x00FF);
		wm8904_write_register(WM8904_CLASS_W_0, 0x0005);
		delay_ms(100);
	/* Initialize the SAM system. */
	sysclk_init();
	board_init();
	/* Initialize the console UART. */
	configure_console();
	puts(STRING_HEADER);
	/* Initialize WM8904 TWI interface*/
	if (wm8904_twi_init() != TWIHS_SUCCESS) {
		printf("-E-\tWM8904 initialization failed.\r");
		while (1) {
			/* Capture error */
	/* Configure CODEC */
	configure_codec();
	/* Configure SSC */
	configure_ssc();
	/* Configure XDMA */
	configure_xdma();
	/* Enable the DAC master clock */
	pmc_disable_pck(PMC_PCK_2);
	pmc_pck_set_prescaler(PMC_PCK_2, PMC_MCKR_PRES_CLK_1);
		pmc_pck_set_source(PMC_PCK_2, PMC_MCKR_CSS_SLOW_CLK);
		pmc_pck_set_source(PMC_PCK_2, PMC_MCKR_CSS_MAIN_CLK);
	pmc_enable_pck(PMC_PCK_2);
	/* Start playing */
	delay_ms(300);
 /*This code makes the sscHandlerCount increase, but there is no waveform at codec output*/
/* 	 the interrupt does not happen with this code
	ssc_enable_interrupt(SSC, 0xFFFFFFFF); */
	NVIC_EnableIRQ(SSC_IRQn);*/
	ssc_enable_interrupt(SSC, 0xFFFFFFFF);*/
	ssc_enable_tx(SSC);
	xdmac_channel_enable(XDMAC, XDMA_CH_SSC_TX);
	while (1) {
/// @cond 0
/**INDENT-OFF**/
#ifdef __cplusplus
#endif
/**INDENT-ON**/
/// @endcond
fullspectrum wrote:
	sscHandlerCount ++;
Frank
#include <asf.h>
/// @cond 0
/**INDENT-OFF**/
#ifdef __cplusplus
extern "C" {
#endif
/**INDENT-ON**/
/// @endcond
	0,           0,
	1714, 		 1714,
	3425, 		 3425,
	5125, 		 5125,
	6812, 		 6812,
	8480, 		 8480,
	10125, 		 10125,
	11742, 		 11742,
	13327, 		 13327,
	14876, 		 14876,
	16383, 		 16383,
	17846, 		 17846,
	19260, 		 19260,
	20621, 		 20621,
	21925, 		 21925,
	23170, 		 23170,
	24350, 		 24350,
	25465, 		 25465,
	26509, 		 26509,
	27481, 		 27481,
	28377, 		 28377,
	29196, 		 29196,
	29934, 		 29934,
	30591, 		 30591,
	31163, 		 31163,
	31650, 		 31650,
	32051, 		 32051,
	32364, 		 32364,
	32587, 		 32587,
	32722, 		 32722,
	32767, 		 32767,
	32722, 		 32722,
	32587, 		 32587,
	32364, 		 32364,
	32051, 		 32051,
	31650, 		 31650,
	31163, 		 31163,
	30591, 		 30591,
	29934, 		 29934,
	29196, 		 29196,
	28377, 		 28377,
	27481, 		 27481,
	26509, 		 26509,
	25465, 		 25465,
	24350, 		 24350,
	23170, 		 23170,
	21925, 		 21925,
	20621, 		 20621,
	19260, 		 19260,
	17846, 		 17846,
	16383, 		 16383,
	14876, 		 14876,
	13327, 		 13327,
	11742, 		 11742,
	10125, 		 10125,
	8480, 		 8480,
	6812, 		 6812,
	5125, 		 5125,
	3425, 		 3425,
	1714, 		 1714,
	0, 		 0,
	-1715, 		 -1715,
	-3426, 		 -3426,
	-5126, 		 -5126,
	-6813, 		 -6813,
	-8481, 		 -8481,
	-10126, 	 -10126,
	-11743, 	 -11743,
	-13328, 	 -13328,
	-14877, 	 -14877,
	-16384, 	 -16384,
	-17847, 	 -17847,
	-19261, 	 -19261,
	-20622, 	 -20622,
	-21926, 	 -21926,
	-23171, 	 -23171,
	-24351, 	 -24351,
	-25466, 	 -25466,
	-26510, 	 -26510,
	-27482, 	 -27482,
	-28378, 	 -28378,
	-29197, 	 -29197,
	-29935, 	 -29935,
	-30592, 	 -30592,
	-31164, 	 -31164,
	-31651, 	 -31651,
	-32052, 	 -32052,
	-32365, 	 -32365,
	-32588, 	 -32588,
	-32723, 	 -32723,
	-32768, 	 -32768,
	-32723, 	 -32723,
	-32588, 	 -32588,
	-32365, 	 -32365,
	-32052, 	 -32052,
	-31651, 	 -31651,
	-31164, 	 -31164,
	-30592, 	 -30592,
	-29935, 	 -29935,
	-29197, 	 -29197,
	-28378, 	 -28378,
	-27482, 	 -27482,
	-26510, 	 -26510,
	-25466, 	 -25466,
	-24351, 	 -24351,
	-23171, 	 -23171,
	-21926, 	 -21926,
	-20622, 	 -20622,
	-19261, 	 -19261,
	-17847, 	 -17847,
	-16384, 	 -16384,
	-14877, 	 -14877,
	-13328, 	 -13328,
	-11743, 	 -11743,
	-10126, 	 -10126,
	-8481, 		 -8481,
	-6813, 		 -6813,
	-5126, 		 -5126,
	-3426, 		 -3426,
	-1715, 		 -1715
	sscHandlerCount ++;
	/* Reset SSC */
	ssc_reset(SSC);
	uint16_t *src;
	uint8_t i;
								| XDMAC_CC_PERID(32);
	uint16_t data = 0;
		while(1);
		delay_ms(5);
								WM8904_FLL_ENA);
		delay_ms(5);
		delay_ms(5);
		delay_ms(100);
		delay_ms(5);
		delay_ms(100);
		delay_ms(100);
		delay_ms(100);
		delay_ms(100);
	sysclk_init();
	board_init();
		while (1) {
			/* Capture error */
	configure_codec();
	/* Configure SSC */
	configure_ssc();
	configure_xdma();
	/* Start playing */
	delay_ms(300);
	ssc_enable_tx(SSC);
	while (1) {
/// @cond 0
/**INDENT-OFF**/
#ifdef __cplusplus
#endif
/**INDENT-ON**/
/// @endcond
https aka ms remoteconnect
Hello sumoxo ,
I did not notice your post until today.
I made some progress. I have my SSC_Handler running with  sscHandlerCount increasing and audio being produced.
I get a sinewave of 870Hz on each channel. I have a bump that repeats after every 4 full cycles of the sine wave. I took out all the DMA code.
The ISR is firing at 92.4kHz. I suspect that the code that generates the clock frequency would need to be revised because the SAMPLE_RATE in the code is 48000.  The   if(PCK2 == PMC_MCKR_CSS_SLOW_CLK) evaluates to true, so it is the first section of the coded in {} before the else that is used.
I changed the ssc_enable_interrupt  line to ssc_enable_interrupt(SSC,SSC_IER_TXRDY);
 * The code toggles the Arduino D7 GPII pin. It produceds a 46.2kHz square wave. That means that the ISR is firing at 92.4kHz.
   A sine waveform of 780Hz is produced)
* Support and FAQ: visit <a href="http://www.atmel.com/design-support/">Atmel Support</a>
#include <asf.h>
#include "ioport.h"
/// @cond 0
/**INDENT-OFF**/
#ifdef __cplusplus
extern "C" {
#endif
/**INDENT-ON**/
/// @endcond
uint16_t indexAudioSample;
static uint16_t AudioBuffer[240]=
	0,           0,
	1714, 		 1714,
	3425, 		 3425,
	5125, 		 5125,
	6812, 		 6812,
	8480, 		 8480,
	10125, 		 10125,
	11742, 		 11742,
	13327, 		 13327,
	14876, 		 14876,
	16383, 		 16383,
	17846, 		 17846,
	19260, 		 19260,
	20621, 		 20621,
	21925, 		 21925,
	23170, 		 23170,
	24350, 		 24350,
	25465, 		 25465,
	26509, 		 26509,
	27481, 		 27481,
	28377, 		 28377,
	29196, 		 29196,
	29934, 		 29934,
	30591, 		 30591,
	31163, 		 31163,
	31650, 		 31650,
	32051, 		 32051,
	32364, 		 32364,
	32587, 		 32587,
	32722, 		 32722,
	32767, 		 32767,
	32722, 		 32722,
	32587, 		 32587,
	32364, 		 32364,
	32051, 		 32051,
	31650, 		 31650,
	31163, 		 31163,
	30591, 		 30591,
	29934, 		 29934,
	29196, 		 29196,
	28377, 		 28377,
	27481, 		 27481,
	26509, 		 26509,
	25465, 		 25465,
	24350, 		 24350,
	23170, 		 23170,
	21925, 		 21925,
	20621, 		 20621,
	19260, 		 19260,
	17846, 		 17846,
	16383, 		 16383,
	14876, 		 14876,
	13327, 		 13327,
	11742, 		 11742,
	10125, 		 10125,
	8480, 		 8480,
	6812, 		 6812,
	5125, 		 5125,
	3425, 		 3425,
	1714, 		 1714,
	0, 		 0,
	-1715, 		 -1715,
	-3426, 		 -3426,
	-5126, 		 -5126,
	-6813, 		 -6813,
	-8481, 		 -8481,
	-10126, 	 -10126,
	-11743, 	 -11743,
	-13328, 	 -13328,
	-14877, 	 -14877,
	-16384, 	 -16384,
	-17847, 	 -17847,
	-19261, 	 -19261,
	-20622, 	 -20622,
	-21926, 	 -21926,
	-23171, 	 -23171,
	-24351, 	 -24351,
	-25466, 	 -25466,
	-26510, 	 -26510,
	-27482, 	 -27482,
	-28378, 	 -28378,
	-29197, 	 -29197,
	-29935, 	 -29935,
	-30592, 	 -30592,
	-31164, 	 -31164,
	-31651, 	 -31651,
	-32052, 	 -32052,
	-32365, 	 -32365,
	-32588, 	 -32588,
	-32723, 	 -32723,
	-32768, 	 -32768,
	-32723, 	 -32723,
	-32588, 	 -32588,
	-32365, 	 -32365,
	-32052, 	 -32052,
	-31651, 	 -31651,
	-31164, 	 -31164,
	-30592, 	 -30592,
	-29935, 	 -29935,
	-29197, 	 -29197,
	-28378, 	 -28378,
	-27482, 	 -27482,
	-26510, 	 -26510,
	-25466, 	 -25466,
	-24351, 	 -24351,
	-23171, 	 -23171,
	-21926, 	 -21926,
	-20622, 	 -20622,
	-19261, 	 -19261,
	-17847, 	 -17847,
	-16384, 	 -16384,
	-14877, 	 -14877,
	-13328, 	 -13328,
	-11743, 	 -11743,
	-10126, 	 -10126,
	-8481, 		 -8481,
	-6813, 		 -6813,
	-5126, 		 -5126,
	-3426, 		 -3426,
	-1715, 		 -1715
/*	@brief convert voltage to codec value
	@param voltage voltage
uint16_t voltageToCode(float voltage){
	const float codePerVolts = 32768/1.30/1.050 ;
	return voltage * codePerVolts;
/*	@brief Handler for DMA
/*	@brief Handler ISR for I2S codec
	@params none
	uint16_t sample;
	sscHandlerCount ++; /*interrupt is happening at 92kHz*/
	sample = AudioBuffer[indexAudioSample];
	indexAudioSample++;
	if (indexAudioSample > (sizeof AudioBuffer) /(sizeof AudioBuffer[0])){
		indexAudioSample=0;
	SSC->SSC_THR = sample; /*data to send stereo codec*/
	indexAudioSample++;
		indexAudioSample=0;
	gpio_toggle_pin(PIO_PA2_IDX);
	NVIC_ClearPendingIRQ(SSC_IRQn);
	/* Reset SSC */
	ssc_reset(SSC);
	uint16_t data = 0;
		while(1);
		delay_ms(5);
								WM8904_FLL_ENA);
		delay_ms(5);
		delay_ms(5);
		delay_ms(100);
		delay_ms(5);
		delay_ms(100);
		delay_ms(100);
		delay_ms(100);
		delay_ms(100);
/*	@brief main
	sysclk_init();
	board_init();
	/*PIO_PA2*/
	ioport_set_pin_dir(PIO_PA2_IDX, IOPORT_DIR_OUTPUT);
	ioport_toggle_pin_level(PIO_PA2_IDX);
		while (1) {
			/* Capture error */
	indexAudioSample = 0;
	configure_codec();
	/* Configure SSC */
	configure_ssc();
	/* Start playing */
	delay_ms(300);
	/*ssc_enable_interrupt(SSC, 0xFFFFFFFF);  */
	/*https://community.atmel.com/forum/sam4s-using-end-transmission-interrupt*/
	/*ssc_enable_interrupt(SSC,SSC_IER_ENDXRDY);*/
	/*SSC_IER_TXEMPTY*/
	ssc_disable_interrupt(SSC,0xFFFFFFFF);
	/* ssc_enable_interrupt(SSC,SSC_IER_TXEMPTY); it is too late when TXEMPTY is fired. must use TXRDY*/
	ssc_enable_tx(SSC);
	/*xdmac_channel_enable(XDMAC, XDMA_CH_SSC_TX);*/
	while (1) {
/// @cond 0
/**INDENT-OFF**/
#ifdef __cplusplus
#endif
/**INDENT-ON**/
/// @endcond
Hello sumoso,
I got an email from the system saying you edited something here. I don't see what is different in your post. I am still working on I2s.
 * This code does an audio loopback using interrupt on SSC. It toggles the PIO_PA2_IDX = Arduino D7 GPIO pin. It produces a 46.2kHz square wave. That means that the ISR is firing at 92.4kHz.
   When using transmitAudioBuffer with the look up table containing a sine wave, the codec DAC makes is a small bump every 4 cycles of the sine wave.
   This code is based from two examples:
   https://github.com/avrxml/asf/blob/master/sam/components/audio/codec/wm8904/example/wm8904_example.c
   and
#include <asf.h>
#include "ioport.h"
/// @cond 0
/**INDENT-OFF**/
#ifdef __cplusplus
extern "C" {
#endif
/**INDENT-ON**/
/// @endcond
uint16_t indexTransmitAudioSample;
uint16_t indexReceiveAudioSample;
volatile static uint16_t receiveAudioBuffer[240];
static uint16_t transmitAudioBuffer[240]=
	0,           0,
	1714, 		 1714,
	3425, 		 3425,
	5125, 		 5125,
	6812, 		 6812,
	8480, 		 8480,
	10125, 		 10125,
	11742, 		 11742,
	13327, 		 13327,
	14876, 		 14876,
	16383, 		 16383,
	17846, 		 17846,
	19260, 		 19260,
	20621, 		 20621,
	21925, 		 21925,
	23170, 		 23170,
	24350, 		 24350,
	25465, 		 25465,
	26509, 		 26509,
	27481, 		 27481,
	28377, 		 28377,
	29196, 		 29196,
	29934, 		 29934,
	30591, 		 30591,
	31163, 		 31163,
	31650, 		 31650,
	32051, 		 32051,
	32364, 		 32364,
	32587, 		 32587,
	32722, 		 32722,
	32767, 		 32767,
	32722, 		 32722,
	32587, 		 32587,
	32364, 		 32364,
	32051, 		 32051,
	31650, 		 31650,
	31163, 		 31163,
	30591, 		 30591,
	29934, 		 29934,
	29196, 		 29196,
	28377, 		 28377,
	27481, 		 27481,
	26509, 		 26509,
	25465, 		 25465,
	24350, 		 24350,
	23170, 		 23170,
	21925, 		 21925,
	20621, 		 20621,
	19260, 		 19260,
	17846, 		 17846,
	16383, 		 16383,
	14876, 		 14876,
	13327, 		 13327,
	11742, 		 11742,
	10125, 		 10125,
	8480, 		 8480,
	6812, 		 6812,
	5125, 		 5125,
	3425, 		 3425,
	1714, 		 1714,
	0, 		 0,
	-1715, 		 -1715,
	-3426, 		 -3426,
	-5126, 		 -5126,
	-6813, 		 -6813,
	-8481, 		 -8481,
	-10126, 	 -10126,
	-11743, 	 -11743,
	-13328, 	 -13328,
	-14877, 	 -14877,
	-16384, 	 -16384,
	-17847, 	 -17847,
	-19261, 	 -19261,
	-20622, 	 -20622,
	-21926, 	 -21926,
	-23171, 	 -23171,
	-24351, 	 -24351,
	-25466, 	 -25466,
	-26510, 	 -26510,
	-27482, 	 -27482,
	-28378, 	 -28378,
	-29197, 	 -29197,
	-29935, 	 -29935,
	-30592, 	 -30592,
	-31164, 	 -31164,
	-31651, 	 -31651,
	-32052, 	 -32052,
	-32365, 	 -32365,
	-32588, 	 -32588,
	-32723, 	 -32723,
	-32768, 	 -32768,
	-32723, 	 -32723,
	-32588, 	 -32588,
	-32365, 	 -32365,
	-32052, 	 -32052,
	-31651, 	 -31651,
	-31164, 	 -31164,
	-30592, 	 -30592,
	-29935, 	 -29935,
	-29197, 	 -29197,
	-28378, 	 -28378,
	-27482, 	 -27482,
	-26510, 	 -26510,
	-25466, 	 -25466,
	-24351, 	 -24351,
	-23171, 	 -23171,
	-21926, 	 -21926,
	-20622, 	 -20622,
	-19261, 	 -19261,
	-17847, 	 -17847,
	-16384, 	 -16384,
	-14877, 	 -14877,
	-13328, 	 -13328,
	-11743, 	 -11743,
	-10126, 	 -10126,
	-8481, 		 -8481,
	-6813, 		 -6813,
	-5126, 		 -5126,
	-3426, 		 -3426,
	-1715, 		 -1715
	@params none 9 9this handlers is firing every 16 bits, not every 2 x 16 bits as it should.
	uint16_t sample;
	/*SSC_RHR Receive Holding Register*/
	sample = SSC->SSC_RHR;
	receiveAudioBuffer[indexReceiveAudioSample] = sample;
	indexTransmitAudioSample++;
	if (indexTransmitAudioSample >= (sizeof transmitAudioBuffer) /(sizeof transmitAudioBuffer[0])){
		indexTransmitAudioSample = 0;
	indexReceiveAudioSample++;
	if (indexReceiveAudioSample >= (sizeof receiveAudioBuffer) /(sizeof receiveAudioBuffer[0])){
		indexReceiveAudioSample = 0;
	 /*SSC->SSC_THR = transmitAudioBuffer[indexTransmitAudioSample]/2;*/  /*data to send stereo codec*/
	/*sample = SSC->SSC_RHR;*/
		indexTransmitAudioSample=0;
	/* SSC->SSC_THR =  transmitAudioBuffer[indexTransmitAudioSample]/2; */ /*data to send stereo codec*/
	 /*SSC->SSC_THR = 0xAAFF; */
	clock_opt_t tx_clk_option, rx_clk_option;
	data_frame_opt_t tx_data_frame_option, rx_data_frame_option;
	/* Reset SSC */
	ssc_reset(SSC);
	tx_clk_option.ul_sttdly = SSC_TCMR_STTDLY(1);
	tx_clk_option.ul_period = SSC_TCMR_PERIOD(0);
	tx_data_frame_option.ul_fslen = SLOT_BY_FRAME - 1;
	/* Configure the SSC transmitter to I2S mode. */
	/* Receiver clock mode configuration. */
	rx_clk_option.ul_cks = SSC_RCMR_CKS_TK;
	rx_clk_option.ul_cko = SSC_RCMR_CKO_NONE;
	rx_clk_option.ul_cki = SSC_RCMR_CKI;
	rx_clk_option.ul_ckg = SSC_RCMR_CKG_CONTINUOUS;
	rx_clk_option.ul_start_sel = SSC_RCMR_START_RF_EDGE;
	rx_clk_option.ul_sttdly = SSC_RCMR_STTDLY(1);
	rx_clk_option.ul_period = SSC_RCMR_PERIOD(0);
	/* Receiver frame mode configuration. */
	rx_data_frame_option.ul_datlen = BITS_BY_SLOT - 1;
	rx_data_frame_option.ul_msbf = SSC_RFMR_MSBF;
	rx_data_frame_option.ul_datnb = 0;
	rx_data_frame_option.ul_fslen = SLOT_BY_FRAME - 1;
	rx_data_frame_option.ul_fslen_ext = 0;
	rx_data_frame_option.ul_fsos = SSC_TFMR_FSOS_NONE;
	rx_data_frame_option.ul_fsedge = SSC_TFMR_FSEDGE_POSITIVE;
	ssc_set_receiver(SSC, &rx_clk_option, &rx_data_frame_option);
	ssc_disable_rx(SSC);
	uint16_t data = 0;
		while(1);
	delay_ms(5);
	wm8904_write_register(WM8904_ANALOGUE_OUT12_ZC, 0x0000); /*think this is analog loop back. nothing is enabled.*/
	wm8904_write_register(WM8904_FLL_CONTROL_2, WM8904_FLL_OUTDIV(7)| WM8904_FLL_FRATIO(4));
	wm8904_write_register(WM8904_FLL_CONTROL_1, WM8904_FLL_FRACN_ENA | WM8904_FLL_ENA);
	delay_ms(5);
	wm8904_write_register(WM8904_CLOCK_RATES_2,	WM8904_SYSCLK_SRC | WM8904_CLK_SYS_ENA | WM8904_CLK_DSP_ENA);
	wm8904_write_register(WM8904_AUDIO_INTERFACE_1, WM8904_BCLK_DIR | WM8904_AIF_FMT_I2S);
	wm8904_write_register(WM8904_AUDIO_INTERFACE_3, WM8904_LRCLK_DIR | WM8904_LRCLK_RATE(0x20));
	wm8904_write_register(WM8904_POWER_MANAGEMENT_6,	WM8904_DACL_ENA | WM8904_DACR_ENA |	WM8904_ADCL_ENA | WM8904_ADCR_ENA);/*DAC and ADC enable*/
	delay_ms(5);
	wm8904_write_register(WM8904_ANALOGUE_LEFT_INPUT_0, WM8904_LIN_VOL(0x10)); /*left input volume.  */
	wm8904_write_register(WM8904_ANALOGUE_RIGHT_INPUT_0, WM8904_RIN_VOL(0x10)); /*right input volume.  */
	wm8904_write_register(WM8904_ANALOGUE_HP_0,	WM8904_HPL_ENA | WM8904_HPR_ENA);
	wm8904_write_register(WM8904_ANALOGUE_HP_0,	WM8904_HPL_ENA_DLY | WM8904_HPL_ENA |	WM8904_HPR_ENA_DLY | WM8904_HPR_ENA);
	wm8904_write_register(WM8904_DC_SERVO_0,	WM8904_DCS_ENA_CHAN_3 | WM8904_DCS_ENA_CHAN_2 |	WM8904_DCS_ENA_CHAN_1 | WM8904_DCS_ENA_CHAN_0);
	wm8904_write_register(WM8904_DC_SERVO_1,	WM8904_DCS_TRIG_STARTUP_3 | WM8904_DCS_TRIG_STARTUP_2 |	WM8904_DCS_TRIG_STARTUP_1 | WM8904_DCS_TRIG_STARTUP_0);
	delay_ms(100);
	wm8904_write_register(WM8904_ANALOGUE_HP_0,	WM8904_HPL_ENA_OUTP | WM8904_HPL_ENA_DLY | WM8904_HPL_ENA |	WM8904_HPR_ENA_OUTP | WM8904_HPR_ENA_DLY | WM8904_HPR_ENA);
	wm8904_write_register(WM8904_ANALOGUE_HP_0,	WM8904_HPL_RMV_SHORT | WM8904_HPL_ENA_OUTP | WM8904_HPL_ENA_DLY | WM8904_HPL_ENA |	WM8904_HPR_RMV_SHORT | WM8904_HPR_ENA_OUTP | WM8904_HPR_ENA_DLY | WM8904_HPR_ENA);
	wm8904_write_register(WM8904_ANALOGUE_OUT1_LEFT, WM8904_HPOUT_VU | WM8904_HPOUTL_VOL(0x39)); /*output volume on left*/
	wm8904_write_register(WM8904_ANALOGUE_OUT1_RIGHT, WM8904_HPOUT_VU | WM8904_HPOUTR_VOL(0x39));/*output volume on right*/
	delay_ms(100);
/*	@brief main
	sysclk_init();
	board_init();
	/*PIO_PA2*/
		while (1) {
			/* Capture error */
	configure_codec();
	/* Configure SSC */
	configure_ssc();
	/* Start playing */
	delay_ms(300);
	/*ssc_enable_interrupt(SSC,SSC_IER_TXEMPTY); it is too late when TXEMPTY is fired. must use TXRDY*/
	ssc_enable_tx(SSC);
	ssc_enable_rx(SSC);
	/*xdmac_channel_enable(XDMAC, XDMA_CH_SSC_TX); Do not use XDMAX. */
	while (1) {
		delay_ms(100);
/// @cond 0
/**INDENT-OFF**/
#ifdef __cplusplus
#endif
/**INDENT-ON**/
/// @endcond
I put my last code here. It makes one interrupt by sample using the SSC interrupt, not the XDMAC interrupt.
fullspectrum wrote:
Hello sumoso,
There is (now?) a spam link right at the end of the post
frown
Hello awneil,
I noticed. It says something about minecraft. I did not click on it. I hope this doesn't become : don't think of an elephant - oops, we just did.
Minecraft link removed.
Moderator
