pointer to array of strings
13 posts / 0 new
typedef struct
    const char *title;
    const WHAT items;
    const uint8_t itemsCount;
} myType;
myType a =
    "AVR FREAKS",
    WHAT,
    2
doSomething(a.items[1]);
"items" should point to a constant array of constant strings. For example, an array which contains "Hello!" and "How are you?". So "doSomething()" will get "How are you?" as parameter.
I tried many pointer configurations but always get an error or "initialization from incompatible pointer type [-Wincompatible-pointer-types]" warning.
Please save me from pointer headache! crying
Slow and Steady!
Not enough context. (for example what is "WHAT" ?)
But if this about const pointers to const data remember there are three ways to make const pointers:
const type * p1;
type * const p2;
const type * const p3;
p1 is a pointer to an item of type that is const
p2 is a const pointer to an item of type
p3 is a const pointer to an item of type that is const.
Or is the question really about what the implied type of literal string constants are? Like exactly what type is "AVR Freaks" ?
This is a standard 'C' question, and it's quite common to have arrays of strings.
So have you tried a 'C' textbook? or just google "pointer to array of strings" ...
clawson wrote:
what is "WHAT" ?
I wish I'd known! This is my question.
Luckily I know this one. "AVR FREAKS" is a null-terminated constant char array. smiley
I tried. They say: "This is your array. So assign pointer to &array. Easy as a pie!"
But I have to implement pointer type manually.
Oh; as usual, I forgot to mention something. blush
String constants may (if needed) be limited to 19 characters (excluding final '\0').
Slow and Steady!
See: http://c-faq.com/decl/constptrco...
No, I'm sure they don't say that.
See: http://c-faq.com/aryptr/index.html
Go on.
Very first hit in that google search: https://overiq.com/c-programming-101/array-of-pointers-to-strings-in-c
char *sports[] = {
                     "golf",
                     "hockey",
                     "football",
                     "cricket",
                     "shooting"
isn't that exactly what you want?
Again, this is standard 'C' stuff , so you can easily experiment with it on a PC - much easier than on a small microcontroller!
Use the PC debugger to see the pointer, the pointer value, and what the pointer points to ...
Probably what you are looking for-
https://godbolt.org/z/hv4PjK
Your WHAT is a [const char** const]- a pointer to a (constant char pointer) that is constant. The added const just prevents modifying the pointer to the const char*, but you probably never get that far (but doesn't hurt).
There is a lot of const going on, and some of it redundant. With some experimenting, you can figure out the details of what is going on and where the const may be required/wanted/not wanted.
Not much different to curtvm example,  i would tend to define the struct without the members themselves as const (just what the pointer members are pointing to), but then you can make myType a itself const
const char * const what[] = {"hello", "how are you"};
typedef struct
    const char *title;
    const char * const *items;
    uint8_t count;
} myType;
const myType a =
    "AVR FREAKS",
    what,
    sizeof(what) / sizeof(what[0])
    printf("a.title %s\n", a.title);
    for (uint8_t i = 0; i < a.count; i++)
        printf("a.item[%d] %s\n", i, a.items[i]);
If they are "strings" can I suggest __flash/PROGMEM ? (no point wasting RAM with these things and unlike ARM (and, admittedly, the most recent AVRs) just "const" does not necessarily guarantee "only hold in flash")
I think this is more or less what OP wants:
#include<stdint.h>
#include<stdio.h>
typedef const char * const str_array[];
//typedef str_array* str_array_ptr; // pointer type easy way
typedef const char * const (* str_array_ptr)[]; // pointer type hard way
typedef struct
  const char *title;
  const str_array_ptr items;
} myType;
str_array my_items = {"item_1", "item_2", "item_3", "item_4"};
myType a =
  "AVR FREAKS",
  &my_items,
  4
int main(int argc, char *argv[]) {
  puts(a.title);
  for (int i = 0; i < a.itemsCount; i++) {
    puts((*(a.items))[i]); // Sorry for so many parenthesis, but I can't be bothered to learn precedence order between . * and []
  return 0;
Finally, I did it this way:
typedef struct
	const char *title;\
	const char ** items;
} myType;
const char* _items[] = { "Hello!", "How are you?" };
myType _start =
	"AVR FREAKS",
	_items,
	2
doSomething(myType.Items[1]);
Slow and Steady!
note that names beginning with an underscore are reserved for system use - you should not be naming your own symbols with a leading underscore.
Good point. Thanks.
Slow and Steady!
