Can GCC plug-in defaults be customized?
6 posts / 0 new
Is it possible to customize the default settings of the GCC plug-in? For example, I would like to set up a default include file folder (among other things). Is there a makefile template or some such that could be editted to do that for each new project?
Probably not. If there was we would have discovered / heard of it when discussing that the Studio defaults to -O0 and does not link in libm.a by default.
Thanks for letting me know. I think I can work something out by creating a default AVR Studio project ("default.aps"). The .aps file is in XML format and I found I could hand-edit it to fine tune it. After copying it to the new project location I just needed to replace all occurences of "default" with my actual project name. I might automate that with a sed script or something.
You can also generate an external makefile using either AVRStudio or Mfile from WinAVR. Then you have access to all of make's abilities.
Stu
With AVRStudio 4.13 (Build 577), I got rid of -O0. It now defaults to -os, which is much better.
There is a "trick" you can do. If you have a project already loaded in Studio when you create a new GCC project it inherits all the current settings, not the defaults. So just make sure you have a -Os/libm.a project loaded before you create the new one.
