codeblocks, gcc-avr, linux mint... need advice on getting these working on my computer!
12 posts / 0 new
hello, its been almost 10 years since I've written any C code for AVR processors.
I am running the Linux Mint operating system. It has CodeBlocks installed, along with
avr-gcc. I opened an old program I wrote years ago, and got an error message saying that
io.h could not be found. In the past, I used a static build for a compiler I downloaded from a l
ink on this site, with a makefile and compiled using the "make" command. this worked well,
but my eyes aren't so good anymore and I want to set uo a gui based toolchain to write code with.
P.S..... my dog stole my wife, shot up my trailer with an AK-47, and set me on fire :>)
Welcome back.
Might I suggest you look at Microchips MPLAB as it runs on Linux, and it now supports AVRs!!
Microchip bought Atmel and integrated the AVR line into MPLAB.
Might be easier than trying to roll you own GUI.
AND MPLAB supports Atmels Debugging tools like the ICE, and other tools
Thanxx, will check it out!
at a command line try
sudo apt-get install make git gcc-avr binutils-avr gdb-avr avr-libc avrdude
that should get a toolchain, but who knows what Mint will have (is it from Ubuntu or Debian now?).
Or there's platformIO
Amplifying Ron's comment: io.h is considered part of "avr-libc", and you won't have it if you ONLY installed avr-gcc.
Perhaps more "stable" way to get a Linux toolchain is:
https://www.microchip.com/mplab/...
But either Arduino or MPLABX should deliver something "solid".
(the problem with apt-get's from a repo is that you don't know the provenance of the build - it could have been done well by someone who really knows what they are doing or it might be something cobbled togethr).
thanks, Ron. this got me going again. 10 minutes from download to a successful flash of a 90S2313.
Thanks to everyone else who replied, Going to explore all suggestions, looking foreward to becoming
proficient with MCUs again!
AVR debugging has been restored to PlatformIO via a FOSS AVR simulator (simavr)
Microchip's AVR simulator has a form in Linux.
Tools & Debug Probes | Debugging — PlatformIO 5.0.2b2 documentation
Debugging | Atmel AVR — PlatformIO 5.0.2b2 documentation
http://packs.download.atmel.com/#collapse-Atmel-ATtiny-DFP-pdsc
<DFP>/simulator/linux64
in .pdsc :
                  <at:property name="com.atmel.avrdbg.tool.simulator.key" value="ATtiny2313A"/>
                  <at:property name="com.atmel.avrdbg.tool.simulator.model.win32" value="simulator/win32/libattiny4313.dll"/>
                  <at:property name="com.atmel.avrdbg.tool.simulator.model.linux64" value="simulator/linux64/libattiny4313.so"/>
On Debain the packages can be checked, for example
https://packages.debian.org/sid/avr-libc
takes us to
https://qa.debian.org/developer.php?login=hakan%40debian.org
https://qa.debian.org/cgi-bin/vcswatch?package=avr-libc
https://salsa.debian.org/debian/avr-libc
I have no idea what Mint is doing, but I know it is based on Debian (once or twice removed); Ubuntu packages use to be from Debian, but some are snaps now, and those are a matter of trusting the packager. For example, I trust that "sudo apt-get install code" is OK, it is done by Microsoft and installs VSCode, but other than that and the snaps Ubuntu does, I avoid them. I can audit the Debian packages much better, and their packages have a history that I can look over.
A point I note using code:blocks on mint 19.3 Cinnamon (64-bit x86) - it's about as stable as a very very wobbly thing. Interesting effects I've noticed recently include
  • randomly shutting down without warning (and without saving edited files)
  • opening existing files showing a blank page
  • trying to open files showing an empty file select box rather than the expected directory
  • debug working if it feels like it, but sometimes just claiming that the debug window has been closed before it's even opened
That said, I do prefer CB to anything with eclipse in it which while it has a much better debug interface (apart from anything else, CB's interface defaults to decimal values for variables requires each variable to be configured as hex, which is promptly forgotten next time you need it) it's an absolute octopus in that bits of it seem to get stuck all over the OS, and it ends up not working with itself for various reasons - at the moment I have a System Workbench for STM32 which works fine, but an x86 dev configuration won't even start...
Neil
