OC Pins [ATmega32, ATmega32L]
5 posts / 0 new
Hey Guys,
I have a short question, because I could not find an answer in the datasheet (it is probably somewhere in the datasheet but I could not find it).
Where do I find (address in IO-Space) the OC Pin ? I could not find the OC Pin in the register summary of the IO memory.
And is it possible to configure the OC Pin so that instead another pin toggles when matching with OCR ? (probably not).
By the way: I am talking about the 8-bit timer (timer0) of the ATmega32(L).
Thank you.
I think I found the answer. It seems to be PINB3 for the 8-bit timer0.
Now there is only question left :) Is it possible to switch to another pin or is it always PINB3 for timer0 ?
AFAIK, all the "older" AVRs have single unchangeable outputs for the time OCxy outputs.  It's not until the xMega and Mega0 that you start to see multiple options.
The OC pins are all fixed but if you want the output elsewhere do "soft PWM"...
It'll be in the appropriate PORT register
Indeed:
Please mark the solution - see Tip #5 in my signature, below:
