I am trying to use Interrupts for serial communication with ATMEGA4809 Xplained pro evaluation board. For example I want to get this LED control example to work by using the USART1 rx interrupt vector to fill the buffer whenever data is available via serial input. ISR(USART1_RXC_vect) is never called though, when I send serial messages to the board.
const char const help_str[] = "Type on/off to control LED \r\n"; const char const ledon_str[] = "LED is on\r\n"; const char const ledoff_str[] = "LED is off\r\n"; int help(void) { printf(help_str); return 0; } int Turn_on_LED(void) { USER_LED_set_level(false); printf(ledon_str); return 0; } int Turn_off_LED(void) { USER_LED_set_level(true); printf(ledoff_str); return 0; } int parseCmd(char *commands) { char *cmds = NULL; if ((cmds = strstr(commands, "help"))) { help(); } else if ((cmds = strstr(commands, "on"))) { Turn_on_LED(); } else if ((cmds = strstr(commands, "off"))) { Turn_off_LED(); } if (cmds != NULL) { return 1; } else { return 0; } } char buf[5] = {0}; uint8_t buf_pos = 0; int main(void) { /* Initializes MCU, drivers and middleware */ atmel_start_init(); // Enable pin change IRQ PORTB.PIN2CTRL |= PORT_ISC_BOTHEDGES_gc; parseCmd("help\0"); // Print out instructions while (1) { if (parseCmd(buf) || (buf_pos > 4)) { buf[0] = 0; buf_pos = 0; } } } ISR(USART1_RXC_vect){ buf[buf_pos] = USART1.RXDATAL; buf_pos++; buf[buf_pos] = 0; //} }
The example works just fine when I use this function provided by AtmelStudio, only that this is blocking the while(1) loop, which I can not use for my project.
uint8_t USART_0_read() { while (!(USART1.STATUS & USART_RXCIF_bm)) ; return USART1.RXDATAL; }
What am I missing?
Thanks a lot in advance
