JTAG ice MK2 not working with PDI?
10 posts / 0 new
Just repaired my JTAG ice MK2, the power switch was broken.
Trying to program a Xmega32E5 but I get this error:
The ICE was upgraded to the latest firmware (well unintentionally, wanted to keep it for AS4.18 sad)
It works OK with DW and ISP.
The reason why I wanted to use it is because it DOESN'T lock up the mouse like the JTAG Ice MK3 or the Atmel ice does.
pardon?
Get a cat.
I was intrigued.  So I plugged the JTAG-2 ISP/PDI/dW adapter into the Xplained board.   And got the same error messages as you.
However,  the X32E5 works fine with SNAP,  PickKit4, ATMEL-ICE, Dragon, ...
I suspect that the JTAG-2 has fallen off the Microchip AS7.0 radar.
Note that the SNAP requires the hardware mod for PDI.
pardon?
It's a know fact that some mice do not play well with AS7 and the JTAG Mk3 and the Atmel ICE.
I just had to program 1 board and I thought I'd use the MK2 instead as it doesn't suffer from the lock up instead of replacing the mouse just for the exercise, which I ended doing anyway.
Yet it shows up in the list of debuggers if a new project is started.
Sure you have the DATA pin wired to the right place?  (Unlike Atmel-ICE I think DATA is on JTAG-TDI and not TDO?)
Yes, I have made few thousands of this board. I'm using the standard MK2 interface cables so if it is a different pin then I may need a custom crossover cable??
Also I note that the clock speed adjustment slider is not available on the Mk2 as it is available on the Mk3.
I plugged the regular JTAGICE-2 JTAG_to_ISP adapter into the X32E5 PDI header.   So I am using the official ISP / PDI / dW 3x2 pinout.
And the Adapter works fine with ISP on a mega328P
Maybe time to get the "OCTOPUS" cable out..... cheeky after breakfast that is.
So it's a lot later than breakfast time sad but I could not find the octopus cable, it is probably attached to some board somewhere.
I used 4 jumper cables to connect the board to the Mk2 according to the help file and it works.
So the solution is to either
1) Make a 10 way to 6 way cable similar to the ISP dongle but using the correct pins as hinted in #5.
2) Use the squid cable
3) Use jumper cables (male to female) from the JTAG connector to the 6 pin PDI connector.
OR read the Friendly manual blushblush
I soldered a 5x2 and a 3x2 onto a scrap of Protoboard.    Connected the appropriate PDI pins.   And now have a working JTAGICE-2 PDI Adapter.
Thanks mraardvark
Thanks Mr Samperi.
Mind you,   the SNAP is a lot smaller and faster.   And has a micro USB socket.
