resident self-hosted debugger for Cortex-M ?
7 posts / 0 new
Is there a resident (or "self-hosted") debugger that runs on Cortex-M CPUs?   Something that could reside in flash, and works like CP/M's DDT or MSDOS "debug"?
Is such a thing possible (I think it should be)?  It would be acceptable if the program being debugged had to be resident in RAM...
You mean like an old-school debug monitor?
Something like this:  https://github.com/adamgreen/mri ?
If 8051s could do it, I don't see why a Cortex-M shouldn't ...
Yes.
That probably contains a bunch of useful bits and pieces, but it seems to be designed to interact with gdb on a host ("gdb-stub" or maybe "semi-hosting"?), while I want something that interacts with a dumb terminal.
Well, there was a generation or two of microcontrollers that pretty much decided that debugging should only work with an external debugger - no single-step mode, no breakpoint instruction that worked "internally", and of course no writable program memory (not without great difficulty, anyway.)  AFAIK, neither the 8bit PICs nor AVRs are capable of supporting a resident debugger of the sort I'm looking for...
Cortex-M has a bunch of debug features, but it's difficult to skim the documentation and figure our which ones work in a standalone fashion, and which interact only with an external debugger.  For example, the BKPT instruction says:
  • A DebugMonitor exception. If Halting debug is disabled and the DebugMonitor exception is enabled, a debug event causes a DebugMonitor exception when the group priority of the DebugMonitor exception is greater than the current execution priority.
    Halting debug is disabled when the DHCSR.C_DEBUGEN bit is set to 0 or disabled by the Debug authentication interface, see Debug Halting Control and Status Register, DHCSR on page C1-700 and Debug authentication on page C1-688, and the DebugMonitor exception is enabled when the DEMCR.MON_EN bit is set to 1, see Debug Exception and Monitor Control Register, DEMCR on page C1-706.
Dunno if you're still looking into this, but I've just been tidying up some papers and come across these:
Cortex-M4 Monitor Mode:  https://www.mikrocontroller.net/topic/396104
Vector Catch:  https://www.keil.com/support/docs/3782.htm
You might also want to look at Segger's "Monitor Mode Debug":
https://www.segger.com/products/debug-probes/j-link/technology/monitor-mode-debugging/
the part of that which goes in the J-Link is proprietary & closed, but you do get to see the bit which goes on the Target ...
Dunno if you're still looking at this, but I just came across this:
https://interrupt.memfault.com/blog/cortex-m-debug-monitor
Thanks.  that looks relatively distant from what I was hoping for (still relies on gdb for UI?), but there's a lot of useful explanation there!
I don't think it relies on it - I think he's just using that as an example that will be familiar to his readership?
The article does refer somewhere to using a simple terminal interface  ...
Anyhow, glad there was some useful stuff in it
