USB Protocol Analyser
22 posts / 0 new
Can anyone recommend a USB protocol analyser?
I have here a USB controlled 'thing'. It comes with windows/macos/android software packages to control it via USB. My aim is to be able to embed this into a vehicle using a suitable embedded board to control it. Using a PC/Mac/Phone to control it is not an option. The goal is to be able to operate it with just a couple of buttons.
I don't know how intelligent the unit is. So I need to find out if a) it's dumb and all the cleverness is done on the host and the USB is transferring low level commands or b) it's clever and the USB is transferring high level 'macro' commands or 'this button has been pushed' commands.
So I *think* I need to sniff, and decode, the USB to see what's going on.
USB Protocol Analyzer | AVR Freaks
P.S.
Is AVR Freaks an echo chamber? wink
edit :
Oh!  'z' instead of 's'.
P.S.
edit :
OUCH!!
But I was thinking that we had read this request elsewhere......
JIm
Total votes: 3
But if you guys can't spell correctly it's hardly my fault! cheeky
I've not used their USB analysers, but their others were OK:
https://www.totalphase.com/proto...
EDIT
oh - they've already been mentioned in the other thread.
blush
Brian Fairchild wrote:
It comes with windows/macos/android software packages to control it via USB. ...
May be able to sniff WinUSB.
Capturing USB Debug Traces - Microsoft Tech Community - 270840
Here it seems to take a neutral opinion of the spelling:
https://en.wikipedia.org/wiki/An...
Collins Dictionary notes that 'analyser' is a British spelling, and 'analyzer' is USA:
https://www.collinsdictionary.co...
When I type 'analyser' in a google search bar, the first thing that pops up is the translator.....FRENCH to ENGLISH!
So, it would appear that it's more a matter of local taste than anything else.
It's been a while since I did any Android programming, but I think developer mode has an option for USB logging.
For low-speed devices, a cheap FX2-based logic analyzer will do the trick.
https://github.com/cpldcpu/u-wir...
My Saleae logic analyser(analyzer) can do USB Low Speed, and Full speed.  Not sure what version of USB Brian is going after though....
and Brian clearly has good taste ...
cheeky
At work we have an Ellisys analyzer( antique so not going to go for the number as it will no longer be manufactured), the one we have needs a laptop, but perhaps they in the mean time also made standalone models.
Back in the day when we wanted to do some USB sniffing we simply used one of the equipment hire companies to rent a high end device. Obviously it depends on how long you think the requirement for USB analysis will be and there's a trade-off between hire and purchase cost but for a quick job, to get access to the very best equipment then hiring can be a "better" option.
ZEROPLUS logic analyzers have USB protocol decoders for apparently packets at low, full, and high-speed (2Gsps logic analyzer for high-speed)
Review of Zeroplus LAP-C Logic Analyzer by Jack Ganssle
USB 1.1 | Logic Analyzers-Zeroplus
USB 2.0 | Logic Analyzers-Zeroplus
ZEROPLUS Logic Cube LAP-C(322000) - sigrok
edit :
LAP-C - How to analyze USB 1.1 protocol (En) - YouTube (2m41s)
Thanks for all the suggestions.
It looks like the unit is a lot more intelligent than I hoped which means the only way to control it is likely to be from a PC of some sort.
Time to investigate embedded PCs.
Most obvious of which is Rpi perhaps?
... is likely to be from a PC of some sort.
Relative to current consumption, Android has automotive use cases.
Your preferred local or regional distributor may have these in stock.
Raspberry Pi 4 can run Windows 10; driver availability is a concern plus its current consumption.
Windows 10 IoT Core can run on Raspberry Pi 2 or 3; headless, or, one foreground application (window)
Suggested Prototype Boards - Windows IoT | Microsoft Docs
I wouldn't have thought the RPi was particularly power-hungry relative to other embedded PCs capable of running Win10 ?
Of course, other small embedded Linux boards/modules & boxed units are available ...
https://www.avrfreaks.net/forum/embedded-linux-modules
Yea, both are in that electrical power range.
A sample size of one :
VIA_AMOS-3006_datasheet_v200218-1880006.pdf
Power Supply 9~30V DC-in (typical: 19W)
Operating System Windows 10/8.1/8/7, Win 10 IoT, WES 7, Linux
via AMOS-3006 Embedded System - VIA | Mouser
edit :
DA-1000 Series User's Manual
[page 15, top right]
• Power Consumption Typical 8.3W, Max.15W
via Cincoze Rugged Ultra Compact Fanless Computer | OnLogic
I really ought to buy a Pi just to see what they can do.
Turns out that the Android version, because it's designed to run primarily on phones, is cut down and doesn't have the required functionality.
Driver appears to be using libusbK so I need to investigate that. Current consumption isn't a problem.
Must be Windows (or MacOS, but I'm not going there).
Basically a desktop Linux PC that's about the size of a credit card and costs £20+
Rent, Lease, or Buy Electronic Test Equipment? Here's How to Decide | Electronic Design
by Amanda Wilson
OCT 07, 2020
Evolving technology, certifications, and time are just some of the points to consider before renting, leasing, or buying that next piece of equipment.
