Getting info to a log file
14 posts / 0 new
I am using -finstrument-functions to log function entry/exit to a circular buffer that can be analyzed when a certain condition is detected.
My issue is that it is quite tedious to look up all the function address/offset (function & call site) for each call to see what the calling sequence was.
What I would like to do is be able to somehow write the contents of a 2x15 array to a text file and then I can write a program to consume that and the symbol table to print out a 'human readable' calling sequence.
Or .. has this been done before by someone using finstrument-functions to profile code, etc. and thus there may be some tools available that do this or can be adapted?  Or possibly debugger scripting that I don't know about that would loop through the array and decode function addresses and offsets?
Do you mean you want the target to do this, or the debugger/IDE to do it?
If the target is a small AVR, it might be easier to dump to the serial port, and capture that with something on a PC ...
"Easy" approach would be to add FatFs for an SD/MMC on the SPI  and just write to a file.
The "Instrument" stuff in GCC is obviously intended for a hosted OS where opening and writing files is trivial so you want something like that.
Alternatively use FDEV_SETUP_STREAM to set up a "file" that really streams data to a uart_putchar() and use that then capture the traffic in a PC terminal.
Where a CSV comma separated values format is easy to capture and display in a SS.
Keys to wealth:
I'm reading two problems here:
1) log data to a file
2) decoding data from a file to generate function and/or line number info
For (2) the programs avr-nm and avr-objdump can extract a lot of information from the .elf file.  Maybe start with "avr-objdump --help".
I've been know to attach a bluetooth serial module to the UART in projects which aren't amenable to being tethered to a PC. Doesn't require any code changes; in fact it's completely invisible to the microcontroller.
Unless you're the British govt capturing covid infection statistics.
What would you expect from NHS!
Keys to wealth:
Total votes: 2
I am going to issue just ONE warning.  The political/government derails are not going to be tolerated.
Jim - Moderator
fyi, Python is likely with GDB.
Python (Debugging with GDB)
re 2, addr2line given program counter values.
Toolchain Overview | AVR Libc
[mid-page]
avr-addr2line
Convert addresses to file and line.
addr2line (GNU Binary Utilities) due to Generating Unique Error Codes | The Embedded Muse 306 by Jack Ganssle
Just a technical point. It's an outsourced company run by an ex jockey (no really) who screwed statistics. Meanwhile NHS is a national treasure as far as 99.9% of Brits are concerned.
Cmon Cliff....
Here's a write-up on this from The DailyWTF https://thedailywtf.com/articles/excellent-data-gathering The comments are worth reading also.
Total votes: 2
Guys, back on track please! NHS discussions can go somewhere else wink
:: Morten
