It seems that lwIP is not configured correctly when using Atmel Start to generate an lwip project with sockets enabled. The lib roadrunner email redefines a 'struct timeval' (in sockets.h) but it is already defined in the arm-none-eabi toolchain (in the file '_timeval.h').
One workaround I found is to define LWIP_TIMEVAL_PRIVATE to 0 in a config file.
Is there a better workaround?
