ATMEGA162 will not self-program (nothing no page erase nada)
7 posts / 0 new
I'm a veteran AVR Freak who uses self-programming in the smaller tiny's without hickup.
Now I move into a 162 and want to self program using the BSL. Set the BSL to 0x1C00 (0xE00 word) for powerup.
If I say to erase a page at 0x0000 byte address then read the address back, it remains whatever it was. I set the page to 00's or 69's or anything and it's always what it was :-(.
Has anyone seen this issue? I'm running INTRC at 8 Mhz, 3.3v. I even tried 5v and slowing down the INTRC to the slowest (writing OSCCAL to 0x00).
Here's an example of a page-erase from page 226 of the ATMEGA162/V manual (2513F-AVR-12/03)
ldi a, (1<<PGERS) | (1<<SPMEN)
out SPMCR, a
spm
ret
I did copy the "DoSPM" routine to check first if the SPMEN was busy but it doesn't make a difference.
BSL mode is enable with bootup to 0x1C00 as explained above.
Any insight??
Regards
lock bits?
nope. they are clear in unlocked position. I'm ready to try the mega8515 to see if I have similar problems.
thx!
Regards
Are you writing FROM the bootloader section?
(SPM only works from the bls, I don't know much about tiny's, but maybe most of them don't have bls and can SPM from anywhere)
Dang it! I got it guys.
Thanks CurtVm!
I was placing code at 0xE00 word thinking 0x1C00 was byte address.
So, code por is 0x1C00 WORD not byte. So darn confusing!!!
Somehow chip still powered up when I stuck the code at 0xE00. I guess 0xFFFF is a nop and PC wrapped around and hit my code start.
lol!
Regards
Even when you know about it, the word/byte thing can get you messed up sometimes.
At least the SPM problem pointed you in the right direction.
Yep, I can't believe they got me. I guess I was thinking 8k when I was dealing with 16k.
Regards
