I have been having a problem with a breadboard I had made. I thought I specified to the PCB assembler to use Atmega328p-AU-TQFP32 chips, but out of 10, they seem to be Atmega328-AU-TQFP32 parts. While I think I can live... my old Arduino IDE (don't remember the rev) wouldn't download to them as an 8MhZ 3.3V part, because it said the signature was 0x1E9514. AVRDude via AVRDudess was saying the same. I was about to futz with boards.txt to fix this when I decided I hadn't upgraded my Arduino IDE in a while, and I should do this before making changes to boards.txt with batch files that changed things back and forth between different boards.txt, etc.
When I upgraded to IDE v1.8.13 (on Windows 10 Home), I tried to upload to my board, and IT WORKED. It says the signature is the 328p (0x1E950F). What? AVRDudess still says it's 0x1E9514. While I'm elated I don't have to mod boards.txt, what gives? Am I on crack?
Here's my uploading output:
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Jeff Long\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino14/etc/avrdude.conf"
Using Port : COM5
Using Programmer : arduino
Overriding Baud Rate : 57600
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\JEFFLO~1\AppData\Local\Temp\arduino_build_317201/blink.ino.hex"
avrdude: writing flash (2142 bytes):
Writing | ################################################## | 100% 1.07s
avrdude: 2142 bytes of flash written
avrdude: verifying flash memory against C:\Users\JEFFLO~1\AppData\Local\Temp\arduino_build_317201/blink.ino.hex:
avrdude: load data flash data from input file C:\Users\JEFFLO~1\AppData\Local\Temp\arduino_build_317201/blink.ino.hex:
avrdude: input file C:\Users\JEFFLO~1\AppData\Local\Temp\arduino_build_317201/blink.ino.hex contains 2142 bytes
Reading | ################################################## | 100% 0.91s
avrdude: verifying ...
avrdude: 2142 bytes of flash verified
avrdude done. Thank you.
