ATtiny1616 -> ADC0 Window Comparator Int won't fire
5 posts / 0 new
Been on this one two hours now and still a no-go. ADC is using 0.55v ref, channel is correct, global ints enabled. I've give it a very low WINHT value just to be sure it'll be well within the firing range.
int8_t ADC0_Initialize()
    //DUTYCYC DUTY50;
    ADC0.CALIB = 0x00;
    //SAMPNUM ACC1;
    ADC0.CTRLB = 0x00;
    //SAMPCAP disabled; REFSEL INTREF; PRESC DIV256;
    ADC0.CTRLC = 0x07;
    //INITDLY DLY0; ASDV ASVOFF; SAMPDLY 0;
    ADC0.CTRLD = 0x00;
    //WINCM ABOVE;
    ADC0.CTRLE = 0x02;
    //DBGRUN enabled;
    ADC0.DBGCTRL = 0x01;
    //STARTEI disabled;
    ADC0.EVCTRL = 0x00;
    //WCMP enabled; RESRDY disabled;
    ADC0.INTCTRL = 0x02;
    //MUXPOS AIN10;
    ADC0.MUXPOS = 0x0A;
    //SAMPLEN 31;
    ADC0.SAMPCTRL = 0x1F;
    // Window comparator high threshold
    ADC0.WINHT = 0x38;
    // Window comparator low threshold
    ADC0.WINLT = 0x00;
    //RUNSTBY enabled; RESSEL 8BIT; FREERUN enabled; ENABLE enabled;
    ADC0.CTRLA = 0x87;
    return 0;
ISR(ADC0_WCOMP_vect) {
    hvDetected = 1;
    ADC_DISABLE;
    ADC_CLEARINT;
Breakpoint on the ISR and start the ADC (freerunning mode)
ADC0.CTRLA |= ADC_ENABLE_bm;
ADC0.COMMAND = ADC_STCONV_bm
With an Aref = 0.55v and a WINHT = 56 (0x38), the pin would need to have a voltage less than 0.03v to be IN the window, then I would assume a voltage over that would trigger the interrupt.
So what is the voltage right at the pin of the ADC input?
I would test this using Aref=VCC and a WINHT of say $1ff (or mid range).
Then have a pull down resistor on the pin and jumper in with vcc to trigger a test.
Isn't there something in the 0/1 errata supplement about something not triggering off of something else?... sounds vaguely familiar.
Apologies for my delay, juggling tasks.
I'll take a look. It's set to 'auto-trigger' repeatedly but is clocked of TMRA.
Measuring ~0.2v at the pin.
Alright it's firing. I'm being burned by MPLABX like usual, it's frequently crashing and making a mess of indicating when breakpoints have been hit.
