TCNT1 simulation problems
2 posts / 0 new
Hello
When i try to simulate a program which uses TCNT1 I found with problems in the registers, for example, ICR never is refreshed, i know this is not a problem with my program because it enters in the interrupt function properly
Another problem that i detect is that the timer doesn´t changes its value in the simulated register, instead the value of OCCR1A changes as it was the timer counter.
If someone has a update of that of has a solution it will be really apreciated
Sounds like someone hasn't read the "Known Issues" section of the simulator help file before using it and then assuming that it simulates everything perfectly. It doesn't.
