ATtiny1616 -> Releasing WOx from TMRD
12 posts / 0 new
Pin PC1 I have set as an output. As this is is also controlled by TCD I've ensured the FAULTCTRL register for that pin is disabled.
TCD0.FAULTCTRL = 0;
PORTC.DIRSET = 1 << 1;
I noticed there is only 2.1v at the pin and a scope showed that the pin has not been released from TMRD (I have a 2MHz 50% duty going). Microchip stated in a support ticket that is can be released for general IO usage?
Cheers,
Andrew
Protected register This is not accessible.
TCD0.FAULTCTRL = 0;
Please try this.
_PROTECTED_WRITE (TCD0.FAULTCTRL, 0);
Found it, another MCC bug. ON reset it uses the FUSES value. Unsure why but from what I'm seeing it overrides the FAULTCTRL values (which makes me wonder if I can turn any on after setting FUSES.TCD0CFG to 0 but that would then make FAULTCTRL truly pointless).
FUSES =
    .APPEND = 0,
    .BODCFG = ACTIVE_SAMPLED_gc | LVL_BODLEVEL7_gc | SAMPFREQ_1KHZ_gc | SLEEP_ENABLED_gc,
    .BOOTEND = 0,
    .OSCCFG = FREQSEL_20MHZ_gc,
    .SYSCFG0 = CRCSRC_NOCRC_gc | RSTPINCFG_UPDI_gc,
    .SYSCFG1 = SUT_64MS_gc,
    .TCD0CFG = FUSE_CMPAEN_bm | FUSE_CMPBEN_bm | FUSE_CMPCEN_bm | FUSE_CMPDEN_bm,
    .WDTCFG = PERIOD_OFF_gc | WINDOW_OFF_gc,
Please read the data sheet carefully.
.TCD0CFG is only loaded at boot time.
Subsequent changes are at your disposal.
_PROTECTED_WRITE
That'll be it, 22.3.7. Wish they'd mentioned it in main 22.3.2.7 Output Control section, until you mentioned it I didn't know it existed!
Also MCC isn't using _PROTECTED_WRITE (so this is the bug), if it had I'd have caught it.
N/A
The existence of _PROTECTED_WRITE is to guarantee the cycle.
Otherwise no one will use it.
I have never been betrayed by _PROTECTED_WRITE.
I've confirmed it, this doesn't work.
    _PROTECTED_WRITE(TCD0.FAULTCTRL, TCD0.FAULTCTRL | TCD_CMPAEN_bm);
    _PROTECTED_WRITE(TCD0.FAULTCTRL, TCD0.FAULTCTRL | TCD_CMPBEN_bm);
    _PROTECTED_WRITE(TCD0.FAULTCTRL, TCD0.FAULTCTRL | TCD_CMPCEN_bm);
Also tried
    uint8_t v = TCD_CMPAEN_bm | TCD_CMPBEN_bm | TCD_CMPCEN_bm;
    CPU_CCP = CCP_IOREG_gc;
    TCD0.FAULTCTRL = v;
So far I'm unable to override the FUSE set values.
I have found however if I change the FAULTCTRL before initialising they work. Afterwards turning TCD0 off and on doesn't apply the new values.
    TCD0_Initialize();
    TCD0.CTRLA &= ~TCD_ENABLE_bm;
    TCD0.FAULTCTRL = TCD_CMPAEN_bm | TCD_CMPBEN_bm | TCD_CMPCEN_bm;
    TCD0.CTRLA |= TCD_ENABLE_bm;
I don't know what's going on with you.
My device is obedient to change.
It's the ordering of the STATUS bit, I didn't realise there were sync patterns to look at. That's the second time in the datasheet one section has made no reference to another critical section.
Are you using a simulator? It would explain why it's working there but not on chip.
This works.  :)
    TCD0.CTRLA &= ~(TCD_ENABLE_bm);
    while(!(TCD0.STATUS & TCD_ENRDY_bm)); // must wait here
    TCD0.CTRLA |= (TCD_ENABLE_bm);
# 9 is not a simulator.
I confirmed using a real tiny1616.
Strange, yours didn't work for me as the status check is in the wrong place. TCD0.CTRLA enable bit is unprotected.
