Newbie question: Enable interrupt on port
9 posts / 0 new
I am new to programming microcontrollers so forgive me my ignorance.
I have a XMEGA16E5 with some switches on port A and some LEDs on portC. I would like to control the status of the LEDs using the switches using interrupts. See my program below. For some reason unknown to me the interrupt routine is not called when I change one of the switches. What am I doing wrong?
#include <avr/sleep.h>
#include <avr/wdt.h>
#include <avr/pgmspace.h>
#include <avr/interrupt.h>
#include <util/delay.h>
	// Configure PORTA, The port is used to set the board id using  switches  11100001
	PORTA_DIR = 0x00;				// configure port A for input
	PORTCFG_MPCMASK=0xE1;				// configure bits 11100001 at the same time
	PORTA_PIN0CTRL = PORT_ISC_BOTHEDGES_gc|  PORT_OPC_PULLUP_gc;
	PORTA_INTCTRL=PORT_INTLVL_MED_gc;       	//Medium level interrupt
	PORTCFG_MPCMASK=0x0;				// Should i reset the mask?
	PORTC_DIR = 0xf0;				// Configure PORTC for output: pin 4-7 (LEDs) and input: pin 0-3 (Analog inputs)
	PORTC_OUT = 0x00;				// set the pns low
	PORTC_PIN0CTRL = 0x18;
	PORTC_PIN1CTRL = 0x18;
	PORTC_PIN2CTRL = 0x18;
	PORTC_PIN3CTRL = 0x18;
PORTC_OUT=0x80;						// set a LED on to make sure PortC is working as expected
	PMIC.CTRL |= PMIC_MEDLVLEX_bm;		        // Enabled medium level interrupts
	sei();						// enable interrupts
    while (1)
ISR(PORTA_INT_vect)
	static unsigned char tog=0;
	tog = !tog;
	if (tog) PORTC_OUT=0x10;			// set a led and disable the others
	PORTC_OUT=0x20;					// set a different led and disable the others
because switches bounce this is never a great idea unless your circuitry has hardware debouncing.
The usual approach is to poll the button states in a timer interrupt so that debouncing can be applied.
The interrupt mask setting is missing.
PORTA.INTMASK = 0xE1;
And the interrupt flag is not automatically released, so please do it yourself.
Thank you both for the replies. I got it working!
I would have never considered bouncing without you bringing it up. Is it an option to add a delay of 1 ms to the interrupt routine to take bouncing into account? I can rewrite it to a polling mechanism. The switches are used to set an address. I think this happens only once or twice in the life time of the board so it would be a waste of time to have the board poll the switches on a regular basis.
So just stop the polling once you're done with the switches?
The place to start is always the Product Page - there you will find the datasheet, Application Notes, examples, etc, etc:
whence:
AN_8050 - AVR1313: Using the XMEGA IO Pins and External Interrupts
AN_8043 - AVR1305: using the XMEGA Interrupts and the Programmable Multi-level Interrupt Controller
it'd worth spending some time browsing what's available ...
AswinB wrote:
I got it working!
Please see Tip #5 in my signature, below, for how to mark the solution:
Here is an example using int6 pin on AVR ( I use Atmega128 ):
Do not forget sei(); (enable global interrupt)
Important: The pin needs  a pullup resistor
Ellen
void init_INT6(void) //INT6 init function
    EICRB = 1 << ISC60 | 1 << ISC61; //trigger off the rising edge of INT6
    EIMSK = 0b01000000; //enable INT6 interrupt
// interruptservice routine:
ISR(INT6_vect)
cnt++;
#ifdef ISROut
  PORTA = cnt;
 _delay_ms(510);
#endif
// using:
#ifdef ISROut
    init_INT6();
#endif
sei();
Senior electrical engineer
Well a couple of things:
1) 1ms is nowhere near long enough and
2) NEVER put deliberate delays in ISRs
In the AVR (apart from later Xmega derivatives) the CPU will be "locked" while in an ISR - nothing else can occur - so other events can be missed. So an ISR should be "in" and "out" in microseconds so it does not disrupt anything else going on. Putting misllisec9ond delays in ISR (even just 1ms) is a very, very poor design.
The way to do buttons with interrupts is to set up a timer interrupt that also tracks button input activity. Only when a button has been seen in the same state for a number of subsequent interrupts (maybe every 4ms or something?) should you consider the button settled into a new state. This has been discussed many, many times here, the search term "Ganssle" should hit most of the threads. As you'll see there are two common solutions usually proposed. While some people will use Lee Theuch's solution I'm guessing the one from Peter Dannegger is probably the one most people go with. So I'd search that out and use it.
Thanks all. I discarded the idea of using interrupts in this case. I now use a polling mechanism. I poll every 10mSec and only use the port reading if it is constant for at least two iterations. Thinks do work.
One note. I do read the datasheets and all the application notes I can find but these documents are overwelming for a starter like me. And, if I hadn't asked I would never have been aware of bouncing.
