random float generator
45 posts / 0 new
Guys, I'm havin' a little bit of trouble generating a random float.  The function is as follows:
float random_weight(void){
	return rand()/RAND_MAX*(float)(2.0) - 1.0;
The output is as follows:
-0.999992
-0.999979
-0.999991
-0.999973
-0.999971
-0.999971
-0.999972
-0.999990
-0.999973
-0.999976
-0.999994
-0.999979
-0.999982
-0.999987
-0.999978
-0.999993
-0.999985
-0.999998
-0.999997
-0.999985
-0.999973
-0.999978
-0.999973
I'm thinking that it maybe to do with RAND_MAX!
EDITED: I'm trying to generate a float between -1.0 and 1.0
I'm amazed you don't get  -1.000000  all the time with the code shown.
rand()/RAND_MAX is integer division, so always 0 (unless rand() == RAND_MAX).
It doesn't get converted to float in this case until you do the multiply by 2.0
You want something more like
        float f = (float)rand() / RAND_MAX * 2.0f - 1.0f;
Thanks for the reply MrKendo.  I still get the same results.  I'm going to try generating a integer then make that into a float!
You haven't shown how you're printing it.
And you do understand that rand() is not random - don't you...?
In that case, either your rand() function isn't the C standard library function (or if you're using C++, don't know in that case), or you aren't showing all that you are doing.
Well, if it's the C standard library function, it's pseudo-random of course.
It may not be very good, and certainly not to be used for cryptographic functions, but with all due respect to OP, if you're creating your own cryptographic functions, good luck with that :)
That's one case where you really don't want to be rolling your own.
There's something you are not telling us. And no, there's no way the code you presented in your original message could generate the values you listed, as MrKendo correctly noted. The code you posted is not the code you are running. Unless you provide a more representative example of what's going on in your code, there's no way to say why you still get the same results.
Note BTW, that the granularity of the floating-point values generated by using this method might be too "sparse" for some purposes (depending on the implementation of `rand()`, specifically on its range).
Dessine-moi un mouton
Total votes: 3
I would debug incrementally.
First, return rand()
Then return rand()/RAND_MAX
and so forth
Yes, I know that there are precedence and promotion rules and all that, but to be totally unambiguous, I would write
( (float)rand()/(float)RAND_MAX )
It costs your compiled code nothing. And it saves you in situations like this.
Okay lads, thanks for the feedback, I have the following working.
	int temp = rand() % 10000;
	temp = temp - 5000;
	return (float)temp / 5000;
I would like to increase the resolution but when I add more zero's it prints out garbage again.
As you have a habit of posting Cortex A questions is this Cortex A with a hosting OS? If so it should have a /dev/rand or similar that is fed entropy from things luke Ethernet traffic, mouse movement and so on.
So generate single digit random numbers, 0 - 9, and concatenate them together.
(Note that the save caveats about randomness apply)
Do you have access to the C++ standard library (C++11 or later)? If so, it provides tools for doing exactly what you want.
#include <iostream>
#include <random>
int main()
    auto generator = std::mt19937_64 { std::random_device {}() };
    auto distribution = std::uniform_real_distribution<double> { -1.0, 1.0 };
    for ( auto i = 0; i < 10; ++i ) {
        std::cout << distribution( generator ) << '\n';
    } // for
Output:
0.384381
0.183115
0.634574
-0.103687
0.740283
-0.187781
-0.577465
-0.968228
0.162683
-0.0512241
github.com/apcountryman/build-avr-gcc: a script for building avr-gcc
github.com/apcountryman/toolchain-avr-gcc: a CMake toolchain for cross compiling for the Atmel AVR family of microcontrollers
#include <iostream>
#include <random>
int main()
    } // for
Output:
0.384381
0.183115
0.634574
-0.103687
0.740283
-0.187781
-0.577465
-0.968228
0.162683
-0.0512241
Looks good, I'll have a blast at that tomorrow..
Thanks guys for the feedback.
Okay, I really like the c plus-plus version, however it keeps spitting out the same float.  My code is as follows:
 * random_nr.cpp
 *  Created on: 22 Jun 2020
 *      Author: wmjen
#include <random>
#include "random_nr.h"
using namespace std;
float random_weight_(void)
    auto distribution = std::uniform_real_distribution<float> { -1.0, 1.0 };
    return(distribution( generator ));
and the header file is as follows:
 * random_nr.h
 *      Author: wmjen
#ifndef APPLICATIONS_NEURAL_NETWORK_RANDOM_NR_H_
#define APPLICATIONS_NEURAL_NETWORK_RANDOM_NR_H_
 #ifdef __cplusplus
 #define EXTERNC extern "C"
 #else
 #define EXTERNC
 #endif
	EXTERNC float random_weight_(void);
#endif /* APPLICATIONS_NEURAL_NETWORK_RANDOM_NR_H_ */
And the function call is:
	float test = 0;
	for(int i = 0; i < 50; i++){
		float temp = random_weight_();
		if(temp > 0)
			c_printf("\n\r[b]%f", temp);
			c_printf("\n\r[r]%f", temp);
		if(temp > test)
			test = temp;
	c_printf("\n\r[g]%f", test);
Any suggestions folks?
PS: thanks for looking.
RNGs need seeding with entropy. Do you have a source of entropy?
You are re-initialising generator and distribution on each function call. Make them static.
float random_weight_pp (void)
    static auto generator = std::mt19937_64{ std::random_device {}() };
    static auto distribution = std::uniform_real_distribution<double>{ -1.0, 1.0 };
    return (float)distribution(generator);
C:\Users\Nigel\Documents\Visual Studio 2017\Projects\The_freak\Debug>The_Freak
-0.149776
-0.223296
0.053717
-0.428489
-0.747919
0.841155
0.690961
0.226924
0.920388
0.482196
-0.096723
-0.871745
0.601442
0.801830
0.693042
0.324156
0.977126
0.592106
-0.620074
-0.734697
 Note to self: An interesting function - must read about this sometime.
N.Winterbottom wrote:
entropy
Hi M.Winterbottom, that correction now gives random numbers, however they are now the same results when I reboot the system.  As clawson says, I need to have entropy? maybe my c plus-plus is not setup correctly!
That'll be a "No", then.
General question.... If you have a float width of, say, 32 bits, and generate a random bit stream which you truncate into 32 bit chunks. Can you simply use that value as if it were a float?
I'm aware of the concept of NAN but havent looked into how a compiler like GCC formats floats and whether there are any invalid codes.
Using a physical source would make for much better random numbers.
Brian,
Interesting question. You can kind of "try that out a bit" if you use something like:
https://www.h-schmidt.net/FloatConverter/IEEE754.html
If you type any 8 digit (possibly leading 0 padded) hex value into the "Hexadecimal representation" box it will show you how that is interpreted as a float.
As you say there are "special" values like NaN and Inf but apart from those I *think* most 32 bit values are valid.
EDIT: for example with 0xDEADBEEF...
Ah I see it even supports the "special values":
The possible implication of that is that all other 32 bit patterns are valid float ?
Cliff,
No. From that link, any number 0b 0 1111111 1xxx... is infinity if all the remaining x are 0, but NaN if *any* of the x are 1.
So it looks like - at least on that interpretation - that any 32-bit value is a valid float unless the top nine bits are ones, or the top bit is zero and the next eight are ones. So there's a 2/512 chance you're going to get either a NaN (most likely) or a +/- infinity. But easily fixed by trapping those values out.
Neil
But that's hardly a truly random number because there are more discrete floating point numbers between 0 & 1 than exist in the rest of the FP range. This will skew the distribution significantly.
Of the 32 bit float maybe keep the first 9 bits unchanging and just vary the last 23 then?
Generate a random integer in the range -2**24..2**24 .
Multiply by 2**-24 .
All values will be exactly representable.
Note that including both endpoints requires 2**25+1 possible integers.
I do not know the requirements of neural net code.
Is this really being done on an AVR?
Do you really want it non-repeatable?
Non-repeatability is a primary source of debugging hell.
While it is true that the distribution will be skewed, I don't see why it is "hardly a truly random number". The term "random number" never implies uniform distribution. There's no uniform distribution requirement for the number to be "truly random". The only reason we are assuming uniform distribution in this case is because it follows from the original example.
In any case, properties of IEEE754 floating point representation make it impossible to generate a uniformly distributed floating-point value in the full range of the type, simply because the "stepping" changes constantly as we move away from 0. Uniform distribution is only possible if you keep the exponent fixed.
Isn't there a Martin Gardner "absurdity" in one of his books that describes something along these lines...
A perfect random generator over time would have a uniform spread of samples over the range but if a random system had such a uniform spread then it would be predictable and therefore not "random". As such random does not exist!
(must dig out the books (/ or google?) to remind myself of the actual argument)
Ahhh, the great Martin Gardner. For a  long time, HE was the  reason I read "Scientific American".
Certainly. Arguments like that are often misunderstood and therefore misquoted, which sometimes is the only source of perceived absurdity.
One can argue that, if one takes a random number generator, tests it and confirms that it is indeed a random number generator, then it is not random anymore. Since anything that behaves as expected is not truly random. It probably makes a nice philosophical sophism/paradox/joke, but definitely falls outside the scope of this topic.
Jesus lads, only need a random number, not a feckin' philosophical lecture.  Anyway, I found method to seed/srand he system.  See below for the c version and the c plus-plus version.
float random_weight_ (void){
	char sys_time[3];
	sys_time[0] = NMEA_GPRMC.UTC_Time[6];
	sys_time[1] = NMEA_GPRMC.UTC_Time[7];
	sys_time[2] = NMEA_GPRMC.UTC_Time['\0'];
	static char seed = 0;
    // include entropy into the random number generator
    generator.seed(kernel_core.kernel_stamp + seed++ + atoi(&sys_time[0]));
	char sys_time[3];
	srand(kernel_core.kernel_stamp + seed++ + atoi(&sys_time[0]));
	temp = temp - 5000;
However, when I ported the routines into the RTOS it spits out garbage, see below:
-2.000002
-0.000000
-0.000000
-0.000000
-2.000002
-2.000002
2.681562e+154
-2.000000
2.681564e+154
0.000000
-0.000000
0.000000
0.000000
Is there a clue in the numbers generated???/
What exactly is this line supposed to do?
And again, as you have been told already, `srand`-ing the generator before each request for a random number is a bad idea. This will easily lead to the same time value used in multiple contiguous calls and therefore the same "random" number produced by `rand()`.
Yes.
You have at least one bug in code you haven't shown.
Hi AndreyT, yes, that was an error, it should have read:
sys_time[2] = '\0';
Any how, the same garbage comes up, this only occurs when in he kernel.  I have tried omitting the "srand" and "seed" without joy.
PS: to avoid srand generating the same seed and therefore duplicating a number I have the varible seed that increments each call.
Okay, multiplying the random float by 1000,000 gives the following:
-1711960928
2005088530
-569786299
2128868656
154183397
-1251323615
-1664280325
-872690152
126657474
422168523
1183936932
1803007741
c_printf("\n\r[b]%i", random_weight_() * 1000000);
	char sys_time[3];
	sys_time[2] = '\0';
    generator.seed((int)kernel_core.kernel_stamp + seed++ + atoi(&sys_time[0]));
    static auto distribution = std::uniform_real_distribution<float>{ -1.0, 1.0 };
random_weight_ returns float, multiplying that by 1000000 means it is still float, but you are printing with %i .
In C, this is undefined behaviour. I Imagine it's not good in C++ either but I'm not familiar with C++ rules.
Going back to the C version, why have you not printed out the values returned from rand() which is a straightforward int.
That would be a good place to start.
I have a sneaky feeling that the problem is in the custom software package.  I'll soon find out.
Here are some random floats for you:
awneil, what ever floats your boats.
Can you generate a sequence of random bits?
If so, you should be able to get whatever else you want.
Hi skeeve, what about a cpu register or a floating adc input?
https://dannyelectronics.wordpre...
Final code:
	char sys_time[7];
	sys_time[0] = NMEA_GPRMC.UTC_Time[0];
	sys_time[1] = NMEA_GPRMC.UTC_Time[1];
	sys_time[2] = NMEA_GPRMC.UTC_Time[3];
	sys_time[3] = NMEA_GPRMC.UTC_Time[4];
	sys_time[4] = NMEA_GPRMC.UTC_Time[6];
	sys_time[5] = NMEA_GPRMC.UTC_Time[7];
	sys_time[6] = '\0';
	int seed = rand();
    generator.seed((int)kernel_core.kernel_stamp + seed + atoi(&sys_time[0]));
However, when I enter my RTOS the floating variables are trashed.  I was away for a trip today so I never got to look at the problem but if any freaks can think of something that my cause it please feel free to post.
Wm.
What floating point values?
-1 and 1?
According to the definition of uniform_real_distribution, yours would include -1, but not +1 .
Is that what you want?
In float, the range { -1 } is the the same as the range [-1, -1+2**-24) and its probability should be 2**-25 .
Is that what happens?  Is that what you want?
Deciding what you want to happen at the boundaries can be important.
Note that 2**25 is less than 34 million.
On some platforms, getting statistics would be practical.
	extern struct NMEAGPRMC NMEA_GPRMC;
	// compute time for seed, entropy
	char sys_time[7];
	sys_time[6] = '\0';
	char sys_date[7];
	// compute date for seed, entropy
	sys_date[0] = NMEA_GPRMC.UTC_Date[0];
	sys_date[1] = NMEA_GPRMC.UTC_Date[1];
	sys_date[2] = NMEA_GPRMC.UTC_Date[3];
	sys_date[3] = NMEA_GPRMC.UTC_Date[4];
	sys_date[4] = NMEA_GPRMC.UTC_Date[6];
	sys_date[5] = NMEA_GPRMC.UTC_Date[7];
	sys_date[6] = '\0';
	// A Mersenne Twister pseudo-random generator of 64-bit numbers with a state size of 19937 bits.
	static unsigned int seed = 0;
    generator.seed(std::stoi(&sys_time[0]) + std::stoi(&sys_date[0]) + seed++);
    // generate random number
    return distribution(generator);
Reading the following about " What is a reliable electronic circuit to feed into an ADC to generate true random numbers based on junction quantum effects? I have tried, but all suffered from EM 60Hz interference.
Link
Roy's answer is similar to a "Hororan" (AoE) where the ADC is an analog comparator (1-bit ADC)
The Art of Electronics 3rd Edition | by Horowitz and Hill
[pages 982 and 983]
13.14.7 "True" random noise generators
I'm guessing you already have a peripheral on your high powered mcu, called a 'True Random Number Generator'. They probably already thought of everything, and tested it.
