Does Pull UP affects the volatge on pin....?
9 posts / 0 new
hi there....,
This may be a very basic question....or a silly one to be posted on this forum....it'll be good know its answer...we are getting 4.35V on a I/O pin...our supply voltage is 5.07V. We are not using regulator.
PULL UP value is 10k...AVR Mega 32,Port used is PORTA.
...hgaurav 'n' bdhanu :oops:
Yes, the pullup affects the voltage on the pin.
Think about it, a 10k resistor attached to v+, the other side of it is attached to the pin. What do you have connected to the port pin? That could be loading it down.
All the best on your quest
Normally, with no load, you would expect only a 100mV or so (in a 5V system) between the output level and the supply. The pull up will raise the LOW level slightly and ought to make the HIGH level even closer to Vcc.
So, I would look at what else is connected to that pin.
Another Jim
Another Jim :lol:
Good point. I missed that one myself.
One thing the OP noted is that they are using an unregulated supply.
OP:
What else do you have connected to the power supply?
What is the voltage on the VCC pin of the AVR?
Why an unregulated supply?
The list of questions can go on..............
The other jim :wink:
How is the pin configured? Input? Output? What is it connected to?
The difference between the supply and the I/O pin voltage is about a diode drop, but that may be coincidence.
Yet another Jim
(Do we have a quorum yet?)
Your message here - reasonable rates.
To all the Jim's:
The answers to our questions we will never know, untill the OP doth he show..... :mrgreen:
But even still, a logic high of 4.35 volts in a 5 volt system isn't anything to worry about.
The Mega32 data-sheet states that the minimum logic high output voltage is 4.2 volts for a 5 volt system.
While the logic high output of this controller is only 150mV from the minimum specification, it is still within specification.
If this controller was on my bench, I'd simply be taking note of this fact for future reference and then be moving on.
Oh no! A heathen non-Jim has invaded this thread!
There could be many reasons for this reading, but, without further information from the OP, speculation is pointless.
Ah yes! That would be me! :lol:
