samd21 PLL vs DFLL
4 posts / 0 new
In my application my samd21 is in standby sleep most of the time, only waking up to perform some operation and then go right back to sleep.  I currently have my clock configured using the 32 kHz external oscillator (XOSC32), feeding DFLL at 48 MHz.  I am curious the tradeoff if I use the PLL sourced from the external 32 kHZ oscillator running at 48 MHz.  I have anecdotal read that the PLL is more stable but takes more power.  Is the PLL more stable?
photonthunder. We tried both PLLs (DPLL and DFLL) of SAMD21 and found these differences
Startup Time:
  DPLL 1.2/2 ms   (typ/max)
  DFLL 0.2/0.5 ms (typ/max)
And yes, the DPLL ist more stable, we switched from DFLL to DPLL because of UART communication problems. Unfortunately DPLL starts slower and needs more power.
regards
spachner
Thanks for the information, we did switch to DPLL as well, but I had not noticed any real differences in our application where the device will sleep for 20-30 seconds at a time and then just be on typically for several hundred milliseconds.
I can add that we had UART comm problems with our DFLL system and when we made the switch to DPLL it went away.
Engineering is the truest form of art
