Best way to "level shift" analog signals?
4 posts / 0 new
Hi
I need some advice how to convert a 0-5 volt analog signal (from an ADIS16080 gyro) to a 0-3.3 volt compatible voltage? I guess an op-amp will do the work, but my analog skills ends there.
The bandwidth of the signal is 40Hz and the gyro got an internal buffer at the output.
-- R .Lilja
So, 0-5V to 0-3.3V? Why not try a voltage divider with two resistors?
Then buffer it with a follower circuit.
Why didn't I think of an voltage divider... Sometimes I feel stupid =)
Thanks!
