mplab communication library error
11 posts / 0 new
Is there a solution to this problem that I have never been able to solve?
Atmel Studio 7.0
an error occured
MPLAB Communication Library
What does the log files say?
:: Morten
It's a lot more helpful if you put the image in the post where we can see it - like this:
So did you look at "How to fix Install Errors" ?
See Tip #1 in my signature, below, for how to post images like that:
I have the same issue and the "How to fix Installer Errors" takes me to a page that has been out of service since yesterday.
Can you help?
Is there an e-mail where I could ask for support. It has been a week and still I can't install Studio 7 because of this issue.
The Log stops at:
[1084:19FC][2020-09-11T10:39:05]i352: Removing cached bundle: {7bdb1b7f-1095-4ce1-bda8-9313baa37be0}, from path: C:\ProgramData\Package Cache\{7bdb1b7f-1095-4ce1-bda8-9313baa37be0}\
[1B18:0558][2020-09-11T10:39:05]i000: VisualInstaller : Message: ApplyStatus
[1B18:0558][2020-09-11T10:39:05]i399: Apply complete, result: 0x80070570, restart: None, ba requested restart:  No
[1B18:1BF0][2020-09-11T10:39:05]i000: VisualInstaller : Message: Setting page: FinishError
[1B18:1BF0][2020-09-11T10:39:05]i000: VisualInstaller : Message: FinishErrorPage: Creating Error message
[1B18:1BF0][2020-09-11T10:39:05]i000: VisualInstaller : ERROR: FinishErrorPage: ErrorMessage=MPLAB Communication Library
[1B18:1BF0][2020-09-11T10:39:05]i000: VisualInstaller : Message: PageState - setting page: FinishError
When selecting “How to fix Installer Errors…”
I get a web page that shows:
https://microchip.secure.force.com/microchipknowledge/resource/1429288401000/SiteSamples/img/clock.png
https://microchip.secure.force.com/microchipknowledge/resource/1429288401000/SiteSamples/img/warning.png
https://microchip.secure.force.com/microchipknowledge is down for maintenance
Sorry for the inconvenience. We'll be back shortly. Please email us if you need to get in touch.
Powered by https://microchip.secure.force.com/microchipknowledge/resource/1429288401000/SiteSamples/img/poweredby.png
The “email us” link has no recipient.
Can you provide support.
I would like to start development on an Atmel SAMW25 PRO as soon as possible.
Thank you.
I've seen your answer, but the "How to fix Installer Errors..." link takes you to a dead end:
the "email us" link takes you to an empty address mail form
if you know how to fix this issue, could you please share it. I'm behind on a project that selected a SAMW25 device and I can't even begin to review the device without a IDE.
Thank you.
I found a way to finally get rid of the "MPLAB Communication library" issue.
What I did was instead of using the FULL COMPLETE DOWNLOAD version of the installer, I just used the WEB based installer.
That was it.
That was it.
Estou com o mesmo problema que você estava, tem como me explicar como que você fez?
I have the same problem that you were, can you explain to me how you did it?
castanog  did exactly that in the very post that you quoted!
That was it.
thank you
use the Web installer version:
http://studio.download.atmel.com...
that will load the Communication Libraries with no problem.
