USART working Only When Freq=1Mhz ,Fuse bits are set correctly(I think))
13 posts / 0 new
hello ..
I know This is repeated ...
I'm using ATmega8 , The problem is that when i set the clock to internal RC 1MHZ (in fuse bits and code) with buad rate set to 2400 (error rate is 0.2% according to datasheet) it works perfectly !
But  when i set the clock to Internal 8MHz (both in fuse bits and code) with baud rate to 9600,4800,2400,19200 (I tried all 4) (error rate is 0.2% according to datasheet) it outputs none sense on Terminal screen
I ofcourse checked that the baud rate is the same in my serial terminal And the code ..
My Code:
#define F_CPU 8000000UL
#include <util/delay.h>
void Usart_Init(unsigned long USART_BAUDRATE)
	unsigned int BAUD_PRESCALE;
	BAUD_PRESCALE = (((F_CPU / (USART_BAUDRATE * 16UL))) - 1);
	UCSRB = (1 << RXEN) | (1 << TXEN); // Turn on the transmission and reception circuitry
	UBRRH = (BAUD_PRESCALE >> 8); // Load upper 8-bits of the baud rate value into the high byte of the UBRR register
	UBRRL = BAUD_PRESCALE; // Load lower 8-bits of the baud rate value into the low byte of the UBRR register
void Usart_Write(char Data2Write)
	while ((UCSRA & (1 << UDRE)) == 0) {}; // Do nothing until UDR is ready for more data to be written to it
	UDR = Data2Write;
void Usart_Write_Text(char *text_){
	unsigned char c;
	while ((c = *text_++) != 0) {
		Usart_Write(c);
	Usart_Write(0);
	DDRB=0xff;
	PORTB=0;
	Usart_Init(9600);
	Usart_Write_Text("Hello");
	Usart_Write(0x0d);        // new line
	Usart_Write_Text("-------------");
	Usart_Write(0x0d);
	for(char i =0 ; i<10 ; i++) // quick led flash Just to check that the atmega has started up
		PORTB=255;
		_delay_ms(50);
		PORTB=0;
		_delay_ms(50);
    Usart_Write_Text("StartingUp... \r");
    while (1)
		Usart_Write_Text("still alive : )\r");
		PORTB=255;
		_delay_ms(500);
		PORTB=0;
		_delay_ms(500);
Fuse Bits
Edit: ((Spelling))
A Beam of Light out of the War
Couple more things to consider :
- It's working perfectly on Simulation (Proteus) in both 1MHz and 8MHz
- The same problem applies when using Internal 4Mhz
- I tried adding 1uF cap between Vcc and GND
- I'm using Ardunio board as Serial bridge between PC and my ATmeag
- I tried changing the usb cable
A very silly question but you did also change the PC terminal baud rate to something other than 2400?
IIRC, the M8 has three or is it four different internal RC oscillators, and each one has a calibration byte to go with each osc., but only the 1MHz is loaded into OSCCAL automatically.
So did you also find the cal byte and save it to eeprom so you can load it and save it to the OSCCAL reg upon startup?
The internal RC osc, frequency will change with room temperature and VCC voltage level, so is not ideal for use with USART comms, best to use an external xtal (best) or external resonator, or external clock for solid operation.  Makes life easier if a known good clock source is used!!!
Keys to wealth:
If you want something you've never had...
...you must be willing to do something you've never done!
Lets go Brandon!
May be ok to leave out the xtal, if messing around.  However,  why waste time not using a crystal?  It may borderline work sometimes, or for a while.  Build 100 & 10 won't work
You can leave out caps on Vcc and some might work---but you add those, right?
Save a headache & put in a little xtal....be right on the money.
I recommend using a crystal:
7.3728Mhz is the best choice for Usart communication.
See in the data sheet. There you have 0% error in the baud rate.
Ellen
Senior Electric Engineer
I use Atmega128, AS7, GNU GCC, Atmel ICE
Exactly!
Why deliberately create problems for yourself?!
Thanks for reply Everybody I really appreciate it
Yes,ofcourse
ki0bk wrote:
did you also find the cal byte and save it to eeprom so you can load it and save it to the OSCCAL reg upon startup ?
Actually no , Because as i remember i have used The internal 8MHz clock on a new atmega8 without doing anythings to cal byte and it worked back then (in a year ago)
I'll try it now thx ..
Actually the temp in my room now is about 43c (Really Hot ) ...
Yes And that's what i tried but i messed up the fuse bits (My Bad ..  )
I had to buy another one till i figure out how to fix the broken one (Another subject)
I'm going to use the Xtal one more time but with more cation this time ..
I will redo some experiments with crystals (and cal byte) and post the results here, Thx Everyone .
There is a tutorial here on how to fix "bricked" AVR's: https://www.avrfreaks.net/forum/...
Keys to wealth:
Lets go Brandon!
Hello Again
I have just used a 8MHz Crystal with NO caps and IT WORKED
Thanks Every body
Now couple more questions pls ..
 - How much important are the caps on the Crystal , and how dose their value  effect the clock ? any guide/tut on that ? (not that my application needs time measurements with timers)
 - I Really do need Newbie friendly step by step tutorial on calibrating AVR Internal clocks .. or if u give me a ready made code and circuit  ...That would be awesome ..
Are you working on a solderless breadboard ... ?
it is all in App Note AVR042 AVR h/w design considerations
Edit: you may find this old pdf helpful
Keys to wealth:
Lets go Brandon!
and you will find all the App Notes - and other useful stuff - on the Product Page:
Definitely worth a browse
