ATMEL ICE Varying speeds Between ISP and JTAG
5 posts / 0 new
So I am having issues with flashing my project to  Atmel 324 chipset. The previous revision, I designed the system to have to have the ISP interface and the problem I'm having didn't exist. With this revision, I implemented the JTAG interface. The device gets programmed  and functions exactly like it should except for one thing- it runs slowly. For instance, a 1ms delay turns into a 10ms delay. I have a countdown timer on my design and instead of counting down in seconds, it is counting down every 5 to 7 seconds.
Cody W Phipps
Default for clock fuses is clk/8, so it is actually 8 times slower, make sure your fuse settings are disabling this fuse.
Thank you sir. That did the trick.
For anyone that is looking the solution to this problem in the future and are unfamiliar with fuse settings go to Device Programming > Fuses and uncheck the box for LOW.CKDIV8
Cody W Phipps
That fuse bit has bitten us all at one time or another, but only once!
phippstech wrote:
That did the trick
Thanks for feedback - please mark the solution.
See Tip #5 in my signature, below, for instructions:
