SAMA5D36 RTC/VBAT Insertion
5 posts / 0 new
I am using ATSAMA5D36 xpained board, I tried to mount RTC battery (CR1220) coin cell in the VBAT pin of J14 header
But the battery voltage is draining from 3V to 1V with in a day
What will be the reason, can anybody help me to solve this,
Please find the attachment,
As my understanding, The battery voltage drop due to the R185, But
I removed the R185 (1.5K) resistor also even though its doping.
Cross post:  Internet of Things » Forums » Wireless » General Wireless Discussions » SAMA5D36 RTC
https://community.atmel.com/forum/sama5d36-rtc   Two minutes earlier.
It's a whole lot easier if you insert the picture in the post, where we can see it - like this:
For instructions on how to do that, see Tip #1 in my signature, below:
(never mind)
The User Guide says this is intended for a supercap - not a battery.
If it's expecting a supercap, then it will be expecting to charge it - I don't think that's going to go well with a battery ... ?
