Understanding RJMP instruction
4 posts / 0 new
I would like to understand what is happening in the disassembly of a very simple code.
From the manual I understand that RJMP instruction has  4 hexadecimal numbers, C kkkk kkkk kkkk where k is a 12 signed integer. The instruction does PC = PC + k + 1.
For the next C code:
int main( void )
  int counter = 0;
  while(counter < 5){
    ++(counter);
  return 0;
The disassembly is:
I understand that in line 000076 CFFA is the C and FFA is the 12 signed number, which translates to a -6. Then I expect PC = 000076 + (-6) + 1 = 000071. But as you can see at the end of line 000076 it says it will jump to 00006C, which it does during the debugging. But I don't understand why.
If it helps I am using IAR workbench, and the device is an atmega328P.
Address changes by Words not Bytes
David
Note: when the RJMP instruction is executed the PC points to the next instruction, ie. PC = 0x0078
subtract 12 (0x0c) from the PC and you get PC = 0x006C
Thank you, I didn't think of that.
