Hello everyone.
I have a code written in C programming language. github.com/kghunt/NWatch
I also want to get temperature and pressure data with the BMP280 sensor. However, the code does not allow this, it has created its own i2c library and used TWI.c. Because the Wire library is written in C ++, which creates a problem.
My code
#include<Wire.h> // BMP280 I2C address is 0x76(108) #define Addr 0x76 void setup() { // Initialise I2C communication as MASTER Wire.begin(); // Initialise Serial communication, set baud rate = 9600 Serial.begin(9600); } void loop() { unsigned int b1[24]; unsigned int data[8]; for (int i = 0; i < 24; i++) { // Start I2C Transmission Wire.beginTransmission(Addr); // Select data register Wire.write((136 + i)); // Stop I2C Transmission Wire.endTransmission(); // Request 1 byte of data Wire.requestFrom(Addr, 1); // Read 1 byte of data if (Wire.available() == 1) { b1[i] = Wire.read(); } } // Convert the data // temp coefficients unsigned int dig_T1 = (b1[0] & 0xFF) + ((b1[1] & 0xFF) * 256); int dig_T2 = b1[2] + (b1[3] * 256); int dig_T3 = b1[4] + (b1[5] * 256); // pressure coefficients unsigned int dig_P1 = (b1[6] & 0xFF) + ((b1[7] & 0xFF) * 256); int dig_P2 = b1[8] + (b1[9] * 256); int dig_P3 = b1[10] + (b1[11] * 256); int dig_P4 = b1[12] + (b1[13] * 256); int dig_P5 = b1[14] + (b1[15] * 256); int dig_P6 = b1[16] + (b1[17] * 256); int dig_P7 = b1[18] + (b1[19] * 256); int dig_P8 = b1[20] + (b1[21] * 256); int dig_P9 = b1[22] + (b1[23] * 256); // Start I2C Transmission Wire.beginTransmission(Addr); // Select control measurement register Wire.write(0xF4); // Normal mode, temp and pressure over sampling rate = 1 Wire.write(0x27); // Stop I2C Transmission Wire.endTransmission(); // Start I2C Transmission Wire.beginTransmission(Addr); // Select config register Wire.write(0xF5); // Stand_by time = 1000ms Wire.write(0xA0); // Stop I2C Transmission Wire.endTransmission(); for (int i = 0; i < 8; i++) { // Start I2C Transmission Wire.beginTransmission(Addr); // Select data register Wire.write((247 + i)); // Stop I2C Transmission Wire.endTransmission(); // Request 1 byte of data Wire.requestFrom(Addr, 1); // Read 1 byte of data if (Wire.available() == 1) { data[i] = Wire.read(); } } // Convert pressure and temperature data to 19-bits long adc_p = (((long)(data[0] & 0xFF) * 65536) + ((long)(data[1] & 0xFF) * 256) + (long)(data[2] & 0xF0)) / 16; long adc_t = (((long)(data[3] & 0xFF) * 65536) + ((long)(data[4] & 0xFF) * 256) + (long)(data[5] & 0xF0)) / 16; // Temperature offset calculations double var1 = (((double)adc_t) / 16384.0 - ((double)dig_T1) / 1024.0) * ((double)dig_T2); double var2 = ((((double)adc_t) / 131072.0 - ((double)dig_T1) / 8192.0) * (((double)adc_t) / 131072.0 - ((double)dig_T1) / 8192.0)) * ((double)dig_T3); double t_fine = (long)(var1 + var2); double cTemp = (var1 + var2) / 5120.0; double fTemp = cTemp * 1.8 + 32; // Pressure offset calculations var1 = ((double)t_fine / 2.0) - 64000.0; var2 = var1 * var1 * ((double)dig_P6) / 32768.0; var2 = var2 + var1 * ((double)dig_P5) * 2.0; var2 = (var2 / 4.0) + (((double)dig_P4) * 65536.0); var1 = (((double) dig_P3) * var1 * var1 / 524288.0 + ((double) dig_P2) * var1) / 524288.0; var1 = (1.0 + var1 / 32768.0) * ((double)dig_P1); double p = 1048576.0 - (double)adc_p; p = (p - (var2 / 4096.0)) * 6250.0 / var1; var1 = ((double) dig_P9) * p * p / 2147483648.0; var2 = p * ((double) dig_P8) / 32768.0; double pressure = (p + (var1 + var2 + ((double)dig_P7)) / 16.0) / 100; // Output data to serial monitor Serial.print("Pressure : "); Serial.print(pressure); Serial.println(" hPa"); Serial.print("Temperature in Celsius : "); Serial.print(cTemp); Serial.println(" C"); Serial.print("Temperature in Fahrenheit : "); Serial.print(fTemp); Serial.println(" F"); delay(1000); }
I don't want to use Wire.h library. I worked datasheet a few days, but i couldn't handle it.
