Hello everyone. A few days ago I posted a problem here. https://www.avrfreaks.net/forum/...
I thank everyone who tried to help me in that post. I have reduced the issues now but still have some problems.
I want to use i2c.c and i2c.h instead of Wire.h library and get data with BMP280 sensor.
#include<Wire.h> // BMP280 I2C address is 0x76(108) #define Addr 0x76 void setup() { // Initialise I2C communication as MASTER Wire.begin(); // Initialise Serial communication, set baud rate = 9600 Serial.begin(9600); } void loop() { unsigned int b1[24]; unsigned int data[8]; for (int i = 0; i < 24; i++) { // Start I2C Transmission Wire.beginTransmission(Addr); // Select data register Wire.write((136 + i)); // Stop I2C Transmission Wire.endTransmission(); // Request 1 byte of data Wire.requestFrom(Addr, 1); // Read 1 byte of data if (Wire.available() == 1) { b1[i] = Wire.read(); } } // Convert the data // temp coefficients unsigned int dig_T1 = (b1[0] & 0xFF) + ((b1[1] & 0xFF) * 256); int dig_T2 = b1[2] + (b1[3] * 256); int dig_T3 = b1[4] + (b1[5] * 256); // pressure coefficients unsigned int dig_P1 = (b1[6] & 0xFF) + ((b1[7] & 0xFF) * 256); int dig_P2 = b1[8] + (b1[9] * 256); int dig_P3 = b1[10] + (b1[11] * 256); int dig_P4 = b1[12] + (b1[13] * 256); int dig_P5 = b1[14] + (b1[15] * 256); int dig_P6 = b1[16] + (b1[17] * 256); int dig_P7 = b1[18] + (b1[19] * 256); int dig_P8 = b1[20] + (b1[21] * 256); int dig_P9 = b1[22] + (b1[23] * 256); // Start I2C Transmission Wire.beginTransmission(Addr); // Select control measurement register Wire.write(0xF4); // Normal mode, temp and pressure over sampling rate = 1 Wire.write(0x27); // Stop I2C Transmission Wire.endTransmission(); // Start I2C Transmission Wire.beginTransmission(Addr); // Select config register Wire.write(0xF5); // Stand_by time = 1000ms Wire.write(0xA0); // Stop I2C Transmission Wire.endTransmission(); for (int i = 0; i < 8; i++) { // Start I2C Transmission Wire.beginTransmission(Addr); // Select data register Wire.write((247 + i)); // Stop I2C Transmission Wire.endTransmission(); // Request 1 byte of data Wire.requestFrom(Addr, 1); // Read 1 byte of data if (Wire.available() == 1) { data[i] = Wire.read(); } } // Convert pressure and temperature data to 19-bits long adc_p = (((long)(data[0] & 0xFF) * 65536) + ((long)(data[1] & 0xFF) * 256) + (long)(data[2] & 0xF0)) / 16; long adc_t = (((long)(data[3] & 0xFF) * 65536) + ((long)(data[4] & 0xFF) * 256) + (long)(data[5] & 0xF0)) / 16; // Temperature offset calculations double var1 = (((double)adc_t) / 16384.0 - ((double)dig_T1) / 1024.0) * ((double)dig_T2); double var2 = ((((double)adc_t) / 131072.0 - ((double)dig_T1) / 8192.0) * (((double)adc_t) / 131072.0 - ((double)dig_T1) / 8192.0)) * ((double)dig_T3); double t_fine = (long)(var1 + var2); double cTemp = (var1 + var2) / 5120.0; double fTemp = cTemp * 1.8 + 32; // Pressure offset calculations var1 = ((double)t_fine / 2.0) - 64000.0; var2 = var1 * var1 * ((double)dig_P6) / 32768.0; var2 = var2 + var1 * ((double)dig_P5) * 2.0; var2 = (var2 / 4.0) + (((double)dig_P4) * 65536.0); var1 = (((double) dig_P3) * var1 * var1 / 524288.0 + ((double) dig_P2) * var1) / 524288.0; var1 = (1.0 + var1 / 32768.0) * ((double)dig_P1); double p = 1048576.0 - (double)adc_p; p = (p - (var2 / 4096.0)) * 6250.0 / var1; var1 = ((double) dig_P9) * p * p / 2147483648.0; var2 = p * ((double) dig_P8) / 32768.0; double pressure = (p + (var1 + var2 + ((double)dig_P7)) / 16.0) / 100; // Output data to serial monitor Serial.print("Pressure : "); Serial.print(pressure); Serial.println(" hPa"); Serial.print("Temperature in Celsius : "); Serial.print(cTemp); Serial.println(" C"); Serial.print("Temperature in Fahrenheit : "); Serial.print(fTemp); Serial.println(" F"); delay(1000); }
As you can see here, Wire.h is used. Instead, I want to use the i2c.c and i2c.h files I shared in the attachments.
Full code : https://github.com/zkemble/NWatch
