How to select micro controller architecture
63 posts / 0 new
Pages
Kartman wrote:
Somewhere in the RISC-V blurb they explain their decision regarding the flags.
From the Wikipedia page:
RISC-V has no condition code register or carry bit. The designers believed that condition codes make fast CPUs more complex by forcing interactions between instructions in different stages of execution. This choice makes multiple-precision arithmetic more complex. Also, a few numerical tasks need more energy. As a result, predication (the conditional execution of instructions) is not supported. The designers claim that very fast, out-of-order CPU designs do predication anyway, by doing the comparison branch and conditional code in parallel, then discarding the unused path's effects. They also claim that even in simpler CPUs, predication is less valuable than branch prediction, which can prevent most stalls associated with conditional branches. Code without predication is larger, with more branches, but they also claim that a compressed instruction set (such as RISC-V's set C) solves that problem in most cases.[1]
Instead, RISC-V has short branches that perform comparisons: equal, not-equal, less-than, unsigned less-than, greater-than or equal and unsigned greater-than or equal. Ten comparison-branch operations are implemented with only six instructions, by reversing the order of operands in the assembler. For example, branch if greater than can be done by less-than with a reversed order of operands.[1]
Thank God it's only the C++ compiler authors who actually need to worry about any of this ! :-)
Yeah. But I looked at some RISC-V assembly snippets, it's not that bad. Another uncommon feature is an hardcoded zero register, that, well, always reads zero.
A number of the early RISC chips had pipeline traps where it was expected the compiler would manage this. A pipeline trap is where certain sequence of instructions can cause unwanted results. ie an instruction that might rely on the result of a previous instruction and due the the pipeline where you might have a read register, alu operation, write register sequence, the following instruction would read the register before the previous operation had written it. The compilers would recognise these dangerous sequences and either re-order, avoid or shove in a nop to avoid it.
Even in modern chips, either the compiler, c run time or the libraries may have 'fixes' for hardware issues.
Time will tell if the carry flag will be missed in RISC-V.
Select your micro controller architecture according to the lowest over-all cost of the MCU to the project or product.  The cost is a balance between the non-recurring engineering and programming costs and the per-unit hardware costs.
If you are making 1-10 of an individual design, which is rare outside of hobbyist circles, I suggest going fully Arduino UNO/Nano.  Buy pre-manufactured bootloader-preinstalled clone MCU module boards that have been manufactured cheaply and reliably.  The software development system is free, well-maintained, well-documented, and well supported. Libraries for most hardware devices are freely downloadable.   Between 10 and 100 units, determine the best device in an MCU family, and buy the individual ICs from a distributor.  Acquire, learn, and use the manufacturer's development system for the device family.  Design a custom PCB for the product.
For each order-of-magnitude of product volume, i.e.  100 units, 1000 units, 10,000+ units of the same design, go more to a specialized non-Arduino micro.    Your non-recurring engineering expenses are going to be greater with each order-of-mag, but these costs are going to be a lower percentage of the final cost.  In other words, if you are making 100,000 units of an individual design, buy the full manufacturer's device development kit, along with a training seminar for your development team.  Then buy a pic' n' place reels of the uncommon, but focused on your design parameters, microcontroller for 5-20 cents each.
If you're doing individual learning at home for future career use, start with the Arduino Nano.   School-based learning seems to be usually AVR-based on the Mega devices outside of the Arduino framework.  Best to do what your teacher assigns you to do with the equipment and devices available in the electronics lab, but take the time to learn Arduino as well.  If you're already employed and wish to enhance the skills that your employer will use, learn the "blue pill" ARM Cortex M3 device. This is a complicated chip, so don't be shy to ask around for a engineering tutor familiar with low-cost ARM development.  Expect to pay $100+ dollars for several hours of focused tutorials and development equipment.
Arduino enables one dba the S in SMB/SME in proof-of-concept to design win to first prototype (customer buy-in)
in-lieu of clone, on original can release restrictive licensing.
Simonetta wrote:
Then buy a pic' n' place reels ...
Ask the PCBA manufacturer what's preferred as tubes still exist; low-rate production may be in bags that the PnP operator will empty onto a tray (OCR, and IIRC, Microchip parts are labelled only on the package's top) (hardware BOM - some distributors have a kitting service, software BOM - PCBA manufacturer may want a self test)
There are local or regional PCB manufacturers which enable local and regional PCBA manufacturers; otherwise, there may be a night-time phone call asking for approval of a part substitution.
Simonetta wrote:
... of the uncommon, but focused on your design parameters, microcontroller for 5-20 cents each.
tiny202 are almost into that price range.
One provider of embedded computer language training may have selected micro:bit; some inexpensive operator interface devices don't have USB HCI though do have Bluetooth (Android)
Some engineering colleges have moved away from AVR though may have a course for other students (Arduino enables the creation of custom instruments for those who aren't into electrical engineering)
or the employer has interests in Motorola 68000, Intel 386, IBM PowerPC, DSP, FPGA, etc (all kinds of employers)
Computer language skills are more portable; computer languages can be via a web browser.
Some employers are willing to splash some cash-equivalent for such.
Make Your Own Job with Open Source Hardware: What Students Don’t Know
via Open Source | Licensing -- Quantum Leaps
Designing and Building the Macro Watch - MacroFab (HQ in Houston Texas)
MacroFab Factory Network - MacroFab
PCBShopper – A Price Comparison Site for Printed Circuit Boards
https://www.microchipdirect.com/product/search/all/ATtiny202?mos=true
Ada on the micro:bit - The AdaCore Blog
ECE 4760, Cornell University (edit : HTTPS)
cling@GOREPL
Labs — learn.adacore.com
Embedded Software Training Calendar | Embedded Software Engineering Courses | Barr Group via Barr Group Store | Barr Group
Public Ada Training - AdaCore
edit :
Ada for micro:bit Part 1: Getting Started - The AdaCore Blog
The Industry’s First SoC FPGA Development Kit Based on the RISC-V Instruction Set Architecture is Now Available | Microchip Technology
Microchip’s PolarFire SoC FPGA Icicle Kit enables the broad RISC-V-based Mi-V ecosystem for the industry’s lowest-power FPGA
Chandler, Arizona
Sept. 16, 2020
... Microchip’s Icicle Development Kit for PolarFire (SoC) FPGAs brings together numerous Mi-V partners to accelerate customer design deployment and commercial adoption across a variety of industries.
The Icicle Kit is centered around a 250K Logic Element (LE) PolarFire SoC device and includes a PCIe® connector, mikroBUS™ socket, dual RJ45 connector, Micro-USB connector, CAN bus connector, Raspberry Pi® header, JTAG port and SD Card interfaces, which allow developers a full-featured platform for development. ...
Availability
            Microchip’s Icicle Kit for PolarFire SoC FPGAs (MPFS-ICICLE-KIT-ES) is available today starting at $489.00. PolarFire FPGAs are in production today with early samples of the SoC FPGA available today. ...
edit :
PolarFire® SoC Icicle Kit, Microchip’s RISC-V-Based SoC FPGA Development Kit - YouTube (3m39s)
Make it $89 and maybe, $49 and definitely
Many applications are relatively generic. For example, my accelerometers require I2C (to talk to a sensor) and SPI (to talk to a microSD card) and one ADC channel and a UART and a few port pins to control LEDs. Power consumption is pretty important, but if it is less than a certain amount, anything is OK. Cost is important, but it does not matter a huge amount if it is 0.50USD vs 2USD; less gives me a few more cents profit but either is acceptable. Size is not critical. Running from 3.3V is pretty important because several external peripherals require 3.3V. Speed is moderately important because interfacing to the memory card is somewhat intensive.
Now, notice that list if requirements. Nowhere, does the bit width come in. It basically makes no difference as long as those other conditions are met. But, there are many, many micros from a broad range of suppliers that meet those conditions. So, how does one choose? You pick what ever is comfortable to you. You pick one that has internal peripherals that you understand. You pick one that has programming tools that solve both development and (in my case) relatively small scale production. It helps to pick one with a good support "ecosystem" (I hate that term applied this way); some are pretty miserable and you may end up spending a lot of development time just trying to make it work.
Again, there is no mention of bit width. It is really not relevant, once the real requirements are met. In other words, bit width is not a real requirment.
I would also argue that bit width does not define architecture. "Harvard" and "von Neumann" do. THAT is a real choice.
This can also include current team familiarity with a processor family and toolset.  Getting to market earlier with more expensive hardware can sometimes be the correct path.
Why Universities Want RISC-V – EEJournal
by Jim Turley
October 27, 2020
Sometimes It’s Not About The Technology or The Performance
Their [university] participation must be entanglement-free. No proprietary technology and no licensing fees.
RISC-V, the Linux of the chip world, is starting to produce technological breakthroughs | ZDNet
by November 30, 2020 -- 18:47 GMT (10:47 PST) | Topic: Hardware
RISC-V, the open standard for chip instructions, is leading to some impressive technical innovation, one of its creators says.
The ability of a small but seasoned crew of chip designers [Micro Magic] to accomplish such a task [5GHz, 1W] suggests a design renaissance that could be on the horizon.
[Micro Magic's RISC-V compute efficiency]
The [Micro Magic] RISC-V prototype eliminates a bottleneck that can exist with fast memory and slower chips.
... things can be done in chip design to resolve that bottleneck in ways not possible if the chip's instructions were locked down.
Because of the simplicity of the instruction set of RISC-V, Micro Magic was able to have its chip produced using a standard silicon wafer with no special tweaking.
In a sense, then, RISC-V can potentially promote the micro-batch approach seen in a lot of modern product lines, from breweries to cheese to clothing.
That is where the ecosystem of companies around RISC-V becomes important.
Pages
