ATSAM3X8E memory reset
3 posts / 0 new
projects with IDE
ARDUINO IDE: Arduino Due
PIO, ATSAM3X8, Framework Arduino.
visual micro vs atmel studio: Framework Arduino.
simple bootloader on Flash, loader code in RAM call code, execute.
load code call direct ( my entry_main_ram) 0x20000000 area ok.
see: run ok , file flash.ld and sram.ld compiling separately (flash)
void entry_main_ram(){
uint32_t led =0;
 while(1){
     digitalWrite( L1, led );  running sram ok...simple led
      led ^=1;
problems violation cause reset processor:
bool bl = true;
 while(1){
    digitalWrite( L1, bl = !bl ); not effects, in flash ok
  set_invet_led();  simple call reset processor
//---------------------see list call reset processor
Serial.begin(9600); reset processor
pmc_enable_periph_clk(ID_CAN0); reset processor
can_init(CAN0, 84000000, 500); reset processor
grobal variable simple set ( uint32 temp1; ) temp1 = 0x1234;   reset precessor
execute code on ram error.
thanks,
Carlos.
hi,
problems solved,
thanks,
Carlos.
Okay, but how? Can you describe solution?
