32x64 Dot matrix RGB panel with ATMega16
11 posts / 0 new
Hello all, I am interfacing 32x64 P5 RGB panel with ATMega16. Display is working fine except this one problem, what ever I display in row "0" it is repeatedly displayed in row"8" and so on for further rows. Is there any way to address exactly one row at a time? Please suggest what should I do?
How about telling us about your project?
1) Why have you not posted your code?
2) Why have you not posted your schematic?
3) Why have you not told us what 'RGB panel' you are using?
..remember, we can't read your mind.
//Pin definitions
#define col_port PORTD
#define R1  PD0
#define G1  PD1
#define B1  PD2
#define R2  PD3
#define G2  PD4
#define B2  PD5
#define dat_port PORTA
#define A   PA0
#define B   PA1
#define C   PA2
#define D   PA3
#define LAT PA4
#define CLK PA5
#define OE  PA6
Array I am printing
uint8_t _temp[]={0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00}; //Display required only in first row of panel
Main loop used for printing
	line=0;
	for(_disp_delay=0; _disp_delay<50; _disp_delay++)
		value =
		(uint64_t)(_temp[_index++]) << 56 |
		(uint64_t)(_temp[_index++]) << 48 |
		(uint64_t)(_temp[_index++]) << 40 |
		(uint64_t)(_temp[_index++]) << 32 |
		(uint64_t)(_temp[_index++]) << 24 |
		(uint64_t)(_temp[_index++]) << 16 |
		(uint64_t)(_temp[_index++]) << 8	|
		(uint64_t)(_temp[_index++]);
		shift(TurnBitsAround(value));
		if(_index >= 8)
			_index=0;
Display function used
void shift(uint64_t data){
// data=0;
		dat_port &= (~(1<<OE));
		for (uint8_t n=0; n<64; n++) {
			col_port=0x00;
			if( ((uint64_t)1<<n) & data ){
  				col_port &= (~(1<<R1));
  				col_port &= (~(1<<G1));
  				col_port &= (~(1<<B1));
				col_port |= (1<<R1);     //Red Color only
		        dat_port |= (1<<OE);
			dat_port &= (~(1<<CLK));
			dat_port |= (1<<CLK);
 		dat_port &= (~(1<<LAT));
		dat_port |= (1<<LAT);
		dat_port |= (line & 0x0F);	//Set Line number
The panel I am using is https://www.amazon.co.uk/outdoor-waterproof-display-320x160mm-module/dp/B07G849F38
HUB75 connected with wires as per pin definition given above.
Please suggest how do I address individual row at a time? Thanks
and the description of that says:
P5 outdoor waterproof full color led display 64x32 pixel 320x160mm panel 1/8 scan smd 2727 rgb p5 led module video wall HD panel
I know nothing about these things, but could that "1/8 scan"  be a clue ... ?
Thanks, Yes it is, But I am also new to these displays and want to know the mechanism to address individual row.
So have you googled to find information about them? examples? tutorials? etc?
That's a basic first step when starting with any new thing ...
EDIT
Where AVRs are concerned, adding "Arduino" to your search term is usually a good start; eg
https://www.google.com/search?q=%2Barduino+P5++full+color+led+display++panel
which leads to things like
https://create.arduino.cc/projecthub/CamelCaseName/running-a-32x64-rgb-led-panel-with-only-an-arduino-nano-c19385
https://learn.sparkfun.com/tutorials/rgb-panel-hookup-guide/all
Yes I have googled and as I mentioned that I am writing the above code in that I need assistance in finding out HOW to address the individual ROW. Thanks for showing the links I have been through. I hope to get helpful answers please!!
Surely, that must be shown in those links - they must do it?
https://www.sparkfun.com/news/26...
As such, you don't address the individual row - the row data is shifted in serially so you shift in all the row data. You can access an individual led by manipulating the data array in memory that you shift out to the display.
Thank you for the kind reply Kartman. Yes I had read this article but things were still not working for me after digging in I figured out that the pixels position in my case was different. Conclusion: every dot matrix display does not have the same arrangement. The technique I used to access a row was same as mentioned in the article, shift serial bits to two rows at a time that means selecting x row will select x and x+8 row at the same time, write data in both of these rows. Thanks to humble replies only.
Is the question answered?
