Hi All
I require a simple FAN controller, i am thinking about using the EMC2301 , unless there is a better solution?
I was considering using a an AVR pulsing a Mosfet using PWM, but my reason for a FAN controller is to have an independent solution, where it also detect any faults, which reduce any firmware that will need to write.
My core question is , when powering the FAN, is a simple MOSFET enough or do i need to add an additional circuit to drive the FANs?
