SAMD21+WINC1500 Missing X509Root
2 posts / 0 new
Trying to run stock WINC1500_SSL_CONNECT_EXAMPLE for with SAM21 explained and WINC1500 xplained.
I get a connect error code 12 and the WINC1500 debug console show a  Missing X509Root error.
But root certs were loaded during firmware update ...
  >>>Found Certificate:
  >>>     GlobalSign Root CA
  >Writing the certificate to SPI flash...
  Done
On WINC1500 debug console it shows:
(3770)>> TLS_RSA_WITH_AES_128_GCM_SHA256
(3780)(SSL_172.217.12.164)-> Certificate
(3790)(TLS)*=*=* X509 *=*=*
(3790)(TLS)     Subject <www.google.com>
(3800)(TLS)     Issuer  <Google Internet Authority G3>
(3800)(TLS)     <2018-03-07 19:53:57> to <2018-05-30 18:53:00>
(3810)(TLS)*=*=* X509 *=*=*
(3810)(TLS)     Subject <Google Internet Authority G3>
(3820)(TLS)     Issuer  <GlobalSign>
(3820)(TLS)     <2017-06-15 00:00:42> to <2021-12-15 00:00:42>
(3830)(M2M)(ERR)(HS_ParseCertificateMsg)(2061)Missing X509Root
I'm running into a similar issue, and I cannot for the life of me get the WINC1500 to connect to a WiFi using TLS. I have a dd-wrt router and an RPi running FreeRadius. The debug console is profoundly unhelpful as well. Are the certificates I downloaded to address 0x4000 in the flash not formatted correctly? Is it looking for a certificate that isn't listed? I have no clue.
The WINC1500 is running firmware v19.6.1. I can post the ascii versions of all my certs/keys in code blocks if you think that can help you figure out what's wrong. (None of them are used outside of a development environment.)
