Guy, I get a strange error when I go to include more files in makefile to build.
obj-y += examples/lcd/cerulean_filingsystem/exfat/clusters.o obj-y += examples/lcd/cerulean_filingsystem/exfat/date_time.o obj-y += examples/lcd/cerulean_filingsystem/exfat/directory_clusters.o obj-y += examples/lcd/cerulean_filingsystem/exfat/exFat_checksums.o obj-y += examples/lcd/cerulean_filingsystem/exfat/exFat.o obj-y += examples/lcd/cerulean_filingsystem/exfat/interface.o obj-y += examples/lcd/cerulean_filingsystem/fat32/clusters.o obj-y += examples/lcd/cerulean_filingsystem/fat32/interface_stuff.o obj-y += examples/lcd/cerulean_filingsystem/fat32/directories.o obj-y += examples/lcd/cerulean_filingsystem/fat32/fat.o obj-y += examples/lcd/cerulean_filingsystem/fat32/fat32.o obj-y += examples/lcd/cerulean_filingsystem/fat32/legacy/fat_83.o obj-y += examples/lcd/cerulean_filingsystem/fat32/interface.o obj-y += examples/lcd/cerulean_filingsystem/fat32/name_utilities.o obj-y += examples/lcd/cerulean_filingsystem/hardware_adaptation_layer/cache_ctrl.o obj-y += examples/lcd/cerulean_filingsystem/hardware_adaptation_layer/file_system_driver.o obj-y += examples/lcd/cerulean_filingsystem/partitions/partitions.o obj-y += examples/lcd/cerulean_filingsystem/filing_system.o obj-y += examples/lcd/cerulean_filingsystem/fs_stack.o obj-y += examples/lcd/main.o
The error is as follows:
00:04:58 **** Build of configuration Default for project EmbX **** make TARGET=sama5d4-xplained LINK build/sama5d4-xplained/ddram/ARM_Cortex-A5_SAMA5D_LCD.elf c:/program files (x86)/gnu tools arm embedded/7 2018-q2-update/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/bin/ld.exe: cannot find ./build/sama5d4-xplained/ddram: Permission denied collect2.exe: error: ld returned 1 exit status make: *** [../../scripts/Makefile.rules:119: build/sama5d4-xplained/ddram/ARM_Cortex-A5_SAMA5D_LCD.elf] Error 1 00:05:00 Build Finished (took 1s.592ms)
if however if I remove the group fat32 or exfat it works. Just not when both are included?
HELP!!!
