Hi All
I need a simple sensor, that can test if water level has dropped below a certain limit in a container.
I do not need any measurements for this application, simply if water has reduced below a certain limit.
Could a simple pulse on a GPIO and then using another GPIO to read it be adequate? It would not be the pin directly, but via cable/wire.
