Atmel START SAM E70 Xplained Ultra boot delay
2 posts / 0 new
Used Atmel START/Studio 7 to create a test project for the ATSAME70Q21 on the SAM E70 Xplained Pro dev kit and everything works great. However, trying to do the same with the SAM E70 Xplained Ultra kit I'm running into a weird problem...Atmel START does not list SAM E70 Xplained Ultra specifically as a board it supports but I thought it shouldn't be any different as the micro is exactly the same. The test program runs fine but there is a long delay (20 seconds or longer at times) after a reset on the SAM E70 Xplained Ultra before the program starts running. I am not sure if this is a problem specific to this particular board (faulty kit) or is there a setup/startup difference for these two boards that I'm not aware of. When I debug everything is working fine but after I flash the program or push the reset button it takes a while (sometimes a long while) for it to start running. Confusing!
I appreciate any help in advance.
Sehnsucht
I just bought a E70 ultra board and found the hard way that it is not in the supported boards for atmel start. I'm curious if you got any information since may 21 of 2019 -_-.
It seems the only way is to make the project manually, I tested harmony 3 and it's very ugly.
