Profiling 100s of structs to be 4 byte aligned.
6 posts / 0 new
I have 100s of structs in my project in AtmelStudio 7.
At times I forget to make sure the structs are 4 byte aligned. As this is a must for ARM controllers and also for UC3 series (good practice).
Is there any profiling tools out there that can list all the structs I have used in the project and show their sizes?
Shahriar
Normally the compiler will do this automatically, by adding padding (that you might not want.)
Yes I am sure it does, appropriately or otherwise. And there is then the CPU hang....and watchdog reboots. This is all known cases.
So I am trying to see if there is a way to quickly profile my code to see which structs or nested structs are NOT a multiple of 4 bytes.
Unless you do something funny (like use the "packed" attribute on a struct), all structs and struct members will be aligned appropriately for the target architecture. It would be a real headache if they weren't! (And GCC is smart enough to know how to properly access unaligned members in a "packed" struct.)
What makes you believe that any of your structs are misaligned, or that misaligned structs are the cause of CPU hangs?
In my mind, this is a red herring unless you can show that even one of your structs is actually misaligned.
 Not true, BTW.  Some ARMs support unaligned memory accesses.  (looks like ARM-v7m (CM3, CM4) should support unaligned accesses, and ARM-v6m (M0, m0+) doesn't.  Might be "implementation dependent."
( "some memory regions might not support unaligned accesses.")
Sounds like an opportunity to make use of compile-time static_assert()s in conjunction with sizeof() and offsetof().
Steve
Maverick Embedded Technologies Ltd. Home of Maven and wAVR.
Maven: WiFi ARM Cortex-M Debugger/Programmer
wAVR: WiFi AVR ISP/PDI/uPDI Programmer
https://www.maverick-embedded.co...
