Classes and noinit
11 posts / 0 new
This is an fyi rather than a question.
I recently had an issue with noinit objects. In retrospect it was obvious.... so obvious that I recall running into it years ago and forgetting.
When instantiating a cpp object, the noinit attribute can be specified. For example
ErrorLog errorLog __attribute__ ((section (".noinit")));
This all worked just fine. My error log persisted through restarts and was helpful in solving all sorts of issues... and then it stopped.
The issue was that I had run cppCheck and been through and resolved many of the warnings that it flagged. One of the warnings was the lack of initialisation in the constructor for the class.
Now obviously if the constructor initialises all of the attributes, noinit has no effect.
It is obvious now.... but it wasn't at the time.
Hopefully I don't forget this again and lose more sleep sad
Regards
Greg
regards
Greg
But `noinit` attribute is specified simply as `__attribute__ ((noinit))`, not as `__attribute__ ((section (".noinit")))` (assuming your compiler supports it.)
The specific behavior you observed is a consequence of you using that `section (".noinit")` instead of the actual `noinit` attribute. That way you disabled zero-initialization but preserved the constructor call.
Dessine-moi un mouton
Hi Andrey,
I tried
extern ErrorLog errorLog __attribute__ ( (".noinit") );
but always rx'ed the error "expected ')' before string constant".
All of the other avr examples I have seen include "section". Do you have a compilable example?
Regrds
Greg
regards
Greg
Did you try
extern ErrorLog errorLog __attribute__ ((noinit));
gregd99 wrote:
I tried
As I stated above, it should be  `__attribute__ ((noinit))`, not `__attribute__((".noinit"))`. No string literals involved.
Having said that, while GCC documentation lists `noinit` as a valid variable attribute, I haven't been able to find an implementation that actually supports it. It is accepted by the syntax, but the compiler warns that this attribute is ignored.
Thanks for the correction.
I tried
It compiles.... it seems to do nothing.
There was a warning
warning: 'noinit' attribute directive ignored [-Wattributes]
regards
Greg
Sorry.  So you were right in the first place.   That warning comes from the avr code in gcc itself.   The avr-libc manual section on memory indicates your original method is the correct approach.
It is not a "correct" approach. `__attribute__((section (".noinit")))` is sufficient for C, but this topic is specifically about C++.
`__attribute__((section (".noinit")))` is not a replacement for `__attribute__((noinit))` in C++ code, since the former does not suppress constructor calls. As far as I can see, avr-gcc offers no solution for C++ at all. Support for `__attribute__((noinit))` is simply not implemented.
A constructor can use assembly to determine whether the object is within the .noinit section.
Another possibility is to define the objects only in assembly.
Data in the .noinit section will not find its way to the hex file or binary.
Yet another possibility is to not define the objects at all: Just use assembly to define their symbols.
Be careful with that. You will be side-stepping the compiler's ability
to prevent overlaps and the linker's ability to detect overlaps.
You will need to explicitly set the address of the following section.
Still another possibility is to use a derived type with only empty constructors.
This is one instance where one might want to use inline assembly in order to insert sizeof(errorLog) into it.
Or put it "out of the way" - like change the stack init to lower the top of stack and then put it above there perhaps?
I'd expect that to work.
The value desired is probably RAMEND-sizeof(errorLog).
IIRC the inline assembly should have "r"(RAMEND-sizeof(errorLog)) in the input constraint list.
If for some reason one wants to save a register at the expense of size and legibility,
"I"(RAMEND-sizeof(errorLog)) could also be used.
