C# Serial Communication failure-- Adafruit Metro M4 and Grand Central M4
7 posts / 0 new
Serial Communication -- Adafruit Metro M4 and Grand Central M4
Background:  VS2017 & Windows 10.  Some time ago I put together a C# data acquisition program to collect data from different experiments using different MCUs.  The app collected CSV text strings and stored the data in a text file for later data evaluation.   The process worked well.
I recently started working with the Metro & Grand Central M4 processor, wanting to use them for additional data acquistion data collections.
I started by writing simple CSV text string and capturing them with VS2017 monitor screen and Arduino 1.8 monitor screens.  Every thing worked well.
Next, I fired up my old program and -- It failed.
I started termite and it didn't capture any data.
I started  PUTTY and I captured data.
I stared a console monitor from a 3rd development program -- it did not capture data.
I stared a Hercules.  It didn't capture data.
I started a 4'th development program monitor -- it did not capture data.
This is my code that opens the port
         srPort = new SerialPort();
         srPort.PortName = portName;
         srPort.BaudRate = baud;
         srPort.DtrEnable = false;
         srPort.Handshake = System.IO.Ports.Handshake.None;
         srPort.RtsEnable = false;
         srPort.StopBits = System.IO.Ports.StopBits.One;
         try
            srPort.Open();
            if (srPort.IsOpen)
               this.srPort.DataReceived += new System.IO.Ports.SerialDataReceivedEventHandler(this.srPort_DataReceived);
               //this.srPort.ErrorReceived += new System.IO.Ports.SerialErrorReceivedEventHandler(this.srPort_ErrorReceived);
               srPort.DtrEnable = true;
               Thread.Sleep(20);
               MessageBox.Show("Port: " + portName + " Open \r\n");
         catch (Exception ex)
            MessageBox.Show("Opening Port:  " + portName + " Failed \n\n" + ex.Message);
            srPort = null;
         return srPort;
This is the event handler for receiving the code
      private void srPort_DataReceived(object sender, SerialDataReceivedEventArgs e)
         int numbytes = srPort.BytesToRead;
         if (numbytes > 0)
            byte[] bytes = new byte[numbytes];
            int knt = srPort.Read(bytes, 0, numbytes);
            this.ScanStreamForValidMsg(bytes);
My program reports that the port is opened properly but never receives data. I placed a breakpoint in the event handler and it is never hit.
So...What am I missing???
Any Suggestions???
An AVR?  This is an AVR forum.
FF = PI > S.E.T
I've never used C# (Python would be my choice), but going to guess you are not setting "portName" to the same value that Putty is using.
I would try Putty's session logging.
https://www.viktorious.nl/2013/01/14/putty-log-all-session-output/
Mice Try but only 2 ports to work with.  Hard not to get the right one.  The description if brief, i actually want to eventually  filter the incoming string
BTW:   writing to the port causes it to hang.
Modem control lines - RTS; DTR ?
Debugging serial comms: https://www.avrfreaks.net/commen...
Thanks --- You're right.  Apparently it is not enough to set Handshaking = none.  The RTS has to be set to high.  When I did that, I started to receive data for the MCU.
Thanks.
You're welcome.
Now please mark the solution - see Tip #5 in my signature, below:
