Has any one worked on artificial intelligence ?
12 posts / 0 new
Hi
I am curious to know if someone has developed an AI system.  if someone has made it can you tell why you used AI. What makes artificial intelligence different then Embedded environment?.
That's a meaningless question.
There's nothing to stop "AI" being "embedded"
Google "edge computing", for example.
EDIT
Creating / training an AI model does take huge amounts of computing power - so that would generally tend to be done on dedicated servers, rather than in the final, deployed system.
EDIT 2
As a timely example, this has just arrived in my inbox:
https://www.eetasia.com/ai-startup-grows-tensai-flow-toolchain-for-aiot-socs
EDIT 3
Another example of AI on embedded microcontrollers:
TensorFlow Lite for Microcontrollers is an experimental port of TensorFlow Lite designed to run machine learning models on microcontrollers and other devices with only kilobytes of memory.
It doesn't require operating system support, any standard C or C++ libraries, or dynamic memory allocation. The core runtime fits in 16 KB on an Arm Cortex M3, and with enough operators to run a speech keyword detection model, takes up a total of 22 KB.
There are example applications demonstrating the use of microcontrollers for tasks including wake word detection, gesture classification from accelerometer data, and image classification using camera data.
https://www.tensorflow.org/lite/microcontrollers
https://devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/nrf-tensorflow-support
Check out https://www.avrfreaks.net/forum/... and his other posts about AI.
Way back in the 80's I developed a Tic-Tac-Toe game that would learn what the best responses were to any input move, after about 15-20 games, you would be lucky to win a game, with a draw being the best a human could achive.  So I guess that was AI, although we just called it machine learning at the time.  Lost the source code to that game many years ago, but I bet google could find something similar.  I'll leave that as an exercise for the student!  wink
I work in machine learning. The products are "embedded" but don't have a lot of connection to 8 bit micros I'm afraid.
Can you elaborate, Why do you need machine learning in the product?
yup working on one at the moment.  Lot to learn though.
Quote, " if someone has made it can you tell why you used AI. What makes artificial intelligence different then Embedded environment?"
Out of curiosity!
What's the point of your question? Are you asking for some particular reason---what are you trying to do?   Try asking Eliza about it, it was an early attempt.
When the original ELIZA first appeared in the 60's, some people actually mistook her for human. The illusion of intelligence works best, however, if you limit your conversation to talking about yourself and your life.
http://psych.fullerton.edu/mbirn...
computer: Hello, I am Eliza.
user: is this artificial intelligence?
computer: Don't you ever say Hello?
Easier and more fun to make real intelligence the old-fashioned way, I feel...
Neil
