SAM3A8C: How to prevent watchdog reset during sleep?
5 posts / 0 new
I’m running a program on the SAM3A8C ARM Cortex CPU and have a problem with the watchdog
giving reset during sleep (via command pmc_sleep(SAM_PM_SMODE_WAIT)).
Shouldn’t all peripherals (including the watchdog) be automatically halted during sleep?
(AFAIK there is no way to manually suspend the watchdog after its initial configuration).
Thanks for any help!
Engztrom wrote:
Shouldn’t ...  the watchdog be automatically halted during sleep?
I don't think that would be generally desirable - as it would leave the potential for you to get stuck in sleep!
Yes, but it is even worse to always get a watchdog reset after a few seconds in sleep.
I might add that I have configured the watchdog with the flag WDT_IDLE_HALT set, but that seems to have no effect.
(Assuming "idle" refers to when the CPU is in sleep mode, even if that is not explicitly stated in the datasheet...)
Is the only solution to disable the reset function for the watchdog and instead let it trig the watchdog interrupt,
and then do a software reset from that interrupt when not flagged via a RAM variable to be in sleep mode?
I guess you could wake briefly from sleep to kick the dog ... ?
But why doesn't the WDT_IDLE_HALT setting work?
Currently the sleep mode is configured to wakeup on an IO-pin change (i.e. a pressed key).
Not sure how to configure it to wakeup on both a timer interrupt (to reset the watchdog) and the IO-pin change (the SAM3X-SAM3A datasheet is rather obscure...),
so if anyone has an example it would be greatly appreciated!
