Illegal storage class __flash in Jumpstart ImageCraft IDE
16 posts / 0 new
I'm trying to build a project that was originally built in Atmel Studio which compiled fine without any errors or warnings, but if I try to build the project in the ImageCraft IDE it says there are no errors but it will fail to build.
Source code snippet of what I'm trying to build in ImageCraft:
static inline void PORTA_set_pin_pull_mode(const uint8_t pin, const enum port_pull_mode pull_mode)
    if (pull_mode == PORT_PULL_UP)
        DDRA &= ~(1 << pin);
        PORTA |= 1 << pin;
    else if (pull_mode == PORT_PULL_OFF)
        PORTA &= ~(1 << pin);
This is the outcome of the build log:
iccavr.exe: 'C:\iccv8avr\bin\iccomavr.exe' returns error code -1073741819 Process terminated with status -1073741819 (0 minute(s), 2 second(s)) Build Failed: 0 error(s), 158 warning(s) (0 minute(s), 2 second(s))
The warnings that are showing when trying to build the project
!W C:\Sahil\Basic WifiBuild\WifiBoard\include\port.h(63):[warning] Illegal storage class __flash for parameter 'pin'. Storage class removed.
!W C:\Sahil\Basic WifiBuild\WifiBoard\include\port.h(63):[warning] Illegal storage class __flash for parameter 'pull_mode'. Storage class removed.
!W C:\Sahil\Basic WifiBuild\WifiBoard\include\port.h(92):[warning] Illegal storage class __flash for parameter 'mask'. Storage class removed.
!W C:\Sahil\Basic WifiBuild\WifiBoard\include\port.h(92):[warning] Illegal storage class __flash for parameter 'direction'. Storage class removed.
The code is using non-standard compiler features. Seems the problem is in port.h
__flash is specific to gcc, I believe.
If you're using a different compiler, you'll need to find out the syntax for accessing variables in program memory.
This https://gcc.gnu.org/onlinedocs/g... suggests it's some kind of ISO/IEC standard but clearly your compiler doesn't like it.
Program Data and Constant Memory | JumpStart C for AVR
though from the words there __flash may be conditional (ie not for auto)
Remove the leading “_” underscores and try again!
jim
My (old) version of ICC has a compiler option that says use const as flash. You probably want that unticked.
Seems the identical question was posted on stack overflow today. What a coincidence.
Porting from one compiler (and IDE) to another requires some familiarity of both entities, assuming both are ansi C compilers, most of the code will be the same, difference will be in how things like interrupts and inline assembly are handled.  Spend some time in each systems documentation to understand how it's done in that compiler.   I have converted several projects from gcc to ICC, it's not hard to do in most cases.
I'm guessing there's a file called "port.h" (and "port.c" perhaps?) because all the "compiler specific" stuff is gathered together into one place to be adjusted to the target compiling environment?
Thanks for your response guys. It turns out that in ImageCraft under the compiler options I had to untick "Treat 'Const' as __Flash (See Note 1).
I'm still having to port the remainder of the driver as the tedious build error of " C:\iccv8avr\bin\iccomavr.exe' returns error code -1073741819 " keeps showing up but I'm working on overcoming that.
I'm puzzled as to why you would want to port to Imagecraft ICCAVR? gcc is a far better compiler methinks (Sorry Richard!).
Unfortunately the project I am working on is huge and it''s gonna take too long to port along with the debugging to go with it.
Plus Richard has moved on to other things, doubt there will be anymore updates to the compiler.
Indeed!
It's stated on the website:
On the linked page, Imagecraft wrote:
Unfortunately, given the changing market environment, it is no longer viable at this time for us to continue to actively develop and support the ICC/JumpStart series of products. While we believe that our AVR and Cortex tools are significantly better than other products in terms of price/performance ratio, features, pricing, and technical support, we are finding it necessary for us to move on.
https://www.imagecraft.com/company/a-note-to-our-customers
There was a thread here about that recently.
EDIT - here:  https://www.avrfreaks.net/forum/imagecraft-compilers?skey=imagecraft
EDIT final quote should have been:
Given that Imagecraft is no longer being supported or developed, you're going to have to do it sometime ...
But that is NOt the important bit of the error? It's what lead to this being shown is the issuse(s) you need to concentrate on surely?
I am puzzled:
Especially puzzling considering, as already noted, that ICCAVR is no longer maintained or supported
Now the confusing part:
But you said it was already working fine in Atmel Studio - so why are you porting it at all ??
