Use DFLL48M as base clock?
6 posts / 0 new
when checking the manual of ATSAMD51G, there is following statement:
7.3.2 Starting of Clocks
Once the power has stabilized and the internal Reset is released, the device will use a 48MHz clock by default. The clock source for this clock signal is DFLL48M, which is enabled after a reset by default.
When I understand this correct, after start-up DFLL48M  is running as clock source at 48 MHz. But when I have a look into Atmel START, there is no possibility to let this clock run for its own - to let it produce an 48 MHz output, an other clock source is needed.
So: how can one set up DFLL48M to be used as base clock which itself does not needs any clock source? The only thing I got working was
OSCLULP32K (32 kHz) -> GCG3 (32 kHz) -> DFLL48M (48 MHz)
which is really weird and complicated.
Select open-loop mode. See section 28.6.4.1 of the datasheet.
I'm not sure if Atmel START will allow you to configure open-loop mode or not.
Josh @ CIHOLAS Inc - We fill the gaps from chips to apps
In Atmel START (and therefore in my code) Open Loop Mode is already selected. But there is still a clock source mandatory, either an external clock (which does not exists in my case) or one of the Generic Clock Generators (which I want to get rid of)...
Not everything in START is gospel.  I'd have to read the datasheet to be sure but I believe it can be done.  That said I looked at DFLL48 on a spectrum analyser once and other than slaved to USB it is quite unfortunate.
jeff
Looking at SAMD51 datasheet it says for reset.
13.7
Clocks after Reset
On any Reset the synchronous clocks start to their initial state:
DFLL48M is enabled and configured to run at 48MHz
Generic Generator 0 uses DFLL48M as source and generates GCLK_MAIN
CPU and BUS clocks are undivided.
From this I gather that Generic Generator 0 is ready to be piped to peripheral upon reset.
But why is "DFLL48 input clock source"   itself a peripheral that is by default disabled upon reset.
14.8.4
Peripheral Channel Control
Name:
PCHCTRLm
Offset:
0x80 + m*0x04 [m=0..47]
Reset:
0x00000000
Property:
PAC Write-Protection
Thanks from Verrrrryyyyy confused.
The DFLL48M runs in open loop mode by default (after reset), no reference clock is needed.
Check  "28.6.4.1 Basic Operation".
/Lars
