MPLAB X IDE with Harmony v3 framework - what is our experience with it
4 posts / 0 new
I hope this is the right forum for my question.
I've been using Atmel Studio for years and liked it almost.
Just the software framework I didn't like, because it creates such a deep folder hierarcy.
You end up with a forest of folders and a vast number of files for the simplest tasks.
I am doing embedded firmware programming, often I have to use the peripherals in a very special way working togethether.
Now we are using the SAM-controllers for our projects (SAM D21, SAM 4S, ...?).
Now I have contacted Microchip forum and got help - but this is a MPLAB X project.
So my question is:
How is your experience with MPLAB X?
How easy / tedious is learning to use Harmony v3 framework?
Who has experience in using SAM-processors with MPLAB X?
Thanks for any comments.
Kaum macht man's richtig - und schon geht's!
MPLAB X IDE is very slow (because of Java) and buggy. Also it uses its own XC32 compiler instead of the mainline GCC.
My choice is Atmel Studio.
Hi PNPPK,
thanks for your answer.
>> MPLAB X IDE is very slow (because of Java) and buggy...
My prejudice about Microchip is proven true - once again.
This two bad things for an Compiler environment combined, makes it an absolute NO-Go to me.
We can only hope and pray that Microchip don't extort the users some time to use this sh..ty MPLAB.
I have heared, that Microchip wants to get rid off Atmel Studio...
What I did see also in the example program, provided by the microchip-support (MPLAB X-Project):
In that, they neither have defined the register bits of the peripherals, nor their bit-values as constants. They use only register assignments with a "magic number". The Holy Grail of do-not! And 42 is the answer to all.
