Return INT or UINT16_t ?
15 posts / 0 new
Hey all....
I am writing a function that will be taking readings from an external ADC and placing them in an array where I will be adding the values in teh array together, and then dividing by the size of the array to get an average.
The readings are unsigned as teh ADC is reading only positive voltages, so I am thinking I return UINT16_t but I want to make sure.
JIm
Yes, uint16_t is what I would use if they are unsigned and between 9 and 16 bits wide.
Thanks Cliff!
Now to write teh function!
JIm
Hmmmmm....  Question again....
The ADC is going to be running constantly, and its possible for the ADC input to be zero volts.  >>For the sake of discussion<< the ADC will output 0x0000 in this case so when the function does the divide, it will be divide by zero resulting in the NEG flag being set.  Can I ignore this flag condition?  The datasheet reads:
The Negative Flag N indicates a negative result in an arithmetic or logic operation. See the “Instruction Set
Description” for detailed information.
I am guessign I can ignore the flag, but I am thinking on the side of playing safe I should either clear the flag on exit of the function, or maybe read teh Status register on entry, and write it back on exit?
JIm
How would be a divide by zero, since you are dividing by the size of the array?
I'll admit its been awhile since I was in school, but IIRC zero divided(or multiplied) by anything is still zero.
but then I suffer from CRS  (Can't Remember Stuff) these days.
Surely you are averaging 5 or 10 or 20 readings or something? So you will be dividing by 5, 10, 20. Sure it may be 0/5 or 0/10 or whatever if the last 5 or 10 readings were all 0 but you aren't DIVIDING by 0 are you?
I wrote:
So, lets say teh array is 10 readings
ten samples that the ADC reports as 0x000 are loaded into the array,  Add the ten zeroes together, I get a value of zero.  0/10 is....what?
Oh, Wait a sec.....
0/10 is zero...
10/0 is not allowed.
DOH!!
You didn't say what the resolution of the ADC was, so I'm going to assume that it is 14 bits since it is an external device and you can get 10-bits on the internal AVR ADC.
So each ADC result can go from 0 to 16383.  If you use uint16_t for your averaging sum, then you can only get four or so results before the sum overflows.
Use a uint32_t for the summation variable .
Jim -
Maybe you should get Daniel to help you with the arithmetic?  :=)
West Coast Jim
12 bits
+1 yes
East Side Jim
Thing about INT is that it is signed and may vary in size on different machines. uint16_t, on the other hand, is unsigned (so it gets you another bit of capacity in unsigned operations) and will always be 16 bits.
West Coast Jim
Note that you don't have to divide at all, in some cases, to get the average effect.  For example, if you say I'm gonna average 6 readings & if the average  is > 27 turn on the pump.
That's the same as saying if the sum>162, turn on the pump, no division needed.  By not dividing, you also have finer resolution (say, use 159 instead of 162).  Faster & better.
If you are going to bother with doing a full average, use a weighted exponential type...much simpler, and in some ways, better (since it looks like an RC filter)..
I am measuring a ramp signal so the If>sum(x) will not work.
Ok, I think I have enough to go on for what I need.
Thanks all.  Solution marked
What does a ramp have to do with it?  You mean you need to display the value?
Yes, Long story.  Thanks.
JIm
