AS 7 - cpp and c library modules
8 posts / 0 new
Hi. I have Peter Fluery's UART library modules (uart.c and uart.h).  I can get this to work on a main.c program.
However, changing main.c to main.cpp (it's a simple main), results with compile error for the main.cpp.
Error        undefined reference to `uart_init(unsigned int)'    Test_UART    C:\u\AS_70\02_PeterF_Library\Test_UART - Copy\Test_UART\main.cpp    51
Likewise this error is repeated for all the other routines used in the library.
The Symbols and Directories are set the same for the C and C++ compilers.
The library is referenced as a link file (refer above).
Is there any basis problem(s) ?? Are there other steps for a C library to be use as a C++ library ??
Regards JC......
The ways to use 'C' code in a C++ project are well-documented, and not specific to Atmel Studio or even GCC
Try some googling something like, "mix C C++" ...
eg,  https://isocpp.org/wiki/faq/mixing-c-and-cpp
EDIT
That specific error will be because C++ expects the names to be "mangled" - which 'C' doesn't do.
https://en.wikipedia.org/wiki/Name_mangling#:~:text=In%20compiler%20construction%2C%20name%20mangling,in%20many%20modern%20programming%20languages.
Do you mean you've made a fluery_uart.a and you're linking against that ?
presumably not - as there's a uart.c source file in the project ?
I assumed he meant the source file was added to the project as a link:
EDIT
But that should make no difference to the C / C++ interfacing issue ...
The .cpp calling code must "know" the interface to the library functions so you have something like:
void uart_init(int speed);
void uart_sendchar(char c);
int main(void) {
    uart_init(1123);
    uart_sendchar('A');
but the declarations need to be:
extern "C" {
int main(void) {
 uart_init(1123);
 uart_sendchar('A');
To say " this C++ is calling across to C"
Hi.  Thank you.
My current situation is that with only doing;
extern "C" { uart.h }
I got the uart working (no compiler errors).
My current issue is that the program hangs with CAN0.begin().
Refer code below;
   uart_puts("String stored in SRAM\n");
   // Initialize the CAN controller
   // Baud rates define in mcp_can_dfs.h
   if (CAN0.begin(CAN_500KBPS) == CAN_OK)      // 500KBPS instead of 250KBPS
      uart_puts("CAN INIT OK for MonitorAndDiagnostics. \n\r\n\r");
      uart_puts("CAN INIT Failed.\n\r");
The string "String stored in SRAM" is sent but neither any one of the others.
This CAN library is a C++ source that is linked to like the uart.c.
Regards JC.......
Which suggests it is "stuck inside" .begin()
Either use a debugger, or follow the execution path through the library source and liberally sprinkle serial debug output.
The .begin() method calls SPI.begin() which is an Arduino class/object. Is SPI setup correctly ? Is the SPI slave-select pin set correctly in the CAN object constructor ?
It also calls many internal library methods that twiddle various register bits in the MCP2515.
