absolutely lost on OLED display
20 posts / 0 new
OK, I've spent a bunch of time (sadly way too much) trying to figure out how to get OLED text working with an ATmega328p.  So much stuff is for Arduinos, but I have a custom board coming in next week with a plain 328p.
It has been a number of years since I've worked with AVR products so I am still getting myself up to speed on AtmelStudio, etc.  I have one of the cheapo 0.96" 128x32 OLEDs.  All I want to be able to do is print some simple debug text to the screen.
Is there something that explains how to do this anywhere in AtmelStudio?  I've tried so many things (just attempting to build it), and can't even get a binary built.  I could use any help someone can point me to.  Just some simple text is all I want.
thanks!
Well, first look carefully at the datasheet, so you get a good understanding of what is needed.
Unfortunately you are not using a char display...so it is a much harder task.  A char display just requires to to send the ascii codes (along with some commands)...for example to show a "5" "8" , you send 0x35  0x38 ...the lcd figures out what pixels to light  up.
With a graphics LCD, YOU have to tell it what pixels to light...so your program has to also figure all those out.   Fortunately, you can prob find some libs where some of this character creation has been already figured out for you.
You should print debug info to the uart, maybe not the LCD screen...if you have any bugs the screen can easily quit working (a lot more complexity than the uart).\
do you even have an led blinking?  Start there!
No such thing...  Until you have a working driver, anyway.
Many of the small GLCDs do not have an internal memory map that you can read back to the micro, so what one sometimes does is set up an array in memory that mirrors the pixels on the display.
Your code writes to the memory map, and then you have one routine to write the memory map to the display, (full screen re-writes).
You need to understand how to initialize the display, which can be tricky in and of itself, and how to write your memory map to the display.
You can then write random junk to your memory map and see pixels show up on the display.
That is a huge accomplishment.
You can then create a "font" for your character set, and store that in an array.
Finally you have a routine that takes a string and writes each character's pixel map to the memory map, in sequential locations.
Start with a fixed width font where every character, whether it is a "I" or a "M", takes the same height and width, and write the characters to sequential character locations on a given row.
Later you can get fancy with arbitrary pixel starting locations, and variable size characters, although you might well never need that capability.
If you can find some Arduino code for you display and hardware connections then that is also a tremendous starting point, as you can make sure your hardware works!
You can also copy the start-up / initialization code for the display, so you know that you have that right.
From then on its just a matter of twiddling the bits the right way in software!
Well you could use this code for your OLED.   It doesn't have the 1024 byte SRAM buffer that is used by the Adafruit OLED library.
Here is the code for making an I2C-based SSD1306 OLED display work with the ATmega328P.
Start by adding all these define statements to your base code.  These give names to various
registers of the SSD:
// cut-and-paste the text below into your program.
#define SSD1306_CHAR_SIZE		   6
#define SSD1306_OLED_SLA7               0x3C     //  SSD1306 controller,  I2C slave address
#define SSD1306_LASTLINE                0x07
#define SSD1306_COMMAND                 0x00
#define SSD1306_DATA                    0xC0
#define SSD1306_DATA_CONTINUE           0x40
#define SSD1306_SET_CONTRAST_CONTROL    0x81
#define SSD1306_DISPLAY_ALL_ON_RESUME   0xA4
#define SSD1306_DISPLAY_ALL_ON          0xA5
#define SSD1306_NORMAL_DISPLAY          0xA6
#define SSD1306_INVERT_DISPLAY          0xA7
#define SSD1306_DISPLAY_OFF             0xAE
#define SSD1306_DISPLAY_ON              0xAF
#define SSD1306_NOP                     0xE3
#define SSD1306_HORIZONTAL_SCROLL_RIGHT 0x26
#define SSD1306_HORIZONTAL_SCROLL_LEFT  0x27
#define SSD1306_SCROLL_VERT_AND_RIGHT   0x29
#define SSD1306_SCROLL_VERT_AND_LEFT    0x2A
#define SSD1306_DEACTIVATE_SCROLL       0x2E
#define SSD1306_ACTIVATE_SCROLL         0x2F
#define SSD1306_SET_VERT_SCROLL_AREA    0xA3
#define SSD1306_SET_LOWER_COLUMN        0x00
#define SSD1306_SET_HIGHER_COLUMN       0x10
#define SSD1306_MEMORY_ADDR_MODE        0x20
#define SSD1306_SET_COLUMN_ADDR         0x21
#define SSD1306_SET_PAGE_ADDR           0x22
#define SSD1306_SET_START_LINE          0x40
#define SSD1306_SET_SEGMENT_REMAP       0xA0
#define SSD1306_SET_MULTIPLEX_RATIO     0xA8
#define SSD1306_COM_SCAN_DIR_INC        0xC0
#define SSD1306_COM_SCAN_DIR_DEC        0xC8
#define SSD1306_SET_DISPLAY_OFFSET      0xD3
#define SSD1306_SET_COM_PINS            0xDA
#define SSD1306_CHARGE_PUMP             0x8D
#define SSD1306_SET_CLOCK_DIV_RATIO     0xD5
#define SSD1306_SET_PRECHARGE_PERIOD    0xD9
#define SSD1306_SET_VCOM_DESELECT       0xDB
//  global variables that need to be unchanged between each call to OLED_SetCursor() and OLED_DisplayChar().
uint8_t         OLEDlineNumber = 0, OLEDcursorPos = 0;
// Next comes two font tables that go into 1K of flash. The first table is for 7x5 chars and
//  it is the same table found in most libraries of graphics-based display controllers.
//   After the 7x5 table is a second table for making big digit
//  chars that are three rows high.  {0..9, plus colon : and space chars)
//  Least-sig-bit on upper top side of char column.  Bytes go left to right.
 // Vertical pixel alignment: 475 bytes in flash.
const uint8_t FontTable[][FONT_SIZE] PROGMEM = {
        0x00, 0x00, 0x00, 0x00, 0x00,   // space 00   20 hexASCII
        0x00, 0x00, 0x2f, 0x00, 0x00,   // !     01   21
        0x00, 0x07, 0x00, 0x07, 0x00,   // "     02   22
        0x14, 0x7f, 0x14, 0x7f, 0x14,   // #     03   23
        0x24, 0x2a, 0x7f, 0x2a, 0x12,   // $     04   24
        0x23, 0x13, 0x08, 0x64, 0x62,   // %     05   25
        0x36, 0x49, 0x55, 0x22, 0x50,   // &     06   26
        0x00, 0x05, 0x03, 0x00, 0x00,   // '     07   27
        0x00, 0x1c, 0x22, 0x41, 0x00,   // (     08   28
        0x00, 0x41, 0x22, 0x1c, 0x00,   // )     09   29
        0x14, 0x08, 0x3E, 0x08, 0x14,   // *     10   2a
        0x08, 0x08, 0x3E, 0x08, 0x08,   // +     11   2b
        0x00, 0x00, 0xA0, 0x60, 0x00,   // ,     12   2c
        0x08, 0x08, 0x08, 0x08, 0x08,   // -     13   2d
        0x00, 0x60, 0x60, 0x00, 0x00,   // .     14   2e
        0x20, 0x10, 0x08, 0x04, 0x02,   // /     15   2f
        0x3E, 0x51, 0x49, 0x45, 0x3E,   // 0     16   30
        0x00, 0x42, 0x7F, 0x40, 0x00,   // 1     17   31
        0x42, 0x61, 0x51, 0x49, 0x46,   // 2     18   32
        0x21, 0x41, 0x45, 0x4B, 0x31,   // 3     19   33
        0x18, 0x14, 0x12, 0x7F, 0x10,   // 4     20   34
        0x27, 0x45, 0x45, 0x45, 0x39,   // 5     21   35
        0x3C, 0x4A, 0x49, 0x49, 0x30,   // 6     22   36
        0x01, 0x71, 0x09, 0x05, 0x03,   // 7     23   37
        0x36, 0x49, 0x49, 0x49, 0x36,   // 8     24   38
        0x06, 0x49, 0x49, 0x29, 0x1E,   // 9     25   39
        0x00, 0x36, 0x36, 0x00, 0x00,   // :     26   3a
        0x00, 0x56, 0x36, 0x00, 0x00,   // ;     27   3b
        0x08, 0x14, 0x22, 0x41, 0x00,   // <     28   3c
        0x14, 0x14, 0x14, 0x14, 0x14,   // =     29   3d
        0x00, 0x41, 0x22, 0x14, 0x08,   // >     30   3e
        0x02, 0x01, 0x51, 0x09, 0x06,   // ?     31   3f
        0x32, 0x49, 0x59, 0x51, 0x3E,   // @     32   40
        0x7C, 0x12, 0x11, 0x12, 0x7C,   // A     33   41
        0x7F, 0x49, 0x49, 0x49, 0x36,   // B     34   42
        0x3E, 0x41, 0x41, 0x41, 0x22,   // C     35   43
        0x7F, 0x41, 0x41, 0x22, 0x1C,   // D     36   44
        0x7F, 0x49, 0x49, 0x49, 0x41,   // E     37   45
        0x7F, 0x09, 0x09, 0x09, 0x01,   // F     38   46
        0x3E, 0x41, 0x49, 0x49, 0x7A,   // G     39   47
        0x7F, 0x08, 0x08, 0x08, 0x7F,   // H     40   48
        0x00, 0x41, 0x7F, 0x41, 0x00,   // I     41   49
        0x20, 0x40, 0x41, 0x3F, 0x01,   // J     42   4a
        0x7F, 0x08, 0x14, 0x22, 0x41,   // K     43   4b
        0x7F, 0x40, 0x40, 0x40, 0x40,   // L     44   4c
        0x7F, 0x02, 0x0C, 0x02, 0x7F,   // M     45   4d
        0x7F, 0x04, 0x08, 0x10, 0x7F,   // N     46   4e
        0x3E, 0x41, 0x41, 0x41, 0x3E,   // O     47   4f
        0x7F, 0x09, 0x09, 0x09, 0x06,   // P     48   50
        0x3E, 0x41, 0x51, 0x21, 0x5E,   // Q     49   51
        0x7F, 0x09, 0x19, 0x29, 0x46,   // R     50   52
        0x46, 0x49, 0x49, 0x49, 0x31,   // S     51   53
        0x01, 0x01, 0x7F, 0x01, 0x01,   // T     52   54
        0x3F, 0x40, 0x40, 0x40, 0x3F,   // U     53   55
        0x1F, 0x20, 0x40, 0x20, 0x1F,   // V     54   56
        0x3F, 0x40, 0x38, 0x40, 0x3F,   // W     55   57
        0x63, 0x14, 0x08, 0x14, 0x63,   // X     56   58
        0x07, 0x08, 0x70, 0x08, 0x07,   // Y     57   59
        0x61, 0x51, 0x49, 0x45, 0x43,   // Z     58   5a
        0x00, 0x7F, 0x41, 0x41, 0x00,   // [     59   5b
        0x55, 0xAA, 0x55, 0xAA, 0x55,   //       60   5c Backslash (Checker pattern)
        0x00, 0x41, 0x41, 0x7F, 0x00,   // ]     61   5d
        0x04, 0x02, 0x01, 0x02, 0x04,   // ^     62   5e
        0x40, 0x40, 0x40, 0x40, 0x40,   // _     63   5f underscore
        0x00, 0x03, 0x05, 0x00, 0x00,   // `     64   60 apostrophe
        0x20, 0x54, 0x54, 0x54, 0x78,   // a     65   61
        0x7F, 0x48, 0x44, 0x44, 0x38,   // b     66   62
        0x38, 0x44, 0x44, 0x44, 0x20,   // c     67   63
        0x38, 0x44, 0x44, 0x48, 0x7F,   // d     68   64
        0x38, 0x54, 0x54, 0x54, 0x18,   // e     69   65
        0x08, 0x7E, 0x09, 0x01, 0x02,   // f     70   66
        0x18, 0xA4, 0xA4, 0xA4, 0x7C,   // g     71   67
        0x7F, 0x08, 0x04, 0x04, 0x78,   // h     72   68
        0x00, 0x44, 0x7D, 0x40, 0x00,   // i     73   69
        0x40, 0x80, 0x84, 0x7D, 0x00,   // j     74   6a
        0x7F, 0x10, 0x28, 0x44, 0x00,   // k     75   6b
        0x00, 0x41, 0x7F, 0x40, 0x00,   // l     76   6c
        0x7C, 0x04, 0x18, 0x04, 0x78,   // m     77   6d
        0x7C, 0x08, 0x04, 0x04, 0x78,   // n     78   6e
        0x38, 0x44, 0x44, 0x44, 0x38,   // o     79   6f
        0xFC, 0x24, 0x24, 0x24, 0x18,   // p     80   70
        0x18, 0x24, 0x24, 0x18, 0xFC,   // q     81   71
        0x7C, 0x08, 0x04, 0x04, 0x08,   // r     82   72
        0x48, 0x54, 0x54, 0x54, 0x20,   // s     83   73
        0x04, 0x3F, 0x44, 0x40, 0x20,   // t     84   74
        0x3C, 0x40, 0x40, 0x20, 0x7C,   // u     85   75
        0x1C, 0x20, 0x40, 0x20, 0x1C,   // v     86   76
        0x3C, 0x40, 0x30, 0x40, 0x3C,   // w     87   77
        0x44, 0x28, 0x10, 0x28, 0x44,   // x     88   78
        0x1C, 0xA0, 0xA0, 0xA0, 0x7C,   // y     89   79
        0x44, 0x64, 0x54, 0x4C, 0x44,   // z     90   7a
        0x00, 0x10, 0x7C, 0x82, 0x00,   // {     91   7b
        0x00, 0x00, 0xFF, 0x00, 0x00,   // |     92   7c
        0x00, 0x82, 0x7C, 0x10, 0x00,   // }     93   7d
        0x00, 0x06, 0x09, 0x09, 0x06};  // ~     94   7e
const uint8_t BigDigitFont[][36] PROGMEM = { // each SSD1306 data byte is 8 vertical pixels.
// 12 columns * 3 rows = 36 bytes per digit [ * 12 digit characters__432 bytes total ]
//         0    1    2    3    4    5    6    7    8    9   10   11
	0xfc,0xfe,0xfe,0x0f,0x07,0x07,0x07,0x07,0xcf,0xfe,0xfc,0xf8,  // character '0'
	0xff,0xff,0xff,0xf0,0x78,0x3c,0x1e,0x0f,0x07,0xff,0xff,0xff,  //
	0x3f,0x7f,0x7f,0xf8,0xf0,0xf0,0xf0,0xf0,0xf8,0x7f,0x7f,0x1f,  //
	0x00,0x00,0x40,0x60,0x70,0x78,0xfc,0xfe,0xff,0xff,0x00,0x00,  // character '1'
	0x00,0x00,0x00,0x00,0x00,0x00,0xff,0xff,0xff,0xff,0x00,0x00,  //
	0x38,0x3c,0x3e,0x0f,0x07,0x07,0x07,0x0f,0x1f,0xff,0xfe,0xfc,  // character '2'
	0xc0,0xe0,0xe0,0xf0,0x78,0x78,0x3c,0x1e,0x0f,0x0f,0x07,0x03,  //
	0xff,0xff,0xff,0xf0,0xf0,0xf0,0xf0,0xf0,0xf0,0xf0,0xf0,0xf0,  //
	0x38,0x3c,0x1e,0x0f,0x0f,0x0f,0x0f,0x0f,0x1e,0xfc,0xf8,0xf0,  // character '3'
	0x00,0x00,0x00,0x1e,0x1e,0x1e,0x1e,0x3e,0xff,0xff,0xe7,0x80,  //
	0x78,0xf8,0xf0,0xf0,0xf0,0xf0,0xf0,0xf0,0xf8,0xff,0x7f,0x1f,  //
	0x00,0x00,0x00,0x00,0x00,0xc0,0xf0,0xf8,0x7e,0xff,0xff,0xff,  // character '4'
	0xe0,0xf0,0xf8,0xbe,0x9f,0x8f,0x83,0x81,0x80,0xff,0xff,0xff,  //
	0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0x03,0xff,0xff,0xff,  //
	0xff,0xff,0xff,0x87,0x87,0x87,0x87,0x87,0x87,0x07,0x07,0x07,  // character '5'
	0x07,0x07,0x03,0x03,0x03,0x03,0x03,0x03,0x07,0xff,0xff,0xfc,  //
	0x3c,0x7c,0x78,0xf0,0xf0,0xf0,0xf0,0xf0,0x78,0x7f,0x3f,0x1f,  //
	0xf8,0xfc,0xfe,0x0f,0x07,0x07,0x07,0x07,0x07,0x0f,0x1e,0x1c,  // character '6'
	0xff,0xff,0xff,0x1e,0x0e,0x0e,0x0e,0x0e,0x1e,0xfe,0xfc,0xf8,  //
	0x3f,0x7f,0x7f,0xf0,0xe0,0xe0,0xe0,0xe0,0xf8,0x7f,0x3f,0x1f,  //
	0x07,0x07,0x07,0x07,0x07,0x07,0x07,0x07,0xff,0xff,0xff,0xff,  // character '7'
	0x00,0x00,0x00,0x00,0x80,0xe0,0xf8,0xfe,0x7f,0x1f,0x0f,0x03,  //
	0x00,0xc0,0xf0,0xfe,0xff,0x1f,0x07,0x01,0x00,0x00,0x00,0x00,  //
	0xf8,0xfe,0xff,0x07,0x07,0x07,0x07,0x07,0x8f,0xff,0xfe,0x78,  // character '8'
	0xe0,0xff,0xff,0x1f,0x0e,0x0e,0x0e,0x1f,0x3f,0xff,0xf9,0xe0,  //
	0x1f,0x7f,0x7f,0xf0,0xe0,0xe0,0xe0,0xf0,0x78,0x7f,0x3f,0x1f,  //
	0xfc,0xfe,0xff,0x0f,0x07,0x07,0x07,0x07,0x0f,0xff,0xfc,0xf8,  // character '9'
	0x1f,0x3f,0x3f,0x7c,0x78,0x78,0x78,0x78,0x3c,0xff,0xff,0xff,  //
	0x00,0x70,0xf0,0xf0,0xf0,0xf0,0x70,0x78,0x7c,0x3f,0x3f,0x0f,  //
	0x00,0x00,0x00,0x60,0xf0,0xf8,0xf8,0xf0,0x60,0x00,0x00,0x00,  // character ':'
	0x00,0x00,0x00,0x00,0x80,0xc1,0xc1,0x80,0x00,0x00,0x00,0x00,  //
	0x00,0x00,0x00,0x03,0x07,0x0f,0x0f,0x07,0x03,0x00,0x00,0x00,  //
	0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,  // character ' '
	0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00 };
//  here are the functions for using the SSD1306, followed by documentation.
//~~~~~~~~~~~~~~~~~~~~~~~LOW-level OLED_I2C  @ 180 lines of code ~~~~
void i2c_initialise()  {   //  should called at the beginning of main() {Arduino:  by setup() when not using Wire.h}
        TWBR = 12;         //  400KHz   use 0x62 = @80KHz
        TWSR = 0x01;
        TWCR = (1<<TWEN);
}//~~~~~~~~~~~~~~~~~~~~~ LOW-level OLED_I2C ~~~~~~~~~~~~~~~~~~~~~~~~
void OLED_sendCommand(uint8_t myCmd)   {
        TWCR=((1<<TWINT)|(1<<TWSTA)|(1<<TWEN)); // send START
        while(!(TWCR & (1 << TWINT)));  // delay until TWINT set
        TWDR = OLED_SLA7 << 1;   // send SLA    8-bit SLAw = 0x78
        TWCR = ((1<<TWINT)|(1<<TWEN)); while(!(TWCR & (1<<TWINT)));
        TWDR = SSD1306_COMMAND; // send D/C_sentinel byte for command:0x00
        TWDR = myCmd;   // I2C write, wait until completed
        TWCR = ( (1<<TWINT)|(1<<TWEN)|(1<<TWSTO) ); // I2C STOP
void OLED_clear() {
        OLED_sendCommand(SSD1306_SET_COLUMN_ADDR);   // opcode:0x21
        OLED_sendCommand(0);     // start at left edge of screen
        OLED_sendCommand(127);   // end at right edge of screen
        OLED_sendCommand(SSD1306_SET_PAGE_ADDR);     // opcode:0x22
        OLED_sendCommand(0);     // start at the top row
        OLED_sendCommand(7);     // end at the bottom row
        TWDR = SSD1306_DATA_CONTINUE;   // send D/C sentinal byte 0x40
        // TWI NOT using Wire.h   128 bytes (8 bits vertical) per row * 8 char rows = 1024
        // Send 64 TWI messages { START:SLAw:0x40:16 bytes of 0x00:STOP }  1024 data bytes total
        for (uint16_t scrClearIndex=0; scrClearIndex<1024; scrClearIndex++) {  // (SSD1306_LCDWIDTH*SSD1306_LCDHEIGHT/8)
            TWDR = OLED_SLA7 << 1;   // 8-bit SLAw = 0x78
            TWCR = ((1<<TWINT)|(1<<TWEN)); while(!(TWCR & (1<<TWINT))); // TX?done delay
            TWDR = 0x40;  // send D/C_sentinal byte for data stream
            for (uint8_t x=0; x<16; x++) {
                TWDR = 0x00;  // all eight pixels in the column are off.
                scrClearIndex++;  // 16 bytes per I2C transmission__64 transmissions per screen
            scrClearIndex--;
void OLED_Init(void) {  // cmd: send START, 8bitSLA, D/C sentinel=0x00, command_value, STOP
        OLED_sendCommand(SSD1306_DISPLAY_OFF);          //   0xAE
        OLED_sendCommand(SSD1306_SET_CLOCK_DIV_RATIO);  //   0xD5
        OLED_sendCommand(0x80);                         //   0x80
        OLED_sendCommand(SSD1306_SET_MULTIPLEX_RATIO);  //   0xA8
        OLED_sendCommand(0x3F);                         //   0x3F
        OLED_sendCommand(SSD1306_SET_DISPLAY_OFFSET);   //   0xD3
        OLED_sendCommand(0x0);                          //   0x00
        OLED_sendCommand(SSD1306_SET_START_LINE | 0x00); //   0x40
        OLED_sendCommand(SSD1306_CHARGE_PUMP);          //   0x8D
        OLED_sendCommand(0x14);                         //   0x14
        OLED_sendCommand(SSD1306_MEMORY_ADDR_MODE);     //   0x20
        OLED_sendCommand(0x00);                         //   0x00
        OLED_sendCommand(SSD1306_SET_SEGMENT_REMAP | 0x01);// 0xA1
        OLED_sendCommand(SSD1306_COM_SCAN_DIR_DEC);     //   0xC8
        OLED_sendCommand(SSD1306_SET_COM_PINS);         //   0xDA
        OLED_sendCommand(0x12);                         //   0x12
        OLED_sendCommand(SSD1306_SET_CONTRAST_CONTROL); //   0x81
        OLED_sendCommand(0xCF);                         //   0xCF
        OLED_sendCommand(SSD1306_SET_PRECHARGE_PERIOD); //   0xD9
        OLED_sendCommand(0xF1);                         //   0xF1
        OLED_sendCommand(SSD1306_SET_VCOM_DESELECT);    //   0xDB
        OLED_sendCommand(0x40);                         //   0x40
        OLED_sendCommand(SSD1306_DISPLAY_ALL_ON_RESUME);//   0xA4
        OLED_sendCommand(SSD1306_NORMAL_DISPLAY);       //   0xA6
        OLED_sendCommand(SSD1306_DISPLAY_ON);           //   0xAF
        OLED_clear();
}//~~~~~~~~~~~~~~~~~~~~~~ LOW-level OLED_I2C ~~~~~~~~~~~~~~~~~~~~~
void OLED_SetCursor(uint8_t myLineNumber,uint8_t myColumnPosition) {
        if( (myLineNumber <= SSD1306_LASTLINE) && (myColumnPosition <= 127) ) {
            OLEDlineNumber = myLineNumber;     // global var: current line number
            OLEDcursorPos =  myColumnPosition; // global var: current cursor position
            OLED_sendCommand(myColumnPosition);
            OLED_sendCommand(myLineNumber);
            TWDR = OLED_SLA7 << 1;   // 8-bit SLAw = 0x78  7-bitSLA=0x3C  SSD1306 controller
            TWDR = SSD1306_DATA_CONTINUE;   // 0x40
            TWCR = ((1<<TWINT)|(1<<TWEN)); while(!(TWCR & (1<<TWINT)));  // TWINT?set delay
}//~~~~~~~~~~~~~~~~~~~~~~ LOW-level OLED_I2C ~~~~~~~~~~~~~~~~~~~~~~~
void OLED_GoToLine(uint8_t myLine) {
        if( myLine < 8) {
            OLEDlineNumber = myLine;
            OLED_SetCursor(OLEDlineNumber, 0);
void OLED_GoToNextLine() {      // Increment and roll-over the current line number.
        OLEDlineNumber++;       // global var for current line number
        OLEDlineNumber = OLEDlineNumber & 0x07; // roll-over back to top after 8 lines
}//~~~~~~~~~~~~~~~~~~~~~~ LOW-level OLED_I2C ~~~~~~~~~~~~~~~~~~~~~~~~~~
void OLED_DisplayChar(uint8_t myDisplayChar) {
        uint8_t charColumnBitMap, charBitMapIndex = 0;
        if(((OLEDcursorPos + 5) >= 128) || (myDisplayChar=='\n')) { // font size=5
//      If the line has no more room for complete chars OR NewLine command,
//      then move the cursor to next line
            OLED_GoToNextLine();
        if(myDisplayChar != '\n') {
            myDisplayChar = myDisplayChar - 0x20; // As the lookup table starts from Space(0x20)
            while(1) {
               charColumnBitMap = pgm_read_byte(&FontTable[myDisplayChar][charBitMapIndex]);
               TWDR = charColumnBitMap;
               OLEDcursorPos++;
               charBitMapIndex++;
               if( charBitMapIndex == 5) {   // Exit the loop after sending five bytes
                  TWDR = 0x00;  // last column of char is one column of space between chars.
                  OLEDcursorPos++;
                  break;
}//~~~~~~~~~~~~~~~~~~~~~ LOW-level OLED_I2C ~~~~~~~~~~~~~~~~~~~~~~~~~~
void OLED_DisplayString(uint8_t *ptr) {
        while(*ptr) OLED_DisplayChar(*ptr++);
void displayBigDigit(uint8_t myDigit, uint8_t myDigitRow, uint8_t myDigitColumn) {
        uint8_t charColumnBitMap, columnIndex = 0, rowIndex = 0, fullDigitIndex=0;
        if ( (myDigitRow <= 5) && (myDigitColumn <= 116) ) { // full digit gets displayed
            if (myDigit >= 0 && myDigit <= 9 ) {
              for (rowIndex=0; rowIndex<3; rowIndex++) {
                 OLED_SetCursor(myDigitRow + rowIndex, myDigitColumn);
                 for (columnIndex = 0; columnIndex < 12; columnIndex++) {
                    charColumnBitMap = pgm_read_byte(&BigDigitFont[myDigit][fullDigitIndex]);
                    fullDigitIndex++;
            if (myDigit == 10 ) {
                      charColumnBitMap = pgm_read_byte(&BigDigitFont[10][fullDigitIndex]);
                      fullDigitIndex++;
            }	// myDigit 10
            if (myDigit == 11 ) {
                      charColumnBitMap = pgm_read_byte(&BigDigitFont[11][fullDigitIndex]);
                      fullDigitIndex++;
            }   // myDigit 11
        }   // myDigitRow  5..116
/* OLED display techniques:  numbers; flash strings, bitmaps;
Numbers:  Values that change and need to be updated:
            uint8_t myBuffer[22];
            OLED_SetCursor(0, 11 * CHAR_SIZE); //=6   top line 0, mid-screen char (0-20)
            itoa(integer_Variable_Name, myBuffer, 10);   // use dtostrf() for floats
            OLED_DisplayString(myBuffer);
Individual Characters
-----------OLED_DisplayChar(uint8_t myDisplayChar);
SRAM strings
-----------OLED_DisplayString(uint8_t *ptr);
Constant Number values in program memory:
----------- uint16_t workFMfreq, myFMpresetFreq;
            float displayFMfrequency ;
            byte highFMreg3, lowFMreg3, myBuffer[8];
            OLED_SetCursor(7, 16 * 6); // CHAR_SIZE=6   bottom line 7, right screen char (0-20)
            myFMpresetFreq = pgm_read_word(&FMstationPreset[currentFMstationIndex]);
            displayFMfrequency  =  (float) myFMpresetFreq / 100;
            dtostrf(displayFMfrequency,4,1, myBuffer); // 4 chars, 1 digit after dec point
            OLED_DisplayString(myBuffer); // dtostrf(value,strSize,decPtCnt,buffer);
Flash strings:  constant strings that are stored in program memory:
const char String00[] PROGMEM = "KFBW";   //  FM _The Buzz
const char String01[] PROGMEM = "KLTH";   //  The Eagle
const char String02[] PROGMEM = "KXRY";   //  progressive independent
const char String03[] PROGMEM = "KXJM";   //  Jam'n 1075
const char * const  StringArray[ 4 ] PROGMEM = {String00, String01, String02, String03};
            uint8_t myBuffer[22], *myPtrToFlashString;
            OLED_SetCursor(2,0 * 6);  // = 6    starting row:char column pixel
            myPtrToFlashString = (char *) pgm_read_word (& StringArray
); strcpy_P ((char *) myBuffer, myPtrToFlashString); OLED_DisplayString(myBuffer); ----------- BitMaps: used for real-time clock's hours:minutes display: //offset 0-11; row 0-5; BIGDIGITSPACING=15 ----------- displayBigDigit(digit_offset, 5, 1 * BIGDIGITSPACING); */ //~~~~~~~~~~~~~~~~~~~~~~~~~~~~ LOW-level OLED_I2C ~~~~~~~~~~~~~~~~~~~~~~~~~
Hi folks, thanks for everyone's insights!
You are right, I was using poor terminology.  My point was more that I am not interested in graphics or animations, just simple text.  I brought it up because some of the implementations are designed for that to be more lightweight and not require huge amounts of buffer memory.
I actually had no plans to use an OLED, so it was a last minute thought.  I had planned on using a serial terminal for comms with my actual board, but I am going to be connecting the AVR to some high voltage stuff (isolated of course) and through I am not worried about the micro in general, on the off chance there is an issue, I didn't really want my laptop connected to it.  I went looking for IIC/SPI 3.3V solutions and sadly the OLED was the only thing I could come up with.  I just need it for initial debugging, so I was hoping to toss it onto the SPI port, use it for a week, and then move on.
If someone has some other thoughts, I am all ears.  Worst case, I punt on the OLED for now and just write to EEPROM, and read it off after the fact.
I'll take a look at that file you linked in, thanks.  I am pretty sure it was one of the 100s I've played with at this point, but I should have done a better job keeping track....... :)
A traditional hd44780 character LCD panel with an I2C backpack would be much easier.
A plain mega328 will happily accept an Arduino generated hex file.
Then why didn't you get a char display ???!!!?--it would be 1000 times easier.. just send the ascii codes (preceeded by a couple of command codes) & see your message pop up!
It's like just putting on a pair of socks vs having to weave a pair of socks first.
I absolutely agree, but it seems they all want to run on 5V, and I will be working off of 3.3V.
I hear you, it was just that it was the only thing I could find that I had any confidence in it working at 3.3V.  All of the 16x2 displays I've found look like they need 5V, and I won't have that available on my board.
Really?  I had no idea (I am not being sarcastic).  I've never looked into it, but I guess the only difference really is the bootloader
And a follow up (which I can't find an answer to), if I have an arduino hex file (for instance), can I burn that directly onto a 328p with an ICSP and skip the bootloader?  Just something I've never thought about before.....
There’s nothing magic about Arduino. The bootloader is there for convenience. Apart from loading the code, there is no reliance on it
toozie21 wrote:
I had planned on using a serial terminal for comms with my actual board, but ... I didn't really want my laptop connected to it.
USB CDC ACM via a USB isolator, or, logic analyzer via a USB isolator iff the isolation voltage is greater than the high voltage; otherwise, LED UART (somewhat slow)
P.S.
toozie21 wrote:
... and not require huge amounts of buffer memory.
Concur as small OLED have frame RAM in the display controller.
Protocol decoder:uart - sigrok
Very Low-Cost Sensing and Communication Using Bidirectional LEDs | Publication - TR2003-35 | Mitsubishi Electric Research Laboratories
via
Bi-directional LED communication | Tools and Tips | The Embedded Muse 385
though optically seal :
The Embedded Muse 386 | Tools and Tips
832WC - Optically Clear Epoxy - MG Chemicals | MG Chemicals
64x48 Small Graphic OLED from Crystalfontz
though its given source code is entire frames instead of regions or characters.
I bought one one these toys some time ago:
ESP8266-IOT-OLED
The OLED may be similar to your OLED. As such; this Arduino library https://www.arduino.cc/reference//en/libraries/esp8266-oled-display-library/ may be useful. It's a really simple library (i.e. no graphics) but of course there are many other libraries available if you outgrow that one.
ESP8266-IOT-OLED
Very interesting, that sounds a lot like what I wanted. I am going to check it out today, thanks..
I think I was in the same boat as you a little while ago.    I had a bunch of LCDs already, but picked up a few more with the backlight and the serial adapter for TWI.   Works great, an I'm moving right along with C and Atmel stuff (provided I have the correct datasheets!!!).   I do want to get a few of those small OLED displays, but not ready for graphics yet.   Baby steps, baby steps.
Just gettin' started, again....
I started out a PIC guy, then used Arduino a lot more recently. This board has an ATMega, so it is forcing me back to looking into it, and now I remember how different the Atmel stuff can be. It feels like its own little beast.
Which version of TWI did you go with?
I don't really understand the problem here as long as you take a methodical approach. If you don't want to use the graphic capability to show "pictures" then all you need is to develop some set_pixel(x,y, ON|OFF) that allows you to control the state of any pixel. Then you develop a draw_grid_of_pixels(x,y,w,h) though maybe you fix w/h at 8x8 or 5x7 or something. Then you define grid patterns for all of 0..9, a..z, A..Z (and punctuation). And now you simply move x across in 8's or 5's or whatever and up and down in 7's or 8's or whatever and you can draw any character pattern at any "large scale" character location. At this stage you have something very similar to an HD44780 anyway!
Controlling most displays is little more than writing 3 functions:
lcd_command()
lcd_data()
lcd_init()
Everything else can be built on top of these low-level functions.    And reading the appropriate datasheet that describes any hardware commands.
Otherwise,   you are drawing pixels in different colours.  (or black / white)
And a letter is just a set of pixels from a Font.   (which may be part of the hardware)
God gave you the Arduino.  I suggest that you buy and experiment with an Arduino first.     It is 99% likely that there is already Arduino libraries and examples for your specific display hardware.
Study the code.   You will see that it all builds on top of the primitive lcd_command(), lcd_data() ...
You can write your own primitives e.g. for different AVR, PIC, ARM model
And the high level graphics will just run.
