Rpi SPI (Master) to Atmega1281 SPI (Slave) Communication Does not works.
6 posts / 0 new
I want to communicate Rpi SPI with Atmega1281 hardware SPI module. Rpi is Master configured and Atmega1281 slave. I want to read and write data from Rpi to Atmega1281.
I am using following code on Rpi side.
// spi.c
// Example program for bcm2835 library
// Shows how to interface with SPI to transfer a byte to and from an SPI device
// After installing bcm2835, you can build this
// with something like:
// gcc -o spi spi.c -l bcm2835
// sudo ./spi
// Or you can test it before installing with:
// gcc -o spi -I ../../src ../../src/bcm2835.c spi.c
// sudo ./spi
// Author: Mike McCauley
// Copyright (C) 2012 Mike McCauley
// $Id: RF22.h,v 1.21 2012/05/30 01:51:25 mikem Exp $
#include <bcm2835.h>
#include <stdio.h>
int main(int argc, char **argv)
    // If you call this, it will not actually access the GPIO
// Use for testing
//        bcm2835_set_debug(1);
    if (!bcm2835_init())
      printf("bcm2835_init failed. Are you running as root??\n");
      return 1;
    if (!bcm2835_spi_begin())
      printf("bcm2835_spi_begin failed. Are you running as root??\n");
      return 1;
    bcm2835_spi_setBitOrder(BCM2835_SPI_BIT_ORDER_MSBFIRST);      // The default
    bcm2835_spi_setDataMode(BCM2835_SPI_MODE0);                   // The default
    bcm2835_spi_setClockDivider(BCM2835_SPI_CLOCK_DIVIDER_65536); // The default
    bcm2835_spi_chipSelect(BCM2835_SPI_CS0);                      // The default
    bcm2835_spi_setChipSelectPolarity(BCM2835_SPI_CS0, LOW);      // the default
    // Send a byte to the slave and simultaneously read a byte back from the slave
    // If you tie MISO to MOSI, you should read back what was sent
    uint8_t send_data = 0x31;
    uint8_t read_data = bcm2835_spi_transfer(send_data);
    printf("Sent to SPI: 0x%02X. Read back from SPI: 0x%02X.\n", send_data, read_data);
    if (send_data != read_data)
      printf("Do you have the loopback from MOSI to MISO connected?\n");
    bcm2835_spi_end();
    bcm2835_close();
    return 0;
*The Rpi code works loopback *
And the below code is on Atmega1281 Hardware SPI module:
#include <stdio.h>
#include <stdlib.h>
#include <util/delay.h>
#include "SPI.h"
void SPI_Init()
    char clear = 0;
    PRR0 = (1<<PRSPI);
    DDRB |= 0xF0;
    SPCR |= 0x00;                   // SPI slave Mode = 0
    DDRB |= (1<<DDB3);              // MISO as Output
    SPCR |= ((1<<SPE)|(1<<SPIE));   // Enable SPI and SPI Interrupt
    clear = SPDR;
    clear = SPSR;
    SREG |= (1<<SREG_I);        // Enable Global interrupt
void SPI_write(char val)
    char data = 0;
    SPDR = val;
    while(!(SPSR & (1<<SPIF)))
    data = SPDR;
char SPI_read()
    char value = 0;
    //SPDR = 0xff;
    value = SPDR;
    return value;
void main()
         value = SPI_read();
         SPI_write(value);
But i am not getting any data on Rpi side..
Any Help/
Rakesh
Rakesh Patel
Please see Tip #1 in my signature, below, for how to properly post source code.
What testing / debugging / investigation have you done to find what's going on ?
Are you sure that your hardware connections are correct? Post your schematic (again, see Tip #1).
Are you sure that the RPi logic levels are compatible with your AVR ?
How have you proved that the RPi code is working on its own ? Does it work with a "standard" slave ?
How have you proved that the AVR code is working on its own ?
Have you used an oscilloscope or logic analyser to see what - if anything - is actually happening on the wires ?
etc, etc, ...
 Yes Its working with arduino Due card as slave and i am getting data in Rpi using same code.
 I think I need to improve the Atmega1281 Code.
Any Help/
Rakesh
Rakesh Patel
You enable the spi interrupt but there is no isr. Your code will crash. Do not set spie.
Thank Mate,
It working now.. working code is as per below.:
void SPI_Init()
    DDRB |= 0xF0;
    SPCR |= (1<<SPE);   // Enable SPI and SPI Interrupt
    SPDR = val;
    while(!(SPSR & (1<<SPIF)));
    clear = SPDR;
char SPI_read()
    char value = 0;
    value = SPDR;
    return value;
void main()
    SPI_Init();
      value = SPI_read();
      SPI_write(value);
Thanks For your Support.
Rakesh
Rakesh Patel
The below code works in Interrupt routine.. Rpi send receive the data using below slave code.
void SPI_Init()
    DDRB &=~(1<<DDB0);          // CS as input
    DDRB &=~(1<<DDB1);          // SCK as input
    DDRB &=~(1<<DDB2);          // MOSI as input
    DDRB |= (1<<DDB3);          // MISO as output
    SPCR &=~(1<MSTR);           //SPI as slave
    SPCR |= (1<<SPIE);          // SPI Interrupt Enable.
    SPCR  |= (1<<SPE);          // SPI Enable
    sei();                      // Global Interrupt enable
ISR (SPI_STC_vect)
    SPIFalg = 1;
    retvalue = SPDR;
    SPDR = retvalue;
int  main() {
    SPI_Init();
        if(retvalue == 0x87)
            PORTF = 0x00;
            PORTF = 0x02;
Rakesh Patel
