How to use avr-libc in Atmel Studio ?
3 posts / 0 new
I tried Atmel Studio, I found it like CodeBlocks - an IDE.
When I used CodeBlocks, I need to install gcc and set the path in it.
So, my question is, need I install gcc and avr-libc library in Atmel Studio before I write c++ program for Atmega MCU ?
No - it is all included in the Atmel Studio installation.
MianQi wrote:
for Atmega MCU
The installer will ask you which microcontroller family/ies you want installed
As Andy says, your copy of AS7 already comes with the avr-gcc toolchain and all the library support that requires (with all paths to it preconfigured and so on) at this location:
 Directory of C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\avr8\avr8-gnu-toolchain\avr
10/10/2019  13:31    <DIR>          .
10/10/2019  13:31    <DIR>          ..
10/10/2019  13:31    <DIR>          bin
10/10/2019  13:31    <DIR>          include
10/10/2019  13:31    <DIR>          lib
               0 File(s)              0 bytes
               5 Dir(s)  219,135,008,768 bytes free
So there's nothing to do apart for File-New Project and simply get on with programming as all the complex IDE configuration stuff has already been done.
