programming language c using atmega328p
69 posts / 0 new
Pages
I'm talking about this part of the task.
The robo1 () function is implemented - you just have to use it.
Implement the program for Robot 1 which:
Executes the function robo1 () periodically with a period of 1 sec. --------How is a function executed periodically with a period of 1 sec?
At the end of the function execution, it sends the return value of the function via UART to Robot 2 (assuming that robots 1 and 2 are connected to each other via a serial communication line
through UART) to implement the periodic execution to be used interrupt Service and Output Compare Timer interrupt in normal mode (free running)------------------How?
Select the parameters for communication via UART with the maximum speed for communication which support the controller in question. Implement parity bit for error checking.
The use of Arduino IDE functions is not allowed and the use of delay () functions is not allowed. The oscillator frequency is 4 Mhz----------------------------------------------------------How?
roboti1.c
unsigned char robo1(void);
int init_robo1 (void) {
int main (void) {
M.K
This parti
Executes the function robo1 () periodically with a period of 1 sec ------------------------Si ekzekutohet nje funskionin ne menyre periodike me nje periode prej 1 sec?
At the end of the function execution, it sends the return value of the function via UART to Robot 2 (assuming that robots 1 and 2 are connected to each other via a serial communication line through UART) to implement the periodic execution to be used interrupt Service and Output Compare Timer interrupt in normal mode (free running)------------------------------------------How?
The use of Arduino IDE functions is not allowed and the use of delay () functions is not allowed. The oscillator frequency is 4 Mhz-------------------------------------------------------How?
roboti1.c
int main (void) {
M.K
Metro1 wrote:
This is my goal to continue my specialization in server programming after being accepted to the University, but I must first pass the exam in embedded.
A-Ha this thread has developed a new twist since I last posted.
Can we assume you have zero interest in embedded programming ? This is totally understandable, I used to work amongst programmers who were adept with AngularJS but couldn't program AVR for toffee. (even when given Arduino)
Here's a radical thought; what happens if you simply fail the embedded section of the entrance exam but ace those sections that are pertinent to back-end server coding.
Metro1 wrote:
Please guys
Will you help me solve the first part of the task that has to do with the robot1?
I'm tired of trying but not understanding the part with UART and TIMER.
I thought you would give me the motivation to continue learning for the entrance exam in Computer Science.
I already showed you the high level of the structure for this in #29. All that remains is to add the detail to that. That will involve programming UART and timer. You say you are "tired of trying"? Well I guess it depends how desperately you want to join this course. But consider this: you actually state that this is the paper from a previous year. So assuming you work away at this and learn about timer and UART and then you find that in "this years paper" they actually set a task involving ADC and SPI how are you going to get on with that? The bottom line is that you probably need to have done the entire course that the other entrants have done. Learned about ADC, I2C, Comparator, timer (CTC and PWM), UART, SPI and all the other AVR peripherals that they likely were taught about. Then, when this years exam turns out to be I2C and PWM you will be prepared.
Or are you really hoping they just set the same robo1()/robo2() question every year? It's a bit of gamble!
That is answered for you:
So have you tried googling those terms?
http://www.lmgtfy.com?q=Timer+Output+Compare+Interrupt+Service
Which controller is that?
Add its model number to your google search ...
Please guys
We wouldn't want to give you the wrong advice, so you must list everything you have learned so far about embedded programming, with a brief explanation and example of each concept.
I'm tired of trying but not understanding the part with UART and TIMER.   IF YOU ARE TIRED OF TRYING THAT DOESN'T BODE WELL
I thought you would give me the motivation to continue .  SORRY IT DOESN'T WORK THAT WAY
So if you needed to update a web page once a second, how would you do that?
show the code needed please!
jim
Keys to wealth:
Hello can you tell me if this first part of the task I have given is good
#include<avr/interrupt.h>
#define F_OSC 4000000
#DEFINE PRESCALER 1024
#define TCS_PER_INTERVAL(F_OSC/PRESCALER)
#define BAUD 9600
#DEFINE MYUBERR (F_OSC/16/BAUD-1)
voltile unsigned int sec;
volatile unsigned char value;
ISR(TIMER1_COMPA_vect){
    sex++;
    OCRIA+= TICS_PER_INTERVAL'
    value=init_robo1();
    usartWrite(value);
void usartWrite(unsigned char data)
while(!(UCSR0A &(1<< UDRE0)));
UDR0=data;
void init(void)
//UART
UBRROH =MYUBRR>>8;
UBRROL= MYUBRR & 0x00FF;
UCSR0B = 1<<TXEN0;
UCSROC |=(1<<UPM00)|(1<<UPM01);
UCSR0C |=(1<<UCSZ00)|(1<<UCSZ01);
UCSR0C |=0<<USBS0
//TIMER
TCCR1A|=1<<COM1A0;
TCCR1B|=(1<<CS12)|(1<<CS10);
OCR1A=TICS_PER_INTERVAL;
TIMSKI|=1<<OCIE1A;
sei();
int init_robo1(void)
    sec=0;
    init();
    while(1){
M.K
#define BAUD 9600
    sex++;
    value=init_robo1();
    usartWrite(value);
UDR0=data;
void init(void)
//UART
UBRROH =MYUBRR>>8;
UCSR0B = 1<<TXEN0;
UCSR0C |=0<<USBS0
//TIMER
TCCR1A|=1<<COM1A0;
TIMSKI|=1<<OCIE1A;
sei();
    sec=0;
    init();
    while(1){
M.K
#define BAUD 9600
    sex++;
    value=init_robo1();
    usartWrite(value);
UDR0=data;
void init(void)
//UART
UBRROH =MYUBRR>>8;
UCSR0B = 1<<TXEN0;
UCSR0C |=0<<USBS0
//TIMER
TCCR1A|=1<<COM1A0;
TIMSKI|=1<<OCIE1A;
sei();
    sec=0;
    init();
    while(1){
M.K
You've been pointed to the Tips in my signature already - Tip #1 shows you how to properly post source code.
Put comments in the code which describe what you think the code should be doing.
Do just one thing at a time; eg, timer first; UART next.
Metro1 wrote:
sex++;
laugh laugh laugh laugh
Go on - you clearly haven't even tried to compile it yourself.
You could use the Simulator in Atmel Studio to see how it runs (although it runs an order of magnitude slower than real time) ...
hahhahahhaah noo sex++
sec++
M.K
At it's simplest:
function myreloader() {
  location.reload();
setTimeout(myreloader, 1000);
Which partly illustrates my point above - these web guys just cant be a**ed with F_CPU or configuring registers.
I would like to mention that when you set up one of those network servers, they tend to have serial interfaces (e.g., UARTs at least that was how telecom machines were), they did not have screens or keyboards. So if you ever need to provision such a server to develop on, then the knowledge of how a UART works would be handy. The R-Pi has figured out a way around the provisioning problem, but that in itself is a topic.
Hello everyone
I thank you for the advice you have given me to solve the task, by practicing those tips I have managed to solve the task.
This task was not a task that is set in practice or school task, I was practicing some of the exercises that I found on the Internet and I wanted to practice.
Thanks again for all the tips.
M.K
Lockout Padlock
Just say'in ...
DocJC wrote:
Lockout Padlock
Just say'in ...
great idea
jim
Pages
Topic locked
